I have this older Craftsman variable speed bench grinder, and recently it stopped working. Specifically, when I turn the switch on, nothing happens. I took it apart and tested:
So I went ahead and tested it, and nothing happened. Went off to Google and found a thread on this exact forum about a similar issue, and one reply suggested the problem could be a bad triac. Ordered a replacement BTA12-600B from Mouser, as well as a BTA16-600B just in case the problem was a low amperage rating on the triac.
Installed the new triac- the 16-amp one- and still nothing happened. Well, now I'm stuck. I'd rather not buy a new one because I'm short on funds right now, and I hate throwing stuff away if there's a chance I can fix it. If anyone has any ideas, throw 'em out there, no matter how stupid. Photos are attached (hopefully).
"Turn it off and back on again" and "Is it plugged in" don't count.
- the capacitors on the control board,
- the starting capacitor,
- the diodes,
- the potentiometer for the speed control,
- and the switch.
