Tooling (Re)Organization
Weirth It
Port Orchard, WA
New Workbench Build
In the past 4 years I’ve learned a thing or two about building cabinets. Even though melamine has been good to me (meaning it hasn’t yet failed me), It’s not the strongest for cabinet assemblies. The previous bench utilized unfinished baltic birch for the face frames and the drawers. To finish, it took me about a month to apply 3 coats of poly (spray, scuff, spray, stuff, spray) on both sides of the drawers and a single side of the face frame spraying sometimes 2-3 times per day and many times per day on the weekends.
This go around I'm going to apply what I've learned and build the boxes out of pre-finished baltic birch. This pre-finished material comes from the supplier with a fairly durable UV stable clear coat that has a much nicer finish that what I'm able to spray myself in the garage and it only costs $10-$20 more per sheet depending on where you get it and if you get a break on quantity. I've only been able to find 2 places that sell it in town but they regularly have on hand so there's no need to order it in advance. The only downside to using it is it requires careful handling during machining (or it looks like junk when you're done). For the price difference, I have no issue slowing down to go MUCH faster.
I really really wanted to get the main boxes built this weekend so I didn't slow down to take pictures until I had the main assemblies pieced together. I apologize however I promise that once you've seen me break down a sheet of ply, you've seen it...fast forward...the two boxes, a total of 8'2" long, are laying on their back machined and ready for the face frames.
Orientation-wise, you can see the bottom in this picture. These assemblies are designed to have some fairly wide drawers so they can hold tools that I never had a dream of storing in my old bench (e.g. 36" long impact extensions).
On the old bench I used remnant pieces of the baltic birch cut into thin strips for the face frames and attached them using brad nails. This cause me to spend time patching holes and sanding before I could finish. Since I have a few dozen feet of white maple left over from the kids closet builds I decided I'd use that up. It being hardwood makes it a better choice for shop cabinets anyway because it can take more abuse.
The face frames are hall hand fitted pieces. I cut the verticals so they run a little long top and bottom and then hand fit the rest by measuring and cutting the smaller pieces one at a time. I'll do a more comprehensive breakdown when I feel like I have more time, like when I build the uppers.
Once i have everything fit, I mark and trim the verticals to be flush top and bottom. I do it this way because it allows me to hide slight imperfections in the boards (like if one is 1/16th narrower) by cutting them point to point instead of 90* to length...if that makes sense.
The conventional face frame would be held together as a single assembly using pocket screws which would require me to mark all of the intersections and pocket hole screw the thing together on a large assembly table. I did that for my first two cabinets but, since then, have done it a little differently. I, instead, leave all individual pieces floating so I can remove them, refinish them, and/or replace them later individually if necessary. Then I attach each one using pocket screws which, along with the dominos, prevents it from moving. This allows me to color change or repair my cabinets easily down the road. The cabinetmaker probably cringes...I’ve had no issues to date so no evidence that the face frames actually need to be one assembly. Again I'll go into better detail when I build the uppers.
With the face frames complete, I then moved the cabinet assemblies over to the new location in preparation for install using this conversion hand truck/dolly.
Before installing them, I need to add rear nailer boards. Here’s another notable difference in these cabinets over the old ones. The back have a 1/4-inch thick back panel and I add 5 1/2-inch wide nailers to the top and the bottom. When attached with pocket screws, these nailers serve three purposes - (1) they add a substantial amount of strength to the cabinet. (2) They provide a strong way to attach the cabinet to the wall. (3) they push the back panel forward solidly into the groove so, from the inside, the panel appears to have zero reveal.
Took me all weekend to get to this point...dropping them in place.
It's fun to see a pile of ply turn into something like this in a weekend and to think that all of the flat surfaces already have clear coat on them! I'd bet I build this one in 10th the time. Kinda wished I'd timed myself on the previous one.
Sorry for going back in time 4-years or so but I have a question about pictures in this thread from this post back to Jan 20, 2018 (start of tool (re) organization thread). All of the pictures just show the file name and extension (IMG_XXXX.JPG), no picture showing.
Any idea on how to get the pictures to show? I am in the process of building a Shop and will eventually be looking for work bench ideas. Judging from the text, it sounds like you have great ideas but I am more of a visual learner.
Thanks for the help.
L
lilscorpion
Colorado
Edit: Shoot, looks like all pics from the thread are gone. I was right about tapatalk after all. That's a super bummer. There's no way I can get them all back the way they were but I'm going to have to figure out how to publish a photo album with my mountain of organization pics.
Trapps
The Detroit Zoo
More than a few people will be extremely happy if you are able to make that happen. I personally would account for at least three of them.
L
lilscorpion
Colorado
Matt, that rack really looks good and powder coat to boot! And then look at all those Craftsman wrenches....WOW;)
Thank you. I usually have a good picture of what it may look like in my head before I start but sometimes it ends up not quite as neat. I this case the result was a little bit better. The color helps immensely. They looked cool as bare aluminum but bright red... :D
Those look nice! Where do we order?
I wish I had a bigger machine and more advanced processes. I thought about building a few extra and selling them but since there will likely be 6 different lengths/styles in just my box, it seemed more complicated than it's worth. On the flip-side, maybe I do need to create an etsy account.
Edit: after a little reading, Etsy isn't my jam so that ain't gonna happen anyway. My biggest issue in regards to selling is having to deal with the commercial side of things. I've been there, done that and don't want to do it again. Shipping, returns...blek. I had considered just making one extra of stuff throughout the year and then use them in the secret santa...
L
lilscorpion
Colorado
I'll start looking for a place to host them. Would like something that allows me to control order/sequencing as well as a blurb below the pic. If you know of something that would work like that, let me know.
I'm super bummed. Tapatalk is junk.
Trapps
The Detroit Zoo
I went through it when Fototime flew the proverbial coup.
I've had great success with the capabilities of Flickr. I did splurge for the Pro version. I landed there after research and recommendations from @drivesitfar, a few others and @sakurama who is a Pro.
Bob Heine
Boca Raton, Florida
Matt, I went back to page 1 and 3 and I can see all your pictures. I noticed quite a few picture-rich threads weren't showing the pictures when I first opened them but they appeared when I refreshed the page (sometimes required multiple refreshes). It may have something to do with my connection -- AT&T just upgraded me to fiber so I have 600 Mbps upload and 510 Mbps download speeds.
EDIT: When I expanded the post @Weirth It quoted, the pictures were there. They also were there when I clicked the @lilscorpion link in his post, taking me back to page 3.
Trapps
The Detroit Zoo
Bob, can you see pics in these posts:
Bob Heine
Boca Raton, Florida
Matt, in the first post I can see 22 pics, in the second I can see 3 pics (screenshots?) and in the third I can see 10 pics (and 10 thumbnails at the bottom of the post).
gearhead1960
Understand the hassle of selling. Been dabbling on eBay for close to 20 years. Recent changes on the bay and meddling by the Feds on reporting rules has taken all the fun out of it. Now using local consignment to flip Estate Sale finds I’m not keeping.
L
lilscorpion
Colorado
that's odd. I feel better but still odd. Regardless I think I'll find a place to post up the pics anyway. I know the older thread has some missing as well.
L
lilscorpion
Colorado
I get ebay is a business but they take quite a chunk of a sale. During covid I sold off a bunch of tools I'd not used (ever that I can remember) which I purchased at an auction about 20-ish years ago. Getting anything for them was nice but I learned the hard way that they can take up to 40% if you take advantage of their premium services. That's just nuts.
msharley
Central Pennsylvania
The next step was to figure out how to machine a mirror of the long/right rail. After some futzing around, I figured out how to make a mirror version of the rail. There’s a mirror function. I used a piece of 1/4 6061 as a fixture base and cut the next revision.
A few heavy spot welds I’m the corner keep things where they need to be.
A quick sand blasting to prep for powder coat helps slightly break the edges and give the coating to something to bite onto.
The single in-wall kitchen oven can creating challenges for larger parts.
Spaced it just so the box end of the wrenches would fit between the rack rail and the drawer side. This will keep them from sliding around as much as is possible.
And loaded it up.
I like the contrast of the red behind the clean wrenches. Now that I can see one finished, I know I’ll like the whole drawer organized this way.
Fantastic!!
Trapps
The Detroit Zoo
****, that was a LOT easier than I thought it would be. Tell me what you see when you click these links:
Container Shelves: https://share.icloud.com/photos/0bbZV3fWsYRc5ImxVDegOMPIQ
Lathe Tooling Organizers: https://share.icloud.com/photos/010lyolVfLnONm-GxbcXTcAkA
MFT Horses: https://share.icloud.com/photos/010lyolVfLnONm-GxbcXTcAkA
MFT Table: https://share.icloud.com/photos/00eSRy2yifQC3fHzRniOjIL3Q
MFTC: https://share.icloud.com/photos/0fetFpJ4pQYHGW6HRazD3tGqw
Kurt Vise Stops: https://share.icloud.com/photos/0c3mCYb5WjsMVpypf-PpFNa3Q
Knee Mill Tooling Arm: https://share.icloud.com/photos/050gLZxzZuNLtdCweadrjnbbg
Nail Gun Rack: https://share.icloud.com/photos/0abW-AArlcO7RhDc8QovkZEEA
HPLV Drawer Organizer: https://share.icloud.com/photos/0abyfuQcXRDp2C9FOwzEeNZWQ
French Cleat Clamp Rack: https://share.icloud.com/photos/048F69SgZS-0-S6iRs7sQPjKQ
Domino Offset Base: https://share.icloud.com/photos/049Z4rzo47ohIXPlqOw-xkLvw
Gas Cylinder Stand: https://share.icloud.com/photos/030eAGQ5TwYiHBBGKf9LGJ4XA
8020 Aluminum Corners: https://share.icloud.com/photos/0f7jCl2kBB_gzB8so9CxQxiGA
Portable Drying Rack: https://share.icloud.com/photos/084tQ4lKdKKf_4XioEqjSeiFw
Drawer Organizers: https://share.icloud.com/photos/0eblqPGRIcK_CbhiU0i3W5frw
Systainer Tool Box: https://share.icloud.com/photos/02fwkKesXXv5Wqeu3c4QJCk9Q
Sys-System: https://share.icloud.com/photos/0f1I_ZfmProJvUyufydEq2Cjw
Router Cabinet Module: https://share.icloud.com/photos/0ffFnNnrV5E2kVYN7B-Gb7Cjg
Systainer Shelf: https://share.icloud.com/photos/0ccIdbrkljaJAZhOUxuP3BQqw
Systainer Power: https://share.icloud.com/photos/02b0YcpGaPlp7yRbSQkmx75DA
Sys-Ports: https://share.icloud.com/photos/056q50axoqTY5GHeusmdhZtGA
R8 Tooling Rack: https://share.icloud.com/photos/08bpJOMJfOPhhj8kvAjswFJog
Powered Sys-Port: https://share.icloud.com/photos/099_UDg_yAM0T5O3mS8rokEMQ
Router Table: https://share.icloud.com/photos/0a4JUl9S78p_Wx3VbBszrL0xA
HDPE Socket Organizers: https://share.icloud.com/photos/06fxvZRR--_lYVvwEWwsoD0CA
Ratchet Organizers: https://share.icloud.com/photos/07eYTlSqsrpVs9KB77kfByaPA
Router Plate: https://share.icloud.com/photos/017SI3NZfuIj_REfH4Q0aq9JA
Router Plate - Jig Saw: https://share.icloud.com/photos/0d18ukfRTpPz-AkqqFkollrxA
Router Plate - Bandsaw: https://share.icloud.com/photos/0b0UXP-Ji1MRvZPMsiSo8F8lw
HDPE Organizers: https://share.icloud.com/photos/0abJQLkZpJPiDPMpJ2tU6Axzw
Power Coating Booth: https://share.icloud.com/photos/0b0tclEZIzOXbencjS3vl964w
Socket Organizers: https://share.icloud.com/photos/035WX4aG9ijGXVeuRa77lSntQ
Wrench Organizers: https://share.icloud.com/photos/005ozdAAX5gyIhmKlJGpDazxg
Links are all good! We see well organized (Shocking!) pics in well labeled albums with the ability to download. It looks like that ability expires on February 15. not sure if pics will be visible after Feb 15; I am not familiar with iCloud Photo.
Thanks a ton!
L
lilscorpion
Colorado
Thanks a ton!
Ah, the catch. Ok, plan B (I was prepared though I did miss the expiration):
try this one:
Socket Organizers - https://www.icloud.com/sharedalbum/#B0i5nhQSTqZE30
and this…
Shop Benches - https://www.icloud.com/sharedalbum/#B0iGY8gBYGiaXu1
Strouty
Southern Maine
Using iCloud is interesting, I have all but given up on photo sites, they either disappear or start charging too much, or add limitations that make it near useless. I have been using the GJ to host them now, it seems a lot cleaner since they swapped platforms.
L
lilscorpion
Colorado
I’ll have to redo the albums. The public share I created expires but there’s a “shared album” that you can share as a website and it stays forever (until I switch to Android) and the albums are living things so if I add pics to them later, anyone who has the link will be able to see them.
I have been using GJ since coming back. It does work well. I do still wonder if they’ll expire or there will be a time where they age off (for $$$ reasons).
Bob Heine
Boca Raton, Florida
Matt, one of the reasons I'm an Alliance Member is to keep Ryan in business. Rather than donating to a website that just provides a home for pictures, I'm donating to one that focuses on my interests (and the people who fail to upset me).
zmotorsports
Northern Utah
Well said Bob. I don't support many websites but I am proud to support Ryan for one of the places I enjoy sharing and learning from others. I figured this is where I can post my work kind of like in a blog format and host pictures.
L
lilscorpion
Colorado
I guess I’m alone in my own little word. I actually noticed the “Alliance Member” tag a week or so ago and wondered what it was for. Now I’m one of the cool kids too…. 🍺
L
lilscorpion
Colorado
Got a little more time in on the wrench organization. I worked on a few variants of the rack for the different kind of wrenches that fill the drawer. To take advantage of the space to the best of my ability. I needed to make 6 different variants. Smallest to large leaning left, right, tapered/straight and all three also going from large to small.
As I made each variant, I tested the spacing on all the different sets in order to keep the spacing consistent.
The two rails are tied together via some 6061 1/8 bar. This is how I fixture them. I use angle iron drops to hold the cross braces in place. I set the angle with an angle finder and then tag it together.
Some are just variations of length but the same profile.
Nearly finished drawer. I ran out of material with only the flare wrench rack left.
zmotorsports
Northern Utah
Didn't mean to guilt you into it Matt. I was just expressing my reasoning for helping support the forum.
There is a great group of people here and a vast amount of knowledge to be gained from its members.
On a side note Matt, I stumbled across your son's Instagram page the other night. I had posted some pics from a truck I was working on and his midas_lj popped up on my feed. The LJ sure looks great and it's been interesting to follow along on the turbo setup.
L
lilscorpion
Colorado
You didn’t guilt me into anything. I’ve noticed “Alliance Member” under peoples alias many times and didn’t know what it was and never even looked into it. Sometimes I get stuck in my 3-foot world and Covid had certainly amplified the haze around it. I should support Ryan and the board. It’s the only place I go and socialize. 😜
Thanks Mike, we’re having a lot of fun with the Jeep. I have most of it figured out. I’m so tempted to build a turbo kit to sell…it’s taking everything in my being to not just buy a plasma table and get back into it.
Regarding Instagram - Andrew has been working on figuring the Instagram algorithm. Social media is crazy. He even did a live feed last weekend to answer questions about the Jeep. He did way better than I could have.
zmotorsports
Northern Utah
I think he's got a knack for it based on what I have seen so far. I think his Instagram page has blown up over the recent weeks.
I have had a lot of comments from friends about my Instagram posts and YouTube videos about how to get more subscribers but I don't necessarily do them for the subscribers. I just like to post up what I'm working on and various projects in the shop as well as some trips. As for the videos, I know my channel is NOT what is going to attract a lot of subscribers as it attracts a very, very small niche group of people but I enjoy doing the videos so I'm not focusing on volume as much. I just want to give good content and not fall in to having to conform to the algorithm of the many hack jobs on YouTube that seem to have hundreds of thousands of followers.
L
lilscorpion
Colorado
It was driving me NUTS that I was so close to being done with the SAE drawer so I snuck out to the shop tonight and knocked out the last small wrench rack for the box end wrenches.
Hopefully I can coat it tomorrow night. Being just a little closer is gonna make me sleep so much better.
L
lilscorpion
Colorado
Yeah, it's a bit cramped in there. Those are just up to 1" SAE and 24mm Metric. My large wrenches (up to 2") are in another drawer as they don't get used quite as much and would never fit in there.
I just don’t have anything big enough to need a wrench over 1 5/16…or haven’t yet. The big sets look cool tho.
Pressingonward
SW WA
Thanks, the idea of adding washers to stiffen a spring that's too soft is what I'll have to do then, great idea. Wish I could make a stiff spring a scosh softer...could I make a spring shorter by taking a coil off the end maybe?
You can remove a coil but it will make the spring stiffer - there is less spring length to deflect for a given load. If the spring in its assembly has a lot of preload then removing a coil could reduce the force it is applying despite the stiffer spring rate - would have to analyze it for a given application.
Really to make a spring softer you need a different spring or reduce the preload on it by machining material off the parts it sits against. A spring with lots of preload will resist movement until the preload force is overcome, then compress relatively easily. A spring with low preload but a stiffer spring rate will compress easier at first but due to the higher spring rate will resist compression better as it gets compressed, if that makes sense. For suspension, low preload and stiffer spring gives much better performance. For a BOV, higher preload with a softer spring might be better since it will resist opening at first but then open more easily once the force reaches a certain level. Just need to make sure the spring can still compress enough without coil binding
zmotorsports
Northern Utah
I don't use the 2" very often but I routinely use my 1-1/8", 1-1/4", 1-3/16", 1-3/8", 1-7/16" and 1-1/2" wrenches and sockets. I also have been using my 3/4" drive stuff quite a bit lately. These large RV's have big fasteners. :bounce:
slodat
Central-ish, WA
I recently bought Tekton 3/4 drive sets to extend my 1/2 stuff up to 2” and 50mm. It’s nice to have on hand when you need them. I’m seeing larger fasteners on machine tools.
L
lilscorpion
Colorado
Done? I see two wrenches without a holder????
Hehe, there’s always a critic. 🤣
one (has orange electrical tape on if) has a jammed ratchet mechanism. The other is an odd wrench I used to keep at my cold saw which I sold with the business 20 years ago. We’ve separated but are still living together. We’re trying to work it out but the issues are significant. We’re more or less staying together because of the kids.
