Gator-J
I know this is wookworking and all but that is a pretty 10EE in the background.
I have a mixed shop of wood & metal machines as well. What do you do about fine dust on the metal machines?
Thank you. I wipe the dust off once in awhile....that is a pretty 10EE in the background.
...What do you do about fine dust on the metal machines?
Teak looks really good installed -- the curved edge is definitely needed in such a small space.Today I was finally able to epoxy into place the sink counter. The laminated teak rim is let into the door jamb. There will be a row of tiles to trim where the counter fits against the bulkhead and upper cabinet.
Thank you. The whole interior is teak; even the floors are solid teak (with holly strips). So there is no other choice but to continue with teak.Teak looks really good installed -- the curved edge is definitely needed in such a small space.
Not always a bummer to move. Yes it is hard work, but I’m betting EZ has learned what works and doesn’t, and unless this is a forced downsize that I missed, EZ will come out better. I’d offer to help but I’m not in LA anymore. Best wishes.
Thanks fellas. Been in that old shop for over 40 years. My landlady plans to turn it into a high-end apartment. All my machines have already been moved to the new shop, which is three times the rent I was paying. Additionally I had to rent two small storage garages elsewhere as the new shop is not large enough to store everything I've collected.You've been in that old shop for a long time I think?
Bummer that you're having to move all that equipment, not to mention figuring out where everything is in the new place.
Thanks.I really like using the side by side TSS and out feed table. Smart.
I presume you keep them set up for individual tasks, ie, rip, crosscut, dado?
I was afraid your move was being forced on you -- sorry about that.Been in that old shop for over 40 years. My landlady plans to turn it into a high-end apartment.
Attached is a photo of the new (750 sq ft) shop taken shortly after moving all the machines into place.
I am not a bright man, and generally need to learn by doing.
Alright, I'm dumb.
Using this as inspiration to build our own Island. This will be the first cabinet I've constructed. I understand general Cabinetry but have no practical experience.
I'm trying to figure out the method they used to build this. I'm unsure how the base was constructed. I'm thinking its a piece of plywood with the sides pocket holed on? It doesn't appear to have a face frame. Are the sides a singular piece of ply that they cut out for the doors and drawers?
That would be a horrible way to build it. Forget about pocket holes in the edge grain of plywood....I'm thinking its a piece of plywood with the sides pocket holed on?...
That looks like a ton of work!First photo shows the workpiece roughed out to support the tube.
Second shows how much I had to take off to get it to fit tightly against the inside of the hull. I first sketched its location on the hull; then transferred that info onto the workpiece; then bandsawed the bulk away before doing the rest of the fitting at the boat using a handplane.
Third photo shows it epoxied into place.
