Thanks Monte.
Spongebob89 said:do you know where can I find an old used RPM Indicator like this in the below image. There was any good brand back in this time
Where are Laser tools made. I specifically have my eyes on this
Laser Tools 7865 Twin Function Brake Pin Punch Set 3pc
Laser Tools 7865 A set of specially designed pin punches, particularly suited to use on vehicle brake pad pins where the pins are a tight fit and the ends...www.lasertools.co.uk
That's cool, Weras aren't made in Germany for a while now.
We assumed Stahlwille but not 100% sure. BTW thanks for your opinion.@Eone While most others said your Format wrenches might be Stahlwille, I honestly doubt it. The only Stahlwille thing about them is the "hollowed" out Beam. On the other hand, the finish looks wrong, Stahlwille usually engraved the sizes in the past, only recently they added them in the casting. The shape of the open End does also look wrong to me. All examples of Stahlwille wrenches I could find, have a very distinct, consistent geometry, while yours are a little rounder and less consistent.
Sadly, I don´t know the OEM either. Finish, and the font of the "GERMANY" look very Gedore to me, the shape of the Box Ends, and the fact that they are OEM, I think WGB might also be possible.
I think your Würth spanners could also be Heyco made, rather than Belzer, comparing them to the Heyco Maxline wrenches.
I bought them from here:Hi,
there is any link of these products?
I think you can find NOS Elora SAE socket setThe shown window scraper, Handy MK2 manufactured by Jydsk Barberblade-Fabrik A/S in Denmark, could be about 30 years old (definitely more than 20). I was somewhat surprised to find that not only is the company still in business but the same model is still being made (and spare blades are widely available).
Now for something completely different. I was able to find a set of 1/2" impact sockets in metric sizes by Toptul for a reasonable price. As for SAE sizes, Toptul makes them, both long-reach and normal, but no one seems to sell them in EUWhat would you suggest as an alternative (not Chinese but not super expensive either, usage is infrequent)?
For impact sockets I tend to favour either KoKen (made in Japan) or Deltec (made in England).Now for something completely different. I was able to find a set of 1/2" impact sockets in metric sizes by Toptul for a reasonable price. As for SAE sizes, Toptul makes them, both long-reach and normal, but no one seems to sell them in EUWhat would you suggest as an alternative (not Chinese but not super expensive either, usage is infrequent)?
Hello,
I want to buy a mafel cordless drill but it has two models where the one is called impact (i think is hammer and not impact drill). A guy has told me that the simple drills have more precision on drilling holes than hammer drill but I am not sure that this assumption is right. If the hammer option on a drill has no impact on his functionality, then why companies make always two models where by the way the price is the same?
Cordless Impact Drill Driver ASB 18 in the T-MAX
Cordless Impact Drill Driver ASB 18 PURE in the T-MAX | Cordless Impact Drill Driver ASB 18 PURE in the T-MAX | 91C902
To overcome the toughest challenges, we have given the new-generation A 18 and ASB 18 an especially rugged specification and extra power.Its impact drill function makes the ASB 18 a genuine all-rounder.The upgraded PowerTanks for our cordless tools featu…produkte.mafell.de
Cordless Drill Driver A 18 in the T-MAX
Cordless Drill Driver A 18 PURE in the T-MAX | Cordless Drill Driver A 18 PURE in the T-MAX | 91C802
To overcome the toughest challenges, we have given the new-generation A 18 and ASB 18 an especially rugged specification and extra power.The upgraded PowerTanks for our cordless tools feature advanced processor-controlled battery technology. A key advant…produkte.mafell.de
The hammer function usually ads a set of toothed gears within the gear housing.Anyone to know about this?
I have one Deltic impact socket, a deep 30mm 3/4" drive that is permanently attached to a 1/2" adapter and used on an cordless impact wrench for tightening the stanchion foundation bolts on the steel frame buildings I work on sometimes (I do the concrete work so they get used to build the bolt set up on the template, then after concrete remove the nuts, remove the template, pull the waxed cones out, nuts back on, use a pipe to wobble the bolts around so they move so the stanchion can be bumped into alignment)For impact sockets I tend to favour either KoKen (made in Japan) or Deltec (made in England).
KoKen are excellent, and offer nice sets in steel boxes. Metric and SAE are available. I’ve used these for some years and they last well. I’m sure they will have an importer or dealer in Finland
Deltec are also excellent, but are geared to industrial customers so tend to offer less sets. The prices are not loaded if you buy individually though. They offer Metric, SAE, Whitworth, 6 point, 12 point, square, bi square, regular depth, semi deep, deep - pretty much anything really!
Deltec also last well and are pretty much my “go to” now. They’re used by a lot of British industrial customers, and on the railways. They will take heavy usage, but are quite affordable. If they don’t have an importer in Finland I’m sure they will supply direct!
I must admit I like Facom “Borneo” drivers for these combination screws. They offer slotted / Phillips or slotted / Pozidriv.A while ago I decided to try to find screwdrivers that really fit the combination slotted/something else screws I find in electrical terminals. Long story short, nothing I encounter in the USA appears to be slotted/phillips, DIN rail components are slotted/pozidriv, and American electrical outlets more often than not are slotted/square and are best engaged by my lone Milwaukee.
During the process of figuring this out I discovered and became a big fan of Felo's E-Slim series of drivers. Their small handles can be spun quicker and easier than standard handles, which are optimized for higher torque applications. They also have the nicest cushioning and all the shafts have the end of the insulation flush with the tip.
Does your Milwaukee have an ECX tip?A while ago I decided to try to find screwdrivers that really fit the combination slotted/something else screws I find in electrical terminals. Long story short, nothing I encounter in the USA appears to be slotted/phillips, DIN rail components are slotted/pozidriv, and American electrical outlets more often than not are slotted/square and are best engaged by my lone Milwaukee.
......ECX bits are designed to fit a specific type of combination head screws that you see on many electrical components and terminals screws.....
wondering why does it have CE (china export) stamped on it.
its the safety cert issued by chinese gmnt , the chinese version of UL but a lot easier, cheaper to procure.
