Vise Info Thread
KMScott
Athol 113-1/2 3-1/2" jaws, opens to 6" and weights ?
KMScott
Hollands 27H 7" Jaws. weights 225lbs and opens to 16 inches.
454ragtop
Carver, MA
Athol No 1, 1-9/16" wide jaws, opens to 2", has the quick set nut and screw, has a stop on the screw. This appears to be different from the No 1 Kevin posted back on page 5.
KMScott
454, thanks for posting your vise. I have a #1 too with the Nov 14 1871 Pat date with the quick set Dynamic but my jaws are 1-7/16 wide. maybe I will mark them with 1-1/2 jaw width.
I made a mistake when posting the first # 1, when ever you see a screw under the Static support then that means the 1/2 nut is bolted in place. The one I posted earlier is a quick release to. Note how the text is different on the one listed. I believe ours are older.
454ragtop
Carver, MA
Strange, the seller of mine listed it as 1-5/8" jaws, I measured to keep the info here as accurate as possible, definitely 1-9/16". Makes you wonder how many different No. 1 vises they made, especially when you add in your earlier 1" model.
LOL. looks like we were typing at the same time, guess we can skip the 1".
KMScott
American Scale 211, 4" Jaws, Opens to 7" and weights 40lbs.
KMScott
Prentiss # 26 Swivel Jaw Coachman Vise. 4-1/2" cast Jaws. Weights 67 lbs and opens a safe 10"
KMScott
Prentiss 154 Open screw Clamp-on with a altered handle. 2" Jaws and opens to 2"
KMScott
Prentiss 264-1/2 4-1/2" Jaws weights 66lbs and opens to 6-1/2" restored this one my self.
TinkTinkForge
Louisville Kentucky
Reed no. 202 , no. 102 and a no. 102 1/2. If I remember right the 202 is 15 pounds. e22b362b5ea7902747ee6a112e53a458.jpg9cc9d3842cdcc9aa16045bf6d0d7f446.jpgeb71ebffb6ed618754fdf0e6ef680cbd.jpg
TinkTinkForge
Louisville Kentucky
Erie no. 102 2” jaws. Athol no. 70 2” jaws. Quick release a1c7cde46e3a60e43c0772f8746a7435.jpg8ad515cb48e774e7d73c56152b424473.jpg
KMScott
Thanks Tink, recorded, adding the weight and measuring the square slider from the backside of the Static to the end is a safe max opening dimension if you have time. Appreciate your help.
KMScott
Prentiss 182 Combo Vise. 4-1/4 Jaws, 76 lbs and opens 5" max.
trijeff
Northern Cali
Prentiss 98. 322 pounds, 8-1/2" jaws, 15-1/2" height, 31" length, opens 11-1/4".
9fae1bc5f7665ff4f387df8d3dd49c89.jpg17d84df5a0498f9497f2135435db9d23.jpg441a78d28f3953455f0aad6b22a9270e.jpg5a38956c94aec3c5dfd7c7d1a0b45ce0.jpg
KMScott
Prentiss 802, clamp-on with 2" jaws that open to 3-1/2"
KMScott
Oswego 23-1/2. 3-1/2 Jaws Weights 34 lbs and opens up to 5".
KMScott
Prentiss # 624 Open screw with 3-7/8 jaws that open up to 6" and weights 26lbs
KMScott
Prentiss # 56. 6" Jaws and heavy at 135lbs and opens to 10".
KMScott
Prentiss # 62 open screw vise. 3-5/8 jaws weights 18lbs and opens to 4".
KMScott
Prentiss # 159 open screw vise. 2" jaws that opens up to 2" and weights 3lbs.
KMScott
Prentiss 511/521 with 2-1/2" jaws that open up to 4" and weights 13lbs.
KMScott
Hollands E 3-1/2. 3-1/2" jaws and opens to 4-1/4"
KMScott
Hollands 13-1/2. 4" Jaws and opens to 5" Need weight.
KMScott
Dunlap 5230. 3-1/2" jaws that opens to 4-1/2" Weights 17lbs. Missing the Metal Former pins and Dies.
Quote from A GJ Member. Thanks for the info.
The Dunlap 5230 vise was part of the Sears Dunlap Metal Forming Tool No. 9-05230. It was the Sears version of the Swayne Robinson Metl Former.
The MetlFormer used multiple variations of the vise. The final one had a hole in the anvil to fit a drill press attachment - total of seven holes, here and there.
The real mystery is who made the Metl Former and 5230 and Dunlap 5344 vises - Swayne Robinson or someone else?
KMScott
Parker 574C. Cast in Hard jaws that are 4" wide and opens to ?. Weights 44lbs. Filers Vise
BMR24
Rocky Mountains Colorado
I'm not positive, but the maker of that last vise might've commonly known of as ridgid rather than ridge. All of my pipe wrenches that were made by the ridge tool company say ridgid on them.
tool_scrounge
Southern California
Dunlap 5230. 3-1/2" jaws that opens to 4-1/2" Weights 17lbs. Might have been altered by adding two tapped holes and one precision hole in the Dynamic.
Looks like a Swayne Robinson Metl-Former vise from the 1950's minus the forming attachments. The vise looks the same but they usually had 6 holes (3 on each jaw). But they had at least two variations I have seen in print so there may have been more. Below are some photos I saw on Worthpoint.
KMScott
Empire # 25 (Erie Tool Works) Vise. 2-3/4 Jaws opens to 3-1/2 and weights 11-1/2lbs.
KMScott
Tool, that is what I thought after posting that vise and we can only assume. I will be keeping my eye out on another Dunlap 5230 and see if they had the hardware like your collection. Very nice vise you have, you did not mention the model number of yours. Thanks for the note.
I just noticed that this Metal Former has the same model number as the Dunlap 5230. This Swayne, Robinson & Co. vise sure looks like the Dunlaps, sure there is a connection there.
KMScott
Prentiss 256/266 Says old model 518 which is a swivel base model. 6" jaws that open to over 9". Weights 125lbs.
KMScott
Prentiss 183 with 6" jaws that open to 6", Weights 185lbs and has the side open channel. God awful blue paint job on this one.
KMScott
Reed 109, 9" jaws, these were custom made. 9" jaws opens to 13". Vise weights over 290lbs.
KMScott
Reed 314 Swivel Jaw Coachmakers Vise? 4" jaws opens to 8" and weights 48lbs. This one has serrated jaws so is that a Coachmakers vise Filers vise or just a machinist vise.
