emeraldcoupe
i've had a vulcan migmax 215 since 2018 when they were only $650, but i know they've gone up since then. i haven't had one issue with it, it's been a fantastic machine.
Dang dude, did a bodyman steal your first wife or something?NOT BODY WORK
Is the ancient Miller a Millermatic 200?I am hoping to acquire an ancient Miller to fix and resell. It is a 220 only and is much much to big for my use but I have quite a bit of practice with that machine and really like it. Just going to be too big and won't have it soon enough.
I wouldn’t consider the digital readout a mandatory option, but having dials (unlimited adjustment) vs. knobs/switches is the only way to go.Honestly I cannot remember. Doesn't look like that though
They also use the same gun!no, they do not come off the same line, the only thing in common is, they are both owned by the same parent company, but they are very good machines. i love my iron man
no you need the floating ball type flow meter in addition.That's not the regulator with gauges?
It looks like all he'll need is a cylinder.
@shakenfake this is mostly for automotive welding right?
Example being this Hobart, it has “knobs” or switches for the settings. Only allows you so much adjustment.@pancholasvegas What would you consider dial vs knobs/switches. In my mind those are almost the same...
They can work fine. But a floating ball flowmeter is a better option as it displays actual flow instead of what the flow should be at a given pressure with a given amount of restriction.no you need the floating ball type flow meter in addition.
i had the same machine with those gauges, it doesn't work.
Infinite adjustment can make a guy chase his tail if he isn't good at understanding what they do. If you aren't doing aerospace, there's a bit of leeway in what settings can be used, thus each range is just fine for most people.Example being this Hobart, it has “knobs” or switches for the settings. Only allows you so much adjustment.
true flux core only machines are bottom of the line, they tend to be junk. The ones at HF are really bad.Agreed. That's why I bought one of those, too.
Flux-Core is what everyone that is purchasing their first machine wants, because it's the cheapest and least "Intimidating," set-up available. IE; No need for a bottle, just get straight home from the big-box store and start making a mess. This, in turn, leads to frustration, because shielding gas makes a big difference, especially starting off. There's a reason you see Craigslist, FBMP, filled with Flux-Core machines.
Yep, Cleveland, Ohio. ITW owns both Miller and Hobart. I think Hobart is the lowest cost of the three US names in the game…@gearhead1 That Lincoln is also USA made. In this day and age almost everything has at least some foreign components.
Nice shape for a ~40 yr old machine
Thanks!Nice shape for a ~40 yr old machine
I can't say for certain one way or the other but I think the odds are against that Lincoln being made in the USA. I say this as someone with two Lincoln machines, and I don't mean to suggest it should sway your decision one way or the other, but I think the days when you could assume a Lincoln is made in the US are over. Grainger lists country of origin as Mexico for what it's worth. I think that's where my 210MP was made.@gearhead1 That Lincoln is also USA made. In this day and age almost everything has at least some foreign components.
No kidding! That's refreshing.@GeoBruin I called and asked. They said country of origin was USA.
It saves a tremendous amount of time. That way you can use a parameter chart instead of guessing.Is it really that much better? I've only welded without it.
If the case is digital readout vs non then the only option I see is PrimeWeld for the money.
I was looking at the entry level Lincoln’s of that size last month, and Mexico rings a bell. Not that it matters to me, though.I can't say for certain one way or the other but I think the odds are against that Lincoln being made in the USA. I say this as someone with two Lincoln machines, and I don't mean to suggest it should sway your decision one way or the other, but I think the days when you could assume a Lincoln is made in the US are over. Grainger lists country of origin as Mexico for what it's worth. I think that's where my 210MP was made.
The reason I asked if it was a MM200 is they are a tank, most will outlive their owners and well worth repairing. They are actually in the 250 amp class but still handle .023” wire well.@oldmachinenut It is a Deltaweld 450. Much larger than yours lol
I know for a fact they are….. When I bought my Ironman last year, nowhere in the documentation could I find what liner came in the gun. So I called the 888 tech support (which happenEd to be the same number for Miller and Hobart). Guy said he didn’t know, hang on and he’d look on the shop floor at machines in process. None were there so he went in the engineering lab and was chit chatting on the phone with me while he was doing this. He said the Ironman 240 was basically a 252 without the digital readouts.
