clutch47
Have you considered stick?
With the proper amperage and rod, they truly can't be beat AND no bottle to screw with.
Flux core would the happy compromise between stick and MIG, since he's already looking for a MIG machine. Certainly nothing wrong with flux core if you steer clear of the cheap 120V machines.Have you considered stick?
I've never seen anyone weld exhaust manifold bolts out with stick.Have you considered stick?
I did last week. Nissan Pathfinder 4.0L. I curved a 3/32" 6011 electrode, turned it up high on AC, went through the wheel well, and was able to weld a nut on. Wire feed might have been doable, but way more awkward and clumsier. Titanium 225 stick welder has been great for 4 years now.I've never seen anyone weld exhaust manifold bolts out with stick.
I have zero stick experience either so that would be a pretty good learning curve, maybe not though.
Your statement is true but here's how I've always seen this. For metal fabrication of 1/4" or greater stick is superior to an underpowered MIG 7 days a week. If you've got a 240V 200 Amp MIG machine that erases this advantage especially if you use dual shield wire which is the best for thick metal fabrication. I use my TIG for stick but my Primeweld 180 and HTP Propulse MIGs have the zip to do the thicker stuff so I don't often need to use stick. But I do like stick for anything done outside where your shielding gas coverage will be a problem. For outside repairs and welding on trailers it can't be beat. The Primeweld 180 comes with stick as part of the package. For the money it's the best machine in the world.I've never seen anyone weld exhaust manifold bolts out with stick.
With the right setup, a simple arc welder can be used as a tig.For home or hobby use as a first and only welder, stick just isn't a good recommendation in the 21st century IMO. Most people are going to be welding thin metal 99% of the time unless they're working on heavy equipment. I have a 240V Lincoln MIG and an ancient inherited Miller stick welder. I don't have a farm and don't work on heavy equipment; I've never needed to use the Miller. The last time I used it was 20 years ago just for fun.
My first MIG was only 100 or 125 amps something like that, so I used that for thin stuff and kept my stick welder for thick stuff. Not a bad plan especially if you already had a stick welder.With the right setup, a simple arc welder can be used as a tig.
My Lincoln tombstone has worked well on 18ga sheet steel that way.
While I agree that for a beginner to just make things stick together, a wire feed welder with Flux core wire can do a decent job.... when you want to fix your own trailer hitch or do something heavy, my choice is stick.
I don't care what the manufacturer says, you will never get enough power out of a 120V outlet, even wired for 20A, to get that kind of power.I got an inverter stick welder 6 months ago and it's a game changer. Sooo portable. Will run on 120v up to 120A, ...
That's 120 Amps of welding output (whatever the voltage is, usually like 16 to 25 volts DC). Amps at the electrode.I don't care what the manufacturer says, you will never get enough power out of a 120V outlet, even wired for 20A, to get that kind of power.
Yes, I understand that !That's 120 Amps of welding output (whatever the voltage is, usually like 16 to 25 volts DC). Amps at the electrode.
My old Campbell hausfeld had a 20A plug on it.Yes, I understand that !
16VDC @ 120A is 1,920 watts. The 120VAC input to the welder would have to greater than 16A.
Why are we limiting to 16 amps? A 20A breaker will hold 25 for a couple minutes probably. A lot of welding is intermittent so it works.Yes, I understand that !
The 16A number ASSUMES 100% efficiency in the machine. Not possible.Why are we limiting to 16 amps? A 20A breaker will hold 25 for a couple minutes probably. A lot of welding is intermittent so it works.
Glad it is working for you ! I just would not recommend that for most people.It claims max current is 24A on 120v, I haven't checked. 1/8" 6011's run good at 100A can do a lot of welding before you trip the breaker. I weld a lot of brackets and supports this way on jobs. Lots of 1-1 1/2 beads. Hardly ever trip a breaker doing this type of work.
Very unusual. Even more unusual is to find a 120VAC 20A receptacle !My old Campbell hausfeld had a 20A plug on it.![]()
Usually wear a glove on my left hand but cannot get used to a glove on my right hand unless using a cutting torch. Even then I'll only wear a glove if doing alt of cutting. The bright side is I have no hair on my hand or arm.@Joemctag I do not always weld in the shop. I have had quite a few instances I need to help a friend weld or do something somewhere else in the world. I have used flux core many times and although it is a bit messier I did not mind it on the Vulcan I was using. I also weld outdoors sometimes. I have never tried stick welding and feel as if I would be terrible at it. I think I made an attempt once and just blew through what I was doing.
@driftpin Yeah my experience with the Vulcan has been good so far. I do not wear a glove on my right hand (hand holding the gun) but most of the time I will wear a glove on my left hand. Yes I have been burned but it is just more comfortable that way.
@jonesg I agree with you on the screens.
It looks like everyone is almost about equal in terms of what they recommend. Seems like Hobart, Primeweld and the Vulcan are the top three choices with about an even spread. I like the fact that Hobart and Vulcan are sold in a real store. I like the fact that Hobart is made in USA and seems to be the hobbyist Miller. The Primeweld price point is unbeatable though. Primeweld and Hobart both have a 3 year warranty (doubt I will need it) compared to Vulcan's measly 90 days. Primeweld's support team sounds awesome though, have yet to hear anything about Hobarts.
Based on what I wrote above I think I have narrowed it down to Hobart or Primeweld. I think if I was going to spend the money I might as well shell out a couple hundred and get a Hobart over the Vulcan. Ah decisions decisions...
No it isn't. Code requiring derating by 20% for constant loads, which a welder is not. You can use the full 20a. and then some, depending on how long it runs for.Because that is code for load on a 20A breaker. I get it might not always be applicable, but it's still good practice.
Only for continuous loads.Because that is code for load on a 20A breaker. I get it might not always be applicable, but it's still good practice.
I noticed all the receptacles in my hotel room this week were 20A. I don't think they are that rare.Very unusual. Even. more unusual is to find a 120VAC 20A receptacle !
dont even come out of the same factory. just owned by the same parent companyI am a Hobart fan, as I understand them they come off the same line as a Miller, but are
Marketed at a lower price point.
I guess I have been mistaken about that. I was under the impression they had some interchangeable parts, not all but some.dont even come out of the same factory. just owned by the same parent company
They can have interchangeable parts and still be made in different factories. Multiple production lines for the same product are very commonI guess I have been mistaken about that. I was under the impression they had some interchangeable parts, not all but some.
My garage is packed with them!Very unusual. Even more unusual is to find a 120VAC 20A receptacle !
You’re wrong.I don't care what the manufacturer says, you will never get enough power out of a 120V outlet, even wired for 20A, to get that kind of power.
Must be short duty cycle.You’re wrong.
I routinely run my Miller Maxstar inverter welder in 120v 20 amp input and can easily go over 120 amps of TIG output. Done it hundreds of times
Very unusual unless the house was built to your specs.House was built in ‘04 and all the receptacle circuits inside are 12 ga on 20 amp breakers (15 amp outlets though)
Why can’t you accept that you’re wrong?Must be short duty cycle.
Its not newWhy can’t you accept that you’re wrong?
Look at it from the flip side. I am trying to understand WHY I AM WRONG !Why can’t you accept that you’re wrong?
My first house was built in 1976, and the Garage had a 20 amp breaker. Only one outlet, but it was a 20 amp circuit.Very unusual unless the house was built to your specs.
Electrical devices have come a long way in 50 years. It seems like I’m so many of these posts you’re still stuck in the 1960s.Look at it from the flip side. I am trying to understand WHY I AM WRONG !
50 years ago, I worked at Sears and sold air compressors. The 1 HP model was supposed to run on 120VAC @ 15A. Many got returned because the starting current exceed the capacity of the 15A circuit.
I applaud all of you with the foresight to install 12 AWG/20A circuits in your shop/garage !
Do some homework. Look up trip curves for a 20A breaker. Look up the input current for various welders. This information is all easily found on the webLook at it from the flip side. I am trying to understand WHY I AM WRONG !
