Who is the OEM?
2ndGearRubber
Pittsburgh
72 teeth? Is the direction lever "backwards" - lever to the right to tighten, left to loosen? Looks like a generic Taiwanese head to me. Torx head screws are the giveaway IMO.
KnurledNut
n/a
Im gonna guess a customized set by EASEN Taiwan.
Same dual drive mechanism as the Duratech and Ares, etc.
DadsTools
I noticed while recently conducting an extensive search for ratcheting box wrenches that all the brands stamped with the name letters in outline appeared identical to the Gearwrench brand. I ended up purchasing a Husky set that happened to have the brand name letters in outline, and side by side the wrenches looked identical to my Gearwrench wrenches. So now every time I see an imported tool with the name letters stamped in outline like these Bronco tools, my first suspect is the factory making Gearwrench.
finn
The UP, God's country
Looks much better than the tools that came with my Mercedes when I lived in Europe years ago.
Still have a few, mostly because they weren’t something I really ever wanted to use, so they never wore out or got lost
JradM
Alberta
Pretty cool!
I assume the ratchet is a bit driver on one side and a 3/8" square on the other?
I thought the handle looked a little like Apex (Gearwrench), but they don't have a dual-sided ratchet like that as far as I'm aware. I'm sure they could make one (and they do re-brand for a TON of other companies), but would Ford really bother spec'ing something unique?
The head looks way more like this one from Titan:
Not just the selector switch and bit holder, but the very flat profile of the sides too.
Grokew
Home
Pretty cool!
Titan ratchets are quite nice (the micro ones at least) their insert bits are OK, but their pistol grip pliers, ratcheting micro bit drivers, and standard non ratcheting bit drivers have some QC issues.
dstblj52
That would be Apex usually the sata plant in China
dstblj52
The same as the Pittsburgh/Quinn ratchets thought kobalt was selling them you see them just about everywhere
