gtmorgan89
- Joined
- Feb 2, 2011
- Messages
- 99
I've been looking at buffers and reviews online for a week or two. Im going to purchase one soon. What are you guys using, or what would you recommend?
Porter-Cable 7424 is the go-to DA for detailers on a lot of the car forums I'm on.
wups, that was vague. Im looking for a dual action orbital buffer for car finishes.
A DA orbital buffer is nothing more then a "compound applier". IMHO they are useless. They really don't do any more then you could do by hand. They may take some of the hand fatigue away, but thats about it. They wont restore old paint or bring a high gloss finish by them self. If that is what your looking to do, then you should conceder stepping up to a polisher.
But to answer your question, Stick with a name brand if you plan to use it alot. porter cable, Makita, etc. If your looking for one to use once a year to apply wax, check out the "value" brands such as GMC or Chicago electric.
Also, I would recommend purchasing from Autogeek.net (no affiliation). That is where I bought all of my stuff and their customer service has been top notch.
The best polisher IMO is the Makita 9227CX3.
DeWalt DW849, theres a reason that every body shop i've ever been in has one. Its what i have also.
My experience is that Body shops can't detail to save their lives. Which has always made me![]()
What crack are you smoking ???????? i do paint correction with a PC all the time, i only wheel a car when its needed.
a couple of good forums are
http://poorboysworld.net/board/index.php
http://www.autopiaforums.com/forums/
the autoia forum used to be called detail city , was a better forum at that time, but there is still great info to be had there, its not just the PC your buying its the foam pads , product and the how to that you need to learn ( I'm still learning to this day )
Jeff
while i agree with this it's hardly the sterile environment to do it
detail, maybe not...but they should be pro's when it comes to paint correction and buffing cars, otherwise you should find another shop.
Jeff
A normal DA buffer will not remove sand scratches. They are not aggressive enough. A forced rotation style may be able to remove them, but it would be very slow going. If your using a DA buffer to cut & buff new paint, then you are working much to hard and slow. Seriously, Thats like using a combo wrench to remove lug nuts.A normal DA buffer will not remove sand scratches. They are not aggressive enough. A forced rotation style may be able to remove them, but it would be very slow going.
Every detail guy/paint shop/restoration shop I've been to or worked with has used Makita/Dewalt polishers.
Again, this is my opinion. I'm sure there will be several homeowners/amateurs/internet mechanics that will disagree.
FWIW, most of the "professionals" (detailers included) that have touched my cars over the years have used a rotary, and in almost every instance they have left hologramming on my cars which I have to correct. I've come to expect it when I send my car in for body work. So the tools of choice for the "professionals" isn't a terriby big sell when I'm the guy fixing their mistakes.
yes I've read lots of good things about it. It and the Flex seem to be at the top of everyones list.
