alwaysFlOoReD
Yep. Well, not dirt. Crushed asphalt.
Yes can concur, have had the trusty TS55 Festool and have the MT55 Mafell. They are both great but the Mafell has more grunt Similar to my TS75,it's a lovely tool.I’ve put a ton of mileage on little and big festool track saws. If budget allows, go with Mafell, they’re better.
I ripped 10/4 poplar recently, 10’ lengths with the Mafell tracksaw, it doesn’t skip a beat but in the past when I’ve done that with festool, I had to take 3-4 passes and baby the thing even with the correct rip blade.
I’ve done the same with 10/4 walnut and both sides toward center with 16/4 sapele.
So true! But really, should be no shocker to anyone on GJ. But a point we have to keep making because some folks here think of the price of tools as a loss or a frivolity. I don’t think I own a tool that hasn’t paid for itself several times over.He is another way to look at the cost. I was going to build a couple of bookcases out of 3/4" walnut plywood, as I had some. What is the cost of one walnut bookcase ? I would think the saw would pay for itself on that one project, let alone the second one . The saw then is free and second one is gravy. Or if I screw up a sheet, that is half the price of the saw. It's not that hard to do with a skilsaw and a guide as I have found out. Luckily it wasn't on something that mattered . I did get a lot more serious about a track saw after that.
I swallowed the LR32 kool aid so I needed some with holes).
I am not a commercial shop. Have no need of one. Just need a fuckton of built ins needed for my shop/shouse and future house and future green house/shop. And new cabinets for my mom. I could probably find a used line bore for not much more than the LR32….but the space requirements.Perfect time to upgrade to a line bore from the lr32. Even something as small as a 7 spindle.
My shop is only 36x48 with an additional 12x20 shed and I have to shoehorn in wood working, automotive, small engine, metal working, paint area, an office, a full bathroom, and a 20x36 living area/kitchen (in a mezzanine).
Let's not get carried away! They are quite useful and I highly recommend buying one, but it won't totally replace a table saw.A track saw does it all
A track saw is not a replacement for a tablesaw.With the right MFT type table setup, a track saw is easier and safer than a table saw for many things. Not the best at ripping hardwoods (although the bigger ones can) or small cuts. Also can replace a miter saw for many things (definitely not all).
Reading comprehension? Or did I trip into Reddit?A track saw is not a replacement for a tablesaw.
I think it’s more helpful to compare between the two tools equating price and space allowable. Some here compare $350 tracksaws with $3000 powermatics with out feed and extension tables and reach the genius conclusion the $3000 shop monument is superior.What exactly, in a home shop, will a table saw do better than a track saw?
I have used a track and a table saw. There is only one thing in my mind that a table saw has a slight advantage. The rest go to track saw.
MFT type table with hinge and stops.A table saw will do repeat cuts without resetting.
I don't own a track saw (yet) but believe a solid table saw would generally perform much better than a track saw in almost every way. Repeatable cuts on both sheet goods and lumber. Miter cuts (with appropriate miter fence or sled). Anything requiring a dado. Tenons and other intricate joinery. Index cuts (another version of repeatable). Cutting lids off boxes. Chess and cutting boards. Cutting a circle in plywood. Just to name a few off top of my head. With that said track saw is definitely on my wish list but I think I would use it mostly on job sites. Flooring, counter tops, Cutting doors to length, possibly stair and deck work for example trimming deck boards to final length etc.What exactly, in a home shop, will a table saw do better than a track saw?
This. Track saws are fantastic for breaking down sheet goods, for long accurate cuts, etc but can't really compare to a tablesaw for the types of things mentioned here.I don't own a track saw (yet) but believe a solid table saw would generally perform much better than a track saw in almost every way. Repeatable cuts on both sheet goods and lumber. Miter cuts (with appropriate miter fence or sled). Anything requiring a dado. Tenons and other intricate joinery. Index cuts (another version of repeatable). Cutting lids off boxes. Chess and cutting boards. Cutting a circle in plywood. Just to name a few off top of my head. With that said track saw is definitely on my wish list but I think I would use it mostly on job sites. Flooring, counter tops, Cutting doors to length, possibly stair and deck work for example trimming deck boards to final length etc.
The rip is easy, just need the right lengths of track. The 90's can be done with either an overcut from the back or undercutting and finishing with a hand saw/jigsaw.Can't do that with a track saw.
A router base for the track and a router will cut the lap in one pass without trying to put a long board up on end thru a table saw.The rip is easy, just need the right lengths of track. The 90's can be done with either an overcut from the back or undercutting and finishing with a hand saw/jigsaw.
A track saw may not be the easiest or fastest in every situation but it can do an awful lot
Repeatable cuts, dados, rabbets, tenons, need I go on?What exactly, in a home shop, will a table saw do better than a track saw?
Table saws rip very well, but they are not so hot for crosscut, any. Yeah, you can use sleds if you must cross cut plywood accurately. Who wants to ?
12’ might be pushing it, but 6-8’? Not a problem for me as my 9’ foot outfeed table is also a MFT style table.For 6' to 12' long rips?
I love a track saw, but they work better in conjunction with a table saw than exclusively one or the other.
