Power Probe 3, you wont ever use your test light again![]()
Seriously worth every penny!
Nobody mentioned it, because all the ohms function on a powerprobe does is a basic ground continuity check. Over 20k ohms is a blank display, more than 2k ohms but less than 20k ohms shows 0.0v, and under 2k ohms shows 0.0v and a green LED. Not terribly useful for any real diagnostics you'd need resistance measurements for.I love the power probe 3. Don't use it as often as I should as I just got it and am so used to grabbing the fluke. One thing noone has mentioned is it does ohm's too.
Same here. Test lights are for hacks
Test lights have there place. I use one mostly for a quick check of fuses. Fluke 88 is what I mostly use but even meters have their limitations. I have seen guys get burned. A DVOM can get you in trouble if you just check for voltage. For example, you might have 12 volts when checked with a meter, but not enough current can flow due to corrosion. I have seen wires that are so green and corroded, with only 1 or 2 strands left and you will still have 12 volts. In a situation like that, a test light might better tell the story, but not an led test light. Actually voltage drop testing is the best method in a lot of cases, but thats for another discussion.
Bottom line, all tools have their uses. It's the guy deciding which one is the right one that makes a difference.
I know this is an old thread, but I just happened to stumble across it. There were a few posters commenting on how a old fashioned incandescent test light is useless or for hacks.[/url]
the hacks must be quite the genius bunch then, as there are plenty of places where an old fashioned incandescent test lamp is still a useful tool. Power Probe 3, you wont ever use your test light again![]()
Can anyone recommend a good test light? I have bought the cheep chinese ones from the auto parts stores and they don't last long. The alligator clip spring always looses tension and light is not that bright. What is a good test light to buy that has a bright light?
I used my power probe to check for errant spark through a coil boot. It found it![]()
Good thing I kept my test light around for backup![]()
I currently have the powerprobe 3. It is a great tool i love it. Im thinking about getting that new snap-on version that i mentioned in the previous post though.
Post #60.. I posted a YouTube video about it...What is the new SO version you're mentioning? I haven't seen it. Thanks.
Get a good incandescent test light. skip the LED test light you want something that will put some type of a load on the circuit. Any major brand will do.
IF you willing to spend big bucks. Snap-on has a VERY nice new powerprobe light tester that does ciccuit loading, amperage, resistence, voltage ac/dc. It's good enough to replace your multi meter.
I am not usually one to endorse Snap-on tools unless it's best in class by far and this is less money than a power probe 4 and has more features. So it's a nice tool IMO.
I know right.. It's a dilemma.. I'm pretty sure I read or saw in the video that it does circuit loading.So the EECT900 has the ability to load a circuit and measure voltage drop? I was thinking about getting the loadpro leads and a power probe, but if the EECT900 would do what both of those would...hmm...
About a minute it he explains its load testing capabilities. I might talk my driver into letting me test drive one, I'm actually pretty curious if it could take the place of a load pro.
