BoilermakerFan
Subscribed! Looking forward to this evolution...
So you’re saying that if I didn’t buy tools I wouldn’t need them to build things to organize them?! Hell...never looked at it from that angle.
Hmm
I never woulda had to organize in the first place which would have prevented me from needing to re-organize.
Which would mean...
I could technically have a smaller garage AND my wife would easily be able to park in it which would make her happier.
Did my wife put you up to this?!?
stioc said:Haha! No, that was about me, where I go thinking "oh with a table saw i could build cabinets for the house" but I end up just building jigs, sleds, tool storage for the table-saw itself and then it gets tucked away because by that time I've found another tool to fixate on...hello mill...hello lathe...hello lift...hello labscope...hello plasma cutter...on and on. It really is a disease
In your case you actually do use your tools to do the house upgrades/remodels etc![]()
I understand the desire to have things match/symmetrical, but that sysport looks good.
How big is your garage? It looks huge from all the stuff / pics but my best guess is it's one of those "L" shaped 3-car tandem garages?
The Westling trays are as perfect as you're going to get in that 'open' style (not set sizes) far as I have ever seen. I use two of them for hex/torx impact sockets, for instance.
bj383ss said:So on the Westling trays that you want to make does the stud have to be metal. I made mine from dowel rod. What if you made your studs from HDPE you turned on the lathe? Then you would have control of diameter and height.
Bret
I made my own version of the Westling trays with scrap plywood and 3/8" dowel rod. It works great and only took 30 minutes with scrap pieces.
Prometheus said:Any way you could do something like the Ernst twist lock rails?
http://www.ernstmfg.com/Twist-Lock-Socket-Organizers.aspx.
You just add you remove clips as needed. One of the best solutions I've seen.
Concept: I know that historically I've stuck to the HDPE socket organizers (similar to the Mechanics Time Savers) however I've realized that they're too tailored to the actual sockets (exact size).
EOC_Jason said:If I were to do this, I would have reversed the 2nd row, that would have allowed more space between socket rows to grab them easier, or you could have made them closer together and used a smaller piece of material. But that's just me...
boiler7904 said:...turns into Toolbox Tetris. They're there but I'm not happy about the results.
You have a lathe... That would be an excuse enough for me to turn some aluminum!
I understand you are trying to make it as easy as possible and cost effective.
Did anyone mention 3D printing?
No. I presently don’t have a 3D printer and I wouldn’t know how to find a good one. Do you have experience to get me through that learning curve? Printing them would be cool, I’d learnt something new, and I have a new capability in the shop.
I do know the longest tray I’d want to make is 22”. Knowing g my luck it would take a $10k machine to make a part that big...
zr52002 said:I've taken this on to a degree!
It's not practical to print a whole drawer at a time - common printers are not nearly that big, and each tray would take forever to print. I think it's handier to do this in 6-8 inch modules anyway - none of mine are nearly as big as my printer could do.
I have a Prusa i3mk2 - of course you'd want the mk3 if you got one today https://shop.prusa3d.com/en/3d-printers/180-original-prusa-i3-mk3-kit.html
It doesn't come through great in the pictures here, but everything with a size has that size 3d-printed into the plastic. I would really like to get the multi-material upgrade for my printer so I could print the bottom of the text in a contrasting color so they'd show up better.
zr52002 said:It's been a while - I think those took a couple hours each to print, but I'm not positive now.
I work from home so I draw them up overnight and let them print all day, no big deal.
