Time to clean off the workbench when....
Jhoff310
Perrysburg Ohio
I did this on another forum a couple years ago, decided to do it here.
Its time to clean off the workbench when....
You build another workbench because it is less labor intensive than cleaning off the current one
The calendar on the wall says 1984, because that's the last time you were able to get close enough to it to change the date
You still have the owners manual for the car you sold back in '89
The can of your favorite beverage looks nothing like the can sitting on your workbench, it has had 3 logo changes
Lets keep this going
Jeff
KSwiss
Indianapolis
You buy new wrenches cause you can't find the last three sets you've bought
nine4gmc
Dallas
when you run out of horizontal places to stack things on it and every time you do try to put something on it, it falls on your feet.
Gary S
Bismarck, ND
I still have the owner's manual for the car I bought in 1970, but that car is still in my garage and the manual is in the glovebox. Actually, that car has been in my garages for over 42 years, and I've gone through a lot of work benches in that time.
Bob C
When your cat is missing and you find he made a home under the **** on your workbench.
jdodds
Utah
.... the pile of junk against the wall may or may not be supported by a work bench.
Lkdelta
40 mi.east of syracuse
Those bench supports from the old Chicago Pneumatic factory...
are starting to sag
Kev442
Wi
The grinder dust and drill shavings mounds look like you are starting a diorama.
Norcal
When you buy a new tool because the other one is lost on the bench, this did happen & the replacement was not as good as the old one, which was later found.....
L84ARACE
I am getting ready to restore this old bench with 100 years of grease & dirt on it.
The vice that is on it.
[IMG]http://i814.photobucket.com/albums/zz62/saphead/image-10.jpg
OctoMan
Newport News, VA
Your wife complains about your projects laying on the washing machine. You clean that off and use it again because it's easier than moving the ton of **** just to get to the workbench.
Kev442
Wi
So, how many dead bodies are in that place? I have only seen that many dead flies in a house that a body had decomposed in.
Thankfully not mine. Claims the flies come in the gaps in the siding to get warm and then head for the windows, where they are trapped. This is about 6 months worth.
milner351
I'm glad I'm not the only one. I need to stop doing a million things at once, I have a workbench outside - just waiting to be covered in stuff, if I bring it inside.
