Modern Jess
Seriously though, good work
Keep up the good work. I really dig how it's coming together.
Thanks much, guys. I appreciate it.
I love all the 'outside the box' thinking going on here. All of a sudden I need wiremold for my outlets and air lines run in aluminum channel. It might not be the most cost effective way to wire and pipe a shop but it definitely gets points for coolness and flexibility. I can't wait to see what you come up with next. Great job!
So, you going to embed this stuff in concrete?![]()
This is a great build. It's quite enjoyable following your thought process and the quality of work is excellent. Subscribed!
Maybe consider a light tube (Solatube or similar) for more natural light?
Great build...love the BMW and the scoots....What brand are the stainless rollers you have? I have a blank canvas to work with in Florida and those would work great instead of building a bench.Look forward to more progress!
great project
When you think about it, your system would provide incredible flexibility in walls that would otherwise have NO flexibility for change. So yea, I might.
Thanks for the inspiration.
nice build.
Great space for the bikes, i wish i had m,ore space for my bikes.
The skylight story brings back too many memories of "why did i do that?"
Wow, great build. I'm subscribing so I can steal ideas!
Tell me more about your air lines. I don't want to do steel and copper doesn't excite me either. The plastic and push to fit connectors are very cool and I've not seen them for air before.
Love the channel idea. Good job so far. Looking forward to more.![]()
Great job!!! can't wait to see it finished so we can see some more scooter projects...
Glad you're back. I've missed this thread.
Great thread. That channel idea is gold!
Tim
Thanks, guys!
But you know, I was just thinking last night -- as I sipped bourbon and admired my terrible progress taping and mudding the drywall -- that if I spent half as much time doing as I spend thinking (and drinking bourbon) that I'd be done by now. So there's got to be a balance somewhere.![]()
Just checking your progress, what more can I say..... Awesome.
Very nice!
Oh by the way...I like it. Its nice and clean!
With this unistrut setup, would you be able to attach a 2x6 channeled for a sliding door track and put up a door? Of course you would also need to attach a 2x6 to the ceiling for the top part of the track.
I would believe that this setup would be stronger with less weight than 2x4's/2x6's for the whole shelving build. Thoughts?
Additional details that I neglected to put in the above post:
- The shelf is 22 feet long, and runs the entire front-to-back of the workshop.
- The supports are spaced at 4', and each 4' segment should be good for around 600 pounds.
- I'm planning an identical one on the opposite wall.
- The underside of the shelf is going to be finished in drywall for a clean look. Just have to figure out how to attach the drywall.
Adding a front fascia, which is offset from the front edge of the shelf a bit to allow a recess for sliding bypass doors (someday).
How did you attach that board? Predrilled into the unistrut?
