Visual Feeder Size Determination.
sberry
Brethren, Michigan
All the tools don't add to load, a few lights and any additional heat. Often in general load if using your air comp you are not running a microwave and the oven, you are far from overloading a 200. I seen the bar with 5 fryers and AC running on 200 hot, barely hold your hand on the panel. Your hot tub is somewhat like a welder, it could come on along water heater but you got to work here to run over 80A, yo really do, maybe spikes of 100but you would have to be on all out assault and it probably wouldn't trip the breaker.
I got 3 times as much stuff and it doesn't warm a 200, be a rare day to see 100 and the only real exception to it is motor starting with existing loads etc.
As a common home type if this panel isn't sizzling hot to the touch you are ok. Even in this house, never feel it warm. You don't need to feel insecure.
sberry
Brethren, Michigan
I was in a bar, 4 50A appliance circuits, about 30 run AC, another 30 or more cooler, lights for 3K on 200. I had them paint the outer wall white finally for hot evening sun.
sberry
Brethren, Michigan
I have seen some old fuse 60A overloaded with appliances bootlegged on and a microwave tipping the hat. Even though the match kind of seems small in the universal scale there is a huge leap from 60 to 100. I know a couple,,, maybe 3 or 4 businesses that run from 60 sub thru a 100 wire and a couple welding/machine shops from 100
I was confused by this because my equipment label says 26 amp but the installation instructions say use a 30 amp 2 pole breaker.
Could be that the continous load is under 20a(sized @ 125%) and non continous is the rest thus requiring a 30a circuit...
