jimreed2160
New (old) project
You long time readers may remember the old sewing box that I was working on.
So far I have made a drawer that replaced the pincushion, put feet on the bottom, and replaced missing trim on the small drawers. Remaining projects are to replace missing trim on larger drawers and make 1/2 of a missing rosette on the end.
Last time my daughter was here I showed it to her and she really lit up so I put it on the todo list. My new projects need to clear out room in the shop and this fragile thing really takes up too much flat surface space. So guess what zoomed to the top of the list?
I started this project like I start most--dig in the scrap pile--in this case I needed a walnut stick.
And I got a chance to try out my new (to me) pair of H&R planes. Years back I bought a partial set of Crow H&Rs from Patrick Leach. It is a nice high pitched set but was missing some of the smaller ones. Well as luck would have it, he found a pair of #2s and I grabbed those. It seems to be just the right size for this small piece of trim.
The planes are in good shape and needed only a little touch up. Of course, the round had a small back bevel as many H&Rs do. Craftsmen of yore did not have time to sharpen the profile so many of them just put a back bevel on the blade. Ugh. The way to sharpen H&R profiles is to use thin sandpaper on the sole of the matched plane and drag the bevel down the sole. For example, I needed to touch up the hollow bevel so I stretched sandpaper over the sole of the round and just drug the blade down a few times.
So I worked over the walnut using the H&Rs along with a Stanley #92 and finally got a match. Sorry for the poor photo.
Then I cut it free.
Here is the first trial fit.
And here they are after fitting with the glue drying.
Next comes the finish and then I can tackle the rosette.
Then I cut it free.
