Vise Info Thread
KMScott
Sawyer 602-1/2. 2-1/2" jaws opens to 2-3/4 and weights 28lbs. That latest Nutyp model came out in 1930 as International Nutyp Corp, then finished out as Sawyer Tool from about 1942 - 1950, give or take.
Fierljeppen
Sawyer 602-1/2. 2-1/2" jaws opens to 2-3/4 and weights 28lbs. Worth repeating from Fierljeppen... "That latest Nutyp model came out in 1929 as Oswego Tool, changed to Nutyp International in 1930, then finished out as Sawyer Tool from about 1942 - 1950, give or take."
KMScott...I need to amend my comments slightly, as I misinterpreted some of my data.
The latest Nutyp vise model started advertising in Oct of 1930 as International Nutyp Corp., not in 1929 as Oswego Tool Co. The new change was the addition of the 3rd jaw and can be seen in the attached scans. This model continued with Sawyer Tool, which eventually changed from the swivel-locking wrench to the swivel-locking spindle style.
Long-story-short...I've been acquiring some printed and referenceable Nutyp vise material that I'll be adding to the already significant information provided by PghJKB and Bluebolt. I'm currently pursuing some Google locked directory information that I need to create a time-line of the handover from International Tool Corp. to Sawyer Tool (Sawyer Foundry & Machine Works) and beyond. I'm pretty happy with the Oswego Tool Co. information I've recently acquired.
Sorry about the misinformation. Hopefully we'll be able to continue to solve more and more of the mysteries surrounding this very interesting vise.
KMScott
Trojan 702. 3" jaws that opens to 4-1/2" and weights 24-1/2lbs. Built by Chas Parker.
KMScott
Athol #113. 3" jaws and weights 28lbs.
KMScott
Oswego NuTYP 601-3/4. 1-3/4 Jaws that opens to 1-3/4 and weights 6lbs.
Owned by Joe
AngryBeaver
Lake Milton Ohio
Yost has removed this model from its website. not sure if it has been discontinued or not. database needs this one added.
Yost 503. 4-1/2" jaws. opens 9". weighs 66 lbs per Yost's data sheet. 5-1/2 tall throat depth and removable hardened steel smooth jaws for sheet metal work. looking forward to getting this on the new fab table.
KMScott
Rock Island 156. 4-1/2" jaws that opens to 10".
KMScott
Athol # 730. Swivel base, Swivel Jaw and Ratcheting Handle all in one. This 4" swivel jaw vise opens to 8" and weights 50lbs. Athol does things right, check out the swivel jaw pin.
KMScott
Columbian 1004 Hydraulic Swivel base Vise. Will try to get more spec:s.
KMScott
Fulton # 20. 4" Jaws. No other info available.
KMScott
Charles Parker # 383. 3" Swivel Jaw.
KMScott
Charles Parker Vise Stand. Quote from Joe. "Ok, the top part of that stand was made by Charles Parker, the base was made by JJ Adams in Worcester MA late 1800."
KMScott
American Scale 61C. 3" jaws that opens to 5 inches and weights 35lbs.
KMScott
Athol 724. 4" jaws that opens to 6". 700 series have Ratcheting handles.
MayerMR
Dallas, Texas
Thanks Mayer, maybe when you have a chance could you mention the max opening.
Kevin,
Max jaw opening is 5.5", measured when the vise was on its last couple of threads before coming loose from the main nut - or otherwise, the farthest out that I would be comfortable actually placing a workpiece in.
F
FMC1959
Montreal, Canada / Upstate NY
Kevin,
Max jaw opening is 5.5", measured when the vise was on its last couple of threads before coming loose from the tmain nut - or otherwise, the farthest out that I would be comfortable actually placing a workpiece in.
Kevin has mentioned this in the past, and I believe this is how manufacturers also calculate max opening; close the vise completely and then measure how much slide there is sticking out; this is the max [safe] opening.
MayerMR
Dallas, Texas
If that's the case, then the max opening is 4"
KMScott
Rock Island 950. No Spec:s to list. Do not let the swivel base fool you. It is from a Reed 204 and fits the Rock Island. Might say a little about vise company's buying bases from another vendor.
KMScott
Hollands 56H. 6" jaws that opens to 8" and weights 200lbs.
KMScott
Charles Parker 482-1/2. I will add spec:s when I get them.
KMScott
Prentiss #50. 3-1/4 jaws that opens to 4" and weights 22lbs.
KMScott
Rock Island 113. 3-1/2" jaws. Vise weights 33lbs. This model of vise has a Automatic Swivel. Locks when you clamp. This vise has been repaired.
KMScott
Yost 31C. 3-1/2" jaws that opens to 3" and weights 40lbs.
