GeorgiaHybrid
Well,
My buddy asked for his vent cap back (mine broke off) and the jack was starting to leak down so a PM was sent to Hiball for a Walker 93632 kit and vent cap. It came in yesterday (thanks Steve...) so I thought this would be a good Saturday morning project.
I don't know if you guys would be interested or not but thought I would add this in case anyone else wanted to know how this series of Walker jack comes apart.
The jack....
Implements of destruction and partially disassembled. All you need to do on this jack to get the bottle out is remove the 4 side bolts and then loosen the nuts on each side of the lift arm pivot.
Bottle jack free of the frame and the fun can start.
Pump assembly removed from the jack and partially disassembled as well as the release assembly.
Disassembled pump assembly.
Completely torn apart pump assembly. Just take your time when driving the retaining pin out and everything should go fine.
Next up was the ram but I did not have a homemade socket for this particular tank nut. I usually make one from schedule 80 or 120 pipe, a piece of plate and a nut welded to it but this time I decided to cheat. The local bargain tool store had some VERY cheap Chinese Budd sockets on sale so what the hell... 15 minutes with a cutoff wheel, a little file work to make it fit and a little bit of impacting with the MG725 and presto.
Tank nut loose in 5 seconds.....
Main ram and reservoir pulled.
Easy to spot the problem with this one. The main seal is ripped from the center section along half of its diameter.
Almost forgot the release valve. It should have been removed when I pulled the release assembly out. It's tough getting old and forgetting things...
Next up are the pressure and safety valves under these expansion plugs. I just center punch them and then pop them out.
Here they are removed and ready to start with the valves. The valve on the left is the safety valve and the one on the right is the pressure/suction valve.
First up is the safety valve. NOTE !!!!! make sure you look at the location the screw is at and then TIGHTEN and count the total amount of turns until it bottoms out. This way you can get the jack back to where it was (+/-). In this case 1 1/2 turns was the magic number. The valve is to the left, next is the spring and cup and then the adjustment screw.
Next up is the pressure and suction valve. This screw will take a LOT to break it loose. Get your big screwdrivers out with a bolster and wrench. You WILL need them. From left to right we have the suction valve, suction spacer, discharge valve, discharge spacer, gasket and high pressure plug.
Just for grins, I removed the gallery plug that is located under one of the side bolts holding the pump in the jack frame. I just like to make sure that everything is nice and clean before starting to put it back together.
One thing that you will need on most of these rebuilds is a GOOD set of mini picks. The best that I have found so far are these little Snap-on ones but make sure yours are tough and sharp.
That's it for a complete teardown of the jack. Now I just need to find the time this weekend to clean it all up and re-assemble the little ******. If you guys want me to take photos on putting Humpty Dumpty back together again, just let me know.
The jack....
