And what can you say about SAM quality compared to Facom? What do you like better?
Hard to compare them directly since they're totally different styles of pliers. I have some Facom needle nose pliers though that are probably my favorites out of Gedore, Knipex, NWS, Klein, and Channellock. I have some SAM needle nose pliers on the way, so I'll be able to compare them when they come in.
I can compare the Made in China Facom welding locking pliers to the Made in Germany Bollmann-Selzer/Knipex/Elora welding locking pliers though. The Facom's have a rougher finish that isn't as comfortable to hold, almost like extremely fine grit sandpaper. The chrome plating is also slightly less even around the edges. That said, they weigh about the same and at least they seem about as sturdy. One issue I noticed is that when you pull the release lever on the Facom's, the handle springs open quickly with a lot of force like it's going to shoot out of your hands, whereas the Bollmann-Selzer pliers open confidently, but don't feel like they're going to shoot out of your hands.
I also just got a new made in South Africa Gedore adjustable wrench today, which completes my recent purchases of adjustable wrenches to compare.
The top two, the Irega and the comfort grip, reversible jaw Bahco wrenches are both made in Spain. The VDE Elora adjustable wrench is made in Germany. The middle Bahco and Elora adjustable wrenches have no COO. Anyone know where these are made? They're the Bahco 8701 and Elora 61-MB.
The Irega with the thumb screw adjustment has the absolute least amount of play in the jaw, almost none whatsoever. But it also takes the longest to adjust, as it's a more fine adjustment with a wide range in the jaw capacity. It seems like the 771s with the end screw aren't made anymore? I didn't see them on the Irega website anyway.
After that I'd say the 6in Gedore adjustable wrench has the next least amount of play despite being the smallest. It feels light but strong. The rest are all basically the same, good but still some play in the jaw.
The Elora VDE wrench has the nicest finish, and then after that probably the two bahco wrenches, then the Irega and Gedore.
The only weird thing is that the Gedore wrench has some weird surface coating inside the jaws that looks like it's coming off already just having been opened.
And then finally, I got a new pair of Grip-on rebranded SAM locking pliers with an adjustable copper swivel clamp.
Once again, curiously, they lack the Made in Spain stamp that the Grip-on's have on the opposite side. However, you can see that they're identical to the actual Grip-on version. The only other difference is that the jaw on the Grip-on pliers is aluminum while the jaw on the SAM pliers is steel. This makes the SAM pliers about 200 grams heavier.
Sent from my Pixel 2 using
The Garage Journal mobile app
