After reading AnEv942's post, I did open up the box of spare parts and did find the board. There were no cut traces on it at all. I took a look at the specs for the relay and it appears to be a SPST relay with a pair of contacts that's shared BUT the PDF specs shows that there should be only 4 contacts, not 5 as it's shown on the board. If yours is working fine, I'm assuming that there's no difference since the trace between the two contacts are already connected through the relay. If it isn't, then the marking on the relay is incorrect and I'd like to know what the relay says on top.
Further thinking,... I think they have been using both relays and may have ran out of the other type of relay. If your relay is marked GP-24VDC-C54 or GP-24VDC-1C54, it was necessary to cut the trace. If your relay is marked GP-24VDC-A54 or GP-24VDC-1A54, then the trace does not have to be cut.
http://www.sinetong.com.sg/product/downloadPdf/80/GP-24VDC-1A54-16A.pdf
China did tell me not to operate the torch in the air for too long. I'm assuming that it would cause excessive wear on those contact points, which would make sense. If it was having excessive wear, the contacts could be filed flat and readjusted to the original gap. I didn't measure the one I have but it appears to be proper. I'll get pictures up in the next post along with the switch modification I made on my torch through my phone.
By the way, THANK YOU for the extra funds some of you have sent, I appreciate it!!!
