Vintage Combination Square
MShaw
York, Pa.
My father bought this Starrett combo square second hand in about 1948. Assuming it was purchased when a machinist retired and sold his tools it would put the original purchase prior to 1920. Anyone else have one to show?
Packard V8
Spokane, WA
Very nice, very useful tool.
FWIW, Starrett came out with the combination square in 1880 and still sells them today. I've got several from 6" to 24" and use them all the time.
jack vines
  • Like
Reactions: lmg
Dave455
Sussex, England
Nice!
Thankfully, a decent combination square then, is still a decent combination square now!
I still use my Grandfathers, which is certainly pre war!
Enjoy...
Tucko
Whittier, Ca
jack vines
Yep, me too. My best score was a 12" Starrett machinist square.
$1.00
Stuart in MN
Minneapolis
I have and use a Stanley try square I got from my Dad. I don't know where he acquired it but it has a patent date from the 1890s on it.
Looks like this one:
paulm12
NW Chicago 'burbs
Starrett no 12 protractor and center square. Not sure of age. Need to find a good rule to match.
MShaw
York, Pa.
Mine is a #12 also. It has a serial number, lot number or ? 291 stamped on it and is definitely pre 1920 if this helps date yours. If it would help I will try to get a better picture and, hopefully, some stock or other numbers from the rule that is with it..
altersaddle
Victoria, BC
I've got a Craftsman set, a Starrett set (that's seen better days) and a Union Rule co combination square.
The Craftsman set is a bit odd, the manufacturer code is D J (Mitutoyo) but it's also stamped Made in USA...!
The Starrett rule is stamped "L. S. S. Co".
MShaw
York, Pa.
The stamping is on the back edge of the "foot" under the level. The rule is noted as "hardened" and "No 4".
This is an old thread but I didn’t find a more appropriate one in doing a search. I found this Stanley #22 at a recent estate sale. I now only buy these squares if the scriber is included. The rule was a little rusty but evaporust worked its magic. This has two levels at right angles to one another, which I hadn’t seen before.
At the same sale that I found the square above I found the rusty treasure shown below. Even after evaporust the maker’s markings were illegible. I looked through some catalogs and found that a Union square was a close match. IMG_9083.jpegIMG_2964.jpegIMG_2963.jpegI went through some spare rules and found a Union marked one in good shape and replaced the rusty one. At least the square is now useable.IMG_2971.jpeg
  • Like
Reactions: Jr5
I've always thought of the Union's as having really Loopy Shapes, but your catalog listing doesn't show them. The older catalogs have both (yours earlier page)
Yeah, I have a drawer in my Kennedy roller of squares with some of both styles. It seems like the rules get switched around pretty often. Here is the listing that looks like mine in the ‘41 catalog you referenced. I’ll get some pictures of a variety of others from the drawer. IMG_9084.jpeg
More square pictures. There are no guarantees that the rules are correct to the squares but they probably are.
Stanley Handyman #1222 1/2IMG_3011.jpegIMG_3012.jpeg
WisJim
Menomonie, WI
Here are most of my combination squares. I have 3 versions of the Stanley No 21, and my Union looking square (lower left) is marked "Orange Tool Co., Orange, Mass.". I think that Union and Orange Tool Co were related but I don't think that we ever figured out exactly how back in Nov. 2023.Squares.jpg
Is the head, or the rule marked? If just the rule, those swap easy. Don’t remember that thread.
LesserSon
PA USA
I bought ten of these center heads today, in hopes of adding some of them to existing combination squares. Unfortunately, they don’t all have the screw&nuts.
So far, I’ve added a texture-finish one to a smooth-finish Starrett square, based on the shape of the nut and the double notch that allows the pin to reverse 180°. Neither of the crosshatch-textured ones fit on my Starrett rules. I suppose there may be a Goodell-Pratt or maybe a Millers Falls.
IS there a one-stop ID-er thread or online source?
You can buy them from Starrett, and PEC via HJE
It's possible they are for 9" or 6" rules. The four left most look smaller. 6" is just under 2.5' tips to tail, 12" is a touch over 3"
Somewhere I have the dimensions for the rules and slots, but right now probably easier to go out and measure. Back in a minute
4: 0.638 x 0.065
6" 0.715 x 0.080? (In theory the 6" should fit the 9", but it doesn't, the notch does not fit the tongue, or I'm really clumsy tonight)
9" 0.875 x 0.082
Zoro has the nuts too.
If you decide to sell, I may be interested in one to fit a 9", or 4" Gotta check my stash.
leg17
Kentucky
.....So far, I’ve added a texture-finish one to a smooth-finish Starrett square, based on the shape of the nut and the double notch that allows the pin to reverse 180°. .....
The smooth Starrett ones are forged and hardened.
More desirable than the textured ones which are cast iron.
(am I misunderstanding?)
I think that is correct. The only marked HARDENED ones I’ve seen were smooth, but I have several unmarked ones.
The marking is on the skinny face 90° from the bearing surface.
LesserSon
PA USA
I was vague. I should have described this one as crinkle-finish, not “textured,” which I had also used in conjunction with “crosshatch.” I just meant it is not shiny-smooth. IMG_1252.jpeg
LesserSon
PA USA
Looking among the different designs, there are a few points of comparison in addition to the shape of the openings.
1 brand stamp
2 awl grip (missing in this example)
3 transition to the 45° face
4 nut shape: short/long, knurl, single/divided grip, rounded, beveled, square
5 means of holding/reversing bolt
6 length parallel to rule
This one is unmarked, lacks a hump at the return to the 45°, has the same nut, but no external notches no bolt sleeve, and is shorter along the rule face.
Then this one is smooth, has differently shaped openings, a reduced hump at the return to the 45°, but has the brand on a raised oval on the side, includes the notches
Then, I notice there are nuts that look really similar to Starrett, but are shorter.
1 brand stamp
Nice job gathering all the points of difference. I've always used the checkering as a sure Starrett tell, and the shape of the nut.
I've never looked to see if my center heads have different nut size than the combo heads.
And catching the hump at the 45, well done, never even noticed.
Mine are in three different locations, will try to track this down later.
LesserSon
PA USA
Aside from the heads, the rules are interesting. The top three are essentially identical, but the bottom one has the model and logo shifted an inch to the left and mostly lower-case letters. I think it may be older than those at top.
AreBeeBee
Wisconsin
LesserSon — these are great examples. Do you know of a source where Starrett combo squares (and double squares) are age-dated according to finish and design? I have a clear sense that the "basketweave" design ones are ca. WW 1 up to some point in the 1930s. Then?
LesserSon
PA USA
IMG_1270.jpegAnd then the type without the logo symbol. Top one includes “Made in USA,” bottom one is really degraded (also bent, though it doesn’t show in this pic), but obviously different from those at top. The third from top is a No4R GRAD. Have to look that one up yet.
LesserSon
PA USA
No, I don’t know anything yet. I’m asking the same question at the bottom of post24.
LesserSon
PA USA
Here are the gradations
4R is 8th, 16th, 32nd, 64th inch.
4 has the same gradations. I wonder if the R indicates the “quick read” numerals between the inch marks.
There is mention in the catalog you posted of a “reverse” option, but I don’t see “R” explained.
Bob-B
Long Island, NY
Starrett also made scales in quick reading 32nds, 64ths, 50ths and 100ths. Those were 16R graduations and commonly used in the aircraft industry. I 1st saw them when I went to work at Fairchild Republic. Never saw them before in the machinery business..
