wreckdiver1321
The floor coating is what led me to GJ. After reading a **** ton of threads on it...I tossed down to coats of concrete sealer and called it a day for now.
I made my own cabinets....but used discarded cabinet doors.
This is my thread on the garage build......
Cabinets are towards the end.
DDawg16's Garage Build in One Post
I started my garage build back in October of 2008......I had many posts documenting it's progress....then I got asked today where my link was to my garage build (and jeep build...another story). Makes sense....so I've pooled all the picks and put them in chronalogical order.... First...a...www.garagejournal.com
Oooooh, that's not a bad idea. I have to check your thread out!
I did the Delta Dye and it worked great. I’m real happy with it!
Your shop looks awesome, and the effect you got on that floor is great. Is that Legacy's Nohr-S?
I'll state that DeltaDye worked really well, I was just a blockhead and didn't prep or plan correctly. That won't happen this time....
I think I have figured out the path forward from here.
Step one is to remove the oil stains as best I can. I'll be looking into ways to do that and try to tackle that this week. Next is to grind the floor in order to remove the color as best I can and get closer to fully removing the oil stains. After that, it should be just about prepped. Maybe. Hopefully.
I'm going to take a stab at using the gray DeltaDye to darken the floor before the polyurea goes down. I only bought a gallon, and my plan is to dilute it to the maximum recommended level of 1 qt water to 1 gal stain. This should dilute it enough to give me a pretty light, minimal effect and be able to cover the entire floor. I'm not aiming for really artsy or pretty, just a nice industrial-looking space.
In other news, I started working on breaking down my pallet pile. Pile O' Pallets? I think I like that better.
My Pile O' Pallets is about 35 or 40 strong. You're looking at 3 layers of six-foot tall stacks there. I'm hoping this will be enough for the projects I have planned. If it's not, I might need to rethink how much **** I take on at once.
Because I want to reduce the Pile O' Pallets to a Pile O' Lumber as quickly and efficiently as possible, I needed a method to break the pallets down without destroying my back, destroying the pallet stringers, taking all the rest of the time I have left on this mortal coil, or some combination of those three. I have used the old hammer and pry bar method before, but I found that marginally less pleasant than being on fire. I came across someone here on GJ with the most brilliant method I've yet found. I apologize, I have forgotten who said it or where I saw it.
Basically, the method here involves using a sawzall to cut the nail shanks and release the stringers from the main beams. If you start by wedging your pry bar beneath the stringers to provide a little separation, you can zip through the nails down one entire side in about thirty seconds, then repeat on the other side. The center support requires some more fiddling, but I can say the whole affair is made dramatically easier by a 12-inch blade. I ended Sunday having broken down 8 or so pallets and having a nice stack of weathered slats for my troubles. I'm not sure why I didn't get a picture of that, but I will take one once I have more to show for my labors.
Also this weekend we committed to an interior paint color scheme. For anyone wondering, we went with Sherwin Williams Stony Isle gray and their super-duper white color for the ceiling and trim. the whole house will get that paint job, except for an accent wall in my kids' room and probably the gym. It looks great and should brighten up the whole main living space. Our kitchen/dining room is catastrophically dark thanks to a brown color scheme, so this is a much-needed upgrade.
The living room isn't too bad, it just needs fresh paint. We're not actually sure if we're going to paint over the blue accent wall in the living room yet. Regardless, the new color isn't that far from what's already there, but it will definitely modernize it a good bit. That will help once I look at re-trimming and doing the doors.
We have a family friend who is a professional painter doing the painting for us, because I just don't want to. Too many irons, too much fire.
In fun news, I got my JIS Vessels! Wait, that sounds wrong....
I ordered a set of new screwdrivers as a little gift to myself. I'm starting on a long road of upgrading the hand tools I have, not that they're bad, but I'm at a place where I can swing for some nicer stuff that will last. I'm planning on Vessel screwdrivers, Knipex pliers, Hazet or Stahlwille metric wrenches, Wright SAE wrenches, Ko-Ken sockets, etc. Keeping my Kobalt ratchets though, because they're great. It's an eclectic collection of manufacturers and designs, because I'm weird and I like stuff like that.
More to come!
