Vise Info Thread
Google:
In Tsarist Russia, manufacturing primarily utilized a system of measurement based on Russian ell, the arshin, which was standardized to 28 English inches (71.12 cm). Other units, like the pyad\' (hand span) and the vershok (thumb width), were also used. The metric system was introduced in 1899 but wasn't fully adopted until after the 1917 Bolshevik Revolution.
four.cycle: That wrench certainly looks Imperial.
it is. 7/16" x 1/2"
that was a fun one to identify. an ebay seller in Ukraine helped me with that one:
Y.T.C.M / (as it appears on the wrench) Ukranian Trust of Agricultural Engineering, Odessa, Ukraine / marked "3OP" (ZOR) "Plant of the October Revolution" / marked "Odessa" on reverse (in Cyrillic) / Johannes Gen plant operated independently until 1917 /
... and that chart is a bit whacky: a fathom is six feet.
IN
American Scale #2 2-3/4 jaws and weights 10lbs.
Hey Kmscott I just recently got one of these and was curious if you know what the main screw sizes are on this vise? Id really appreciate any info on it as I’m missing the entire handle and screw for it
KMScott
Can’t help you. If you have the nut then you can figure out what size the spindle thread you have and calculate the length with your Dynamic slide. I did not own the small American Scale vise like yours.
CRSINMICH
Southeastern Michigan
MORGAN JUNIOR Bench Vise
Morgan Vise Company
Jaw width: 3"
Opens to 4"
Weight: 12 lbs.
There is not much (if any) information about this vise.
There are references to Morgan Junior vises but they are Woodworking vises*
BONUS: Specs for Morgan Junior WW vise
*It could be "junior" referred to the woodworkers not the vises.
KMScott
Athol #77. 2” jaws. Looks like a home made stand for the swivel vise that releases from under a bench.
KMScott
Hollands #80. 4-1/2” jaws that opens 9” and weights 56lbs. Coachmakers vise.
CRSINMICH
FWIW -
One of the vises on the Hollands catalog page was identified as
Hough's Extra Heavy Combination Pipe Vise
Robert Hough had an 1898 patent for a pipe-vise which was assigned to Hollands.
It's not the one pictured in the catalog though.
KMScott
Craftsman 5247. 2-1/2” Clampon that opens to 2-1/4 and weights 3-5/8 lbs
Interesting - That Vacu-Vise base was copied, first by Japan, and later Taiwan/Asian companies a lot. possibly the whole vise, but the ones I usually see have a double swivel head like the magic Asian bench vises,
twagler
Ottawa, Canada
Interesting -0 that Vacu-Vise base was copied, first by Japan, and later Taiwan/Asian companies a lot. possibly the whole vise, but the ones I usually see have a double swivel head like the magic Asian bench vises,
I actually purchased one of those small double swivel head magic Asian vacuum base mini-vises a while back. It happens to be an unbranded version, but commonly seen branded versions include Oxwall, JSB (James S. Baker Imports) and believe it or not, Wilton even sold a version of these vises, the Model 525 (see pictures below).
Here's the Wilton version:
And here is an Oxwall, JSB, and my unbranded version, respectively. For a mini-vise, they are actually quite respectable, with decent casting quality and machining.
That's the one - I have two of them, mostly for nostalgia's sake - One has no marks, the other has Taiwan cast in the base;
I got one "back in the day", as a gift one Christmas, that I used for model making. Probably in the 6th or 7th grade or so? I busted it over tightening it - the main screw nut busted the threaded part out of the plate.
