Why Are There Varying Ghostshield Dilution Instructions ?
Pompey
I have seen two different sets of instructions for the dilution of Ghostshield 4500 when using it as a concrete primer/ intensifier One set of instructions say to dilute 1 gallon of 4500 to 1 gallon of distilled water
However these instructions say to mix 1 gallon of 4500 with 3 gallons of distilled water
The instructions on my bottles say to mix 1 gallon 4500 to 1 gallon of distilled water, so that is what I am going to do but I wonder where the 1 gallon 4500 to 3 gallons of water dilution level came from. Was 4500 sold in a higher concentration in the past ?
P
Pompey
4500 Interior, power troweled as a primer for 8510
Garage Flooring
Grand Junction, CO
Power troweled concrete tends to allow less penetration than hand troweled. If you go with a a stronger dilution you may end up
With white spots on the floor.
P
Pompey
OK thanks.. I will go with 4:1 I hope to apply tomorrow...I expect I will have a lot of 4500 left over
I saw this from a while back...
P
Pompey
I have a 35 x 60 area to cover ie 2100 sq feet. I bought 15 gallons of 8510. Will that be enough ? I will primering the floor with 4500 as discussed above.
Garage Flooring
Grand Junction, CO
Surface conditions always impact things, but it definitely does not seem like you will be short. For a 2 coat system on reasonably smooth concrete 300 square feet per gallon puts you at 14 gallons. Yoy may get better coverage and have more left
