Vintage Craftsman Drill Press
Slowjoe
Port Clinton, Ohio
Hey! Last Sunday, I picked up this Craftsman DP. It has no model badge, but it is in GREAT shape. The original paint is all there with just a few scratches, and it needs a cleaning. The Vari-Slo appears to be intact. It also came with a milling vise, shown on the table and on the base after I moved it.)20240428_092830.jpg20240428_092844.jpg20240428_092846.jpg20240428_092849.jpg20240428_092853.jpg I think with some serious cleaning and a good lube, this unit will be ready.
FrankLee
seMI, 48317
WOW! So much greatness in that one. Very nice score, Joe!
The head is early to mid '50s. The model number would be 103.23131, if it was originally a bench-top, or 103.23141, if it was originally a floor standing model.
It looks like it's a hybrid machine. The base is not Craftsman and I can't see the table under the pan. I don't recognize that column collar near the base either.
What about the column? We discussed how the top of Craftsman columns were milled inside.
The hold-down clamped to the column above the table is a Craftsman accessory. Craftsman also sold those Furnas F/R switches.
Are the tilting vise and rotary table branded "Craftsman"? IIRC, they were both made by Palmgren.
WOW!
Slowjoe
Port Clinton, Ohio
Hi Jim. I haven't had the chance for a close inspection of the column or table. I'll get to that this weekend and let you know.
BTW, on those parts I got...
I disassembled the Jacob's chuck, and some of the teeth are broken off of the jaws. I think that tells me that somebody cranked really hard on the key when locking down on small bits (depending on the jaw, only the last 1 or 2 teeth are broken/missing). I don't recall for sure, but I think it's a 63A (or 633A?). Is the 64A the standard chuck for that machine? Do you by chance have replacement jaws, or a good chuck. This one has that safe lock feature, which I like.
Thanks.
Joe
FrankLee
seMI, 48317
Yes, please do.
That is a bummer. Cleaning that chuck was going to be my project last Friday. I would have discovered the broken teeth.
If the end teeth were broken off, more likely, someone pressed the sleeve on without extending the jaws. Typically, over-cranking the key will break the teeth on the sleeve.
The Jacobs 6A chuck was standard on 100s until 1951-ish
I believe that is a Jacobs 633C and was standard on the 100s and 150s from 1951-ish to 1966.
I think I have a set of jaws and a split nut. I'll check.
Thanks.
Joe
crguy
SW Washington
Those with the Vari Slo are neat! Don't force it when adjusting the speed as the castings aren't all that strong. I'd sell the rotary table to someone with a milling machine. That drill press isn't designed to be used for milling work.
Slowjoe
Port Clinton, Ohio
Yeah, my thoughts exactly. I wish I did have a Bridgeport, but since I don't, and probably never will, I'll sell it. Any idea of the worth? It, too, looks to be in excellent shape.
crguy
SW Washington
Look on Ebay to see what they have sold for. Palmgren is one of the makers of those.
Snip's
Congratz on the DP....
Lots of goodies on that one...
Is that a Welch 1100 Cam-Lock Drill Press Clamp?
Slowjoe
Port Clinton, Ohio
WOW!
Hi FrankLee. The rotary table is exactly like the one on my 103.23140 DP. It has the number 27213-103 cast into the underside. I'll check out the column tomorrow.
FrankLee
seMI, 48317
Nick Rivers
USA
I see two different rotary tables in the photos by looking at the crank handles. Those combined are worth more now than the drill press. I would not sell them.
Rotary tables are useful on a drill press for lining up precise drill locations using the X and Y axes.
gatewaysysop
Arizona
This. I have one like the model shown on the base. Mine is branded Craftsman, marked as made in Japan. Superbly made and I would not part with it. Once you've had one to line things up just right, you will wonder how you managed without, especially if like me you don't have a mill and have to make do with a drill press somehow.
Slowjoe
Port Clinton, Ohio
Thanks.
Joe
Hey there, Jim. I got some measurements of the column:
62" LOA column,
1 end is 2-95/128" OD and 2-53/128" ID
the other end is 2-95/128 OD and 2-29/64" ID.
FYI, the 103.23140 column is 65-7/8" LOA
2-97/128" (2-3/4") OD & 2-51/128" ID @ top
2-95/128" OD & 2-23/64" ID @ bottom
How do you clean the crud from inside of the columns?
Joe
FrankLee
seMI, 48317
62" LOA column,
Joe
Are any of those column IDs machined ~2" deep? If so, that is a K-S Craftsman column. I'm not aware of any other manufacturer who machined just the top ID.
The column height was reduced from 67" to 62" in the 1956 model year. I'm not sure what to conclude about the 23140 column height and the differences in the top and bottom OD and ID dimensions. The 65-7/8" height does not sound like mid-'40s to mid-'60s era Craftsman.
I just push a dry wadded-up rag through the column with a broom stick and don't worry about what's left.
Slowjoe
Port Clinton, Ohio
62" LOA column,
Joe
Hi. I got the package yesterday. Thank you.
What are the 10-32 x 3/4" screws for?
FrankLee
seMI, 48317
Those are 10-32?
I meant to include 8-32 x 3/4" for the spindle pulley retaining screws. The originals are always(?) damaged or broken on the 80 and 100 series drill presses that don't have the snap ring on the lower quill.
Do you think those chuck jaws will work?
Slowjoe
Port Clinton, Ohio
My mistake, they are 8-32. I should have taken them out of the bag to look at them.
The jaws look like they should work. I'll be rebuilding the chuck soon, so I'll let you know.
Slowjoe
Port Clinton, Ohio
Jim, in regards to the spindle collar, does the slight bevel install towards the quill or towards the spindle pulley?
Please look at the attached pics. I installed the following parts: (starting from the check end, going up)
Feed Stop Bracket
Quill Snap Ring
Quill Bumper O-Ring
At top of quill on spindle shaft:
Steel Washer
O-Ring
Spindle Collar
Does this look correct, and have I left anything out? Buying this DP in boxes and bags didn't give me much reference on how things go, and trying to merge Craftsman diagrams with hybrid parts is a bit confusing.
Thanks for your assistance. (And I may have more questions later!)
Joe
FrankLee
seMI, 48317
Feed Stop Bracket
Quill Snap Ring
Quill Bumper O-Ring
Steel Washer
O-Ring
Spindle Collar
Joe
Yes, your photos look correct.
Just be sure to tighten the cone of the set screw into the divot in the spindle. This will slightly compress the rubber washer and apply preload to the bearings.
Slowjoe
Port Clinton, Ohio
Thank you. I now have the quill/spindle assembly installed. Scratching my head on spindle pulley...I see where the small snap ring registers into the groove below the pulley bearing. Where does the large snap ring register?
FrankLee
seMI, 48317
The outer snap ring gets installed in the head casting. The outer race of the lower bearing rests on the snap ring.
You don't have to remove the quill/spindle assembly to install the snap ring. Just lower the quill to get the spindle out of the way. I forgot to install that snap ring on multiple occasions.
Slowjoe
Port Clinton, Ohio
Ok, thanks. Now I have to figure out how to get that ring into the head casting. I don't have that long snap ring tool like you showed me.
FrankLee
seMI, 48317
Needle nose pliers work just fine. I believe I filed the hook of that snap ring so needle nose pliers gripped better. Photos added above.
IIRC, those long external snap ring pliers I showed you were for the inner snap ring on the pulley.
Slowjoe
Port Clinton, Ohio
Oh, ok. I pulled the spindle/quill out again, and I see a groove inside the casting where it registers. I assume I can install it before installing the spindle/quill? Then install the spindle pulley/sleeve/bearing assembly last?
Slowjoe
Port Clinton, Ohio
Am I correct in placing the bearing right up
against the sleeve? i.e., the sleeve is a spacer to place the bearing in the right location on the pulley shaft?
FrankLee
seMI, 48317
Ok, good.
I assemble the head on my work bench with the head resting on it's back motor mount side.
Below is the order in which I assemble the head. All sub-assemblies are first assembled independently.
  1. install the quill/spindle assembly
  2. install the pinion/spring/hub assembly
  3. install the spindle pulley
    The spindle aids in keeping the bearings aligned which make installation easy.
    Confirm that the spindle pulley is fully seated onto the outer snap ring.
  4. install the feed stop assembly
  5. install the chuck
  6. install the feed handles, head trim, badge
FrankLee
seMI, 48317
Yes.
install and fully seat the upper bearing onto the pulley shaft
install the bearing spacer
install and fully seat the lower bearing against the spacer
install the inner snap ring
