So I found 2 hydraulic jacks at work today. They were tucked away in a corner in the body shop area. Asked the manager what was wrong with them, and he says that they don't work. So I thought I'd ask you guys to see if I should rebuild these or not.
1 of them is a Lincoln W93642. This does go up, and holds, but it only pumps when the handle is almost close to the floor. Also there is this thing that looks like a bleeder screw, which goes into one of the holes, but the threads are messed up inside, so it doesn't screw in.
The Big one I have no clue about. This is by far the biggest jack I've seen. Not a clue what it is. I tries pumping it but nothing happens. So let me know what you guys thing about them and if I should rebuild them.
, so much information. But I wish I had asked before I started to take it apart, then I wouldn't have hammered on the shaft that holds the lifting piece. Now the threads are messed up
