- Joined
- Nov 4, 2017
- Messages
- 10,472
Nice!
I just finished inventorying this set against the catalog image. It is missing 4 - 3/8 drive pieces SJ14 - 7/16 Socket; H5J Hinged Tee; H12J - Ratchet; H13J - Universal Joint.Just found a nice old pretty complete set of Hinsdale tools in a nice chest/box
Looking at eBay for the H5J Hinged Tee and H12J Ratchet. I see some with smooth handles and some knurled. Is there a production date difference on these? It doesn’t look like wear.I just finished inventorying this set against the catalog image. It is missing 4 - 3/8 drive pieces SJ14 - 7/16 Socket; H5J Hinged Tee; H12J - Ratchet; H13J - Universal Joint.
It is also missing all of the Open End Wrenches.
Everything else is complete.
Phillip, I’ll check my stuff tonight if I get home in time. I can probably fix you upI just finished inventorying this set against the catalog image. It is missing 4 - 3/8 drive pieces SJ14 - 7/16 Socket; H5J Hinged Tee; H12J - Ratchet; H13J - Universal Joint.
I need the 3/8 swivel just like Phillip and two deep 3-8 socketsHere is the twin brother to Phillips set. My box is not as sweet as his.
Couldnt have put it betterSweet bottle capper!
Thanks. I do have a bog 202A which is the same but with knurled handle.Nice. That's a bog supplied ratchet.
Cool. I haven't seen a 1/4" thanks for sharing.They came in 1/2, 3/8 and 1/4
I didn’t check to see how rare…oops! I left behind a KP8 (Phillips size 4, I think) screwdriver today because the head was ground almost flat. Well, I did snap a pic of the handle for posterity.Does anyone else have a Hinsdale screwdriver? I've not seen any in this thread.
I found one last week. On the handle it has the Hinsdale name/logo (barely legible unless you know what you are looking for) and the number "3164 R"
It's overall length is 7.1 inches, the shaft is 3.9 inches long and the flat-head tip is 15/64" wide. It has an 8 ribbed handle.
What is the purpose for the left socket? never seen one beforeInteresting
Nice! I have a couple of those sets, and the sockets are packed in there tight.
Supposed to be a 40pc set. Im sure i have at least most of what you need laying aroundI found a nearly-complete G-20 set on Saturday and snatched it up for $3.50/lb. (G-20 set = $20).
Some of the pieces were in the miscellaneous-sockets bins and on another shelf in the store. I found some of those before seeing the box. Someone smooshed one corner, but it's fixable. The tools are washable, but I'm enjoying the vintage greasy dirt for now.
(the box sitting underneath it is also a G-20 that I found empty over 20 years ago)
The 5/8" socket is missing and there's an extra 12pt. 5/8" in the box. I've seen photos of sets that appear to have even more sockets, so it may be missing some in-between sizes.
Pretty sure refrigeration set.What is the purpose for the left socket? never seen one before
Reference to compare, there may be more sizes.…
