strength_and_power
- Joined
- Apr 26, 2015
- Messages
- 1,470
Because the confuse the hell out of me. I’m in the process of replacing all the toggle wall switches with rockers. The electrician must have been getting paid by the switch, the master bed/bath has 10 switches alone.
The living room light is controlled by 3 switches. Replacing the switches one wire at a time and matching the new switch to the old has been working for me but I’d like to have a better understanding of the circuit as my eventual plan is to add Lutron Caseta switches so I can set schedules, control remotely etc. Their instructions seem pretty straightforward but one of the wires at each switch location needs to be connected to the same wire at the other switches. How do I determine what the common wire is?
The electrician must not have been getting paid to ground the switches because none of the switches I’ve encountered have been grounded. The grounds are tied together in the box so I’ve been adding a ground wire to each switch.
Thanks I’m advance
Scott
Thanks I’m advance
Scott
