Re: 1970 F250 Ranger Project R-S 2014
I had a 1994 BMW 740i with the same color interior and I was NEVER able to get it clean like that either with home remedies or professional cleaning.
-BTW...did you get the F250 to the show on time? Is it now for sale?
Thanks
I did make it to show but was about over by the time I got there.
Thought I told the story but guess not:
Plan was to get there around noon at the latest to get a good spot. 1000+ cars will show up that weekend.
There was just a lot to do yet. Had a couple friends helping.
Never had a chance to get it completely ready to go but once it started and ran for the first time . .
It was probably 3 or 4 pm in the afternoon before I started it for first time.
Usually when I hit the key for first time a project fires right up but in this case I had removed the gas tank behind seat and re-soldered the pickup tube, tank was bone dry from steam cleaning it.
I put a dash of gas in carb and it fired instant but of course would not stay running. Between the fuel selector being in wrong position and not allowing fuel from tank I was trying to use and also (once that was handled) the fuel pump would not prime itself no matter how much fuel i kept adding to carb.
I finally pulled line from bottom of selector valve and put air in tank with line off at fuel pump. That did the trick.
Took it around block for initial test drive and by then when I got back the truck would not turn over. All that cranking on a battery that was never charged in the first place made it low not to mention the fact the charging system was not working.
It took a bit before I found the field wire was broken inside of harness at alternator.
By then a lot of time rolled by. We then headed out to the show approx 22 miles each way. No tuning no nothing just got in and DROVE!
About the time I got to destination the headlights started to blink on and off.
Dimmer switch was acting up . . . When I pulled into the lot and was about to back up the clutch went to floor . . . Did not hit anything in the very close quarters but had to be bailed out by another forum member . .
So a bit of drama but with no real testing etc it was just getting it there.
When we pulled in people were already leaving.
Yes, Truck is for sale. Still need to do a few things, a bit more cleaning and detailing.
This week is shovel out garage week as it gets beyond messy when I have a deadline to make and It has never been organized since I moved in.
So I have not done anything to truck since Saturday. Other than clean inside of box.
In my "SPARE" time I am sorting through pics on my computer that directly relate to what I post here. I just added them all up and its 14,814 photo's to deal with. Trying to upload to photobucket etc
