IIR the third patent in that era is for the steel rods in the slide.
Maybe this and the comparison with the original.IIR the third patent in that era is for the steel rods in the slide.
You bet Outlaw. Thanks.Very impressive shop made vise!
I have a small shop made vise Dr Scott, do you want pics/specs? Its pretty nice...
One of your homemade vises is in the Spreadsheet under Custom Fab Vises Already.
Any details you can share on the wear point mods you did for the dynamic slide? I have a vise that could use something similar.I have another mystery vise with a horn. No markings from the builder. Has anyone seen one like it? 4" jaws that opens to 5-1/2" and weights 60lbs.
Added new jaws, built a new meatball and Silver Soldered it to a newer spindle. Made a handle and new lockdown. Tightened the nut and welded some wear points underneath the Dynamic slide area. Works like a new vise.
Bryson, using TIG on AC I welded up the wore areas with Silicon Bronze. Bought the rod on e-bay. Milled close and hand worked the rest with a sharp file.Any details you can share on the wear point mods you did for the dynamic slide? I have a vise that could use something similar.
Massey # 136. 6" jaws, no other spec:s.
Wow look at that air operated Yost Double Swivel-er. Super rare. Gonna be looking out for that one. I use the Yost G Double Swivel-er in my vise shed. Love it.KMS: The specs for Yost Toolmakers' Universal Double Swivel Vises models D through I are in this 1955 catalog cut and are already in the Vise Spreadsheet. Model J was the "Air Operated version. Jaw width - 4", Jaw opens - 6", Weight - 90 lbs. approximately. I don't have a date for its catalog cut.
Outlawmws that vise is probably German, I had a very similar one but there was a 4 in the diamond instead of a 3. It had a decal that if I remember correctly had GMB or GMBH on it.n
