welding table build round up
bdbecker
Iowa
Here's mine - made out of scrap channel. I've since added additional cross beams and plate along the bottom, as well as a couple of hitch receiver mounts for my vise and bench grinder.
View media item 66764
I also welded some channel pieces to HF c-clamps so I can tighten the clamps from the top instead of having to reach underneath. (I know you're not supposed to weld cast iron to steel using ER70S-6 wire, but in this case its not really a safety issue if the weld fails, only a minor inconvenience).
View media item 87961
desmato
Mid Michigan
Pic of it finished, somewhat
LXCam
Looks great mato. What are all the bottom bolts about in the second picture, mounting studs?
sqznby
Coastal NC
Nice table desmato. What's the dimension of the top?
LX, looks like the bolts may sit inside the plates welded to the frame. They have holes drilled in them through the tubing. The weight of the table top holds it in place. Kind of clever that way you don't put any heat into the top from welding it to the frame. I think haha.
LXCam
You're right. Yesterday I couldn't see they were counter sunk into the top in the first picture. Boy that took some time to do. :beer:
fordkid88
I just have a video at the the moment. The drill has been replaced with a garage door opener motor. I have to figure out the limit switches. Down will be simple up not so much.
