work benches... from scratch
CJCar
South Central PA
2x4's laminated on top of a mixture of metal kitchen cabinets, metal cabinets from the university anatomy dept and ikea. :)
[/URL][/IMG]
I've been thinking of going this route for the top on my next bench. A few of questions if you don't mind:
Did you do any milling to the 2x4's before gluing them up? Run through a jointer/planer?
What type of glue did you use?
Any nails/screws/bolts/all thread?
Are all the 2x4's full length?
Have you had any issue with bowing/warping/cupping?
Thanks!
Dan in Pasadena
Pasadena, CA
Did you do any milling to the 2x4's before gluing them up? Run through a jointer/planer?....
Thanks!
Not to speak for the OP of that photo but I think you'd have to use a planer or jointer to square-up the corners or after the laminating there will be little depressed lines or gaps in the work surface. Not catastrophic but flat is better.
If you laminate the 2x4's so the grain of each 2x4 is opposite each other the tendency of each to warp will fight against each other and overall the top will TEND to stay straight.
JMartel
Seattle, WA
Well, you can use a hand plane, but it takes a while. Plus, if you plan to do that I would highly suggest you make sure all the grain runs the same direction. Otherwise you'll have to switch directions constantly and still have tearout.
mdbeck1
Norman, OK
I seem to remember an article I read about someone that built a sled for their router, placed a 2X on each side (leveled of course) and then leveled the top by running the router in the sled and then moving it over. Then run a belt sander over the bench top to smooth it down.
peelman
Seymour, Indiana
I've heard of similar methods when a planer isn't an option. Like a milling machine for lumber.
The other thing to do is to square the 2x's up on a table saw before you start. Taking off the rounded edges so you have a hard edge on at least one side can at least somewhat reduce the amount of planing (or jig routing) you have to do.
Hpozzuoli
Rhode Island
Here's a little work spot I made at one of my laundromats. Nothing fancy due to space constraints.
welder4956
Birmingham, AL USA
Something like this?
deezee
Saskatchewan
Thanks!
A friend of mine built it for me. He has a 12" planer so he built it in two sections. glued with wood glue and ran them through the planer, then glued and clamped them the two sections together. No screws or nails as far as I know. I had to sand them down by belt sander in the center before I finished them. He made them in full 8' sections and I trimmed off as I installed them. It was just built and installed so I'll report back if there are any issues.
sean Buick 76
Edmonton Alberta
Well it is not "from scratch" however I did a lot of work to the table so I thought it might give others ideas....
I surfed on here and saw a ton of really nice work benches however in the end I could not justify buying thousands of dollars in welding and cutting equipment to build a workbench so I stuck with wood.... The reason I went with this type of "table" design is that I wanted a large span of up to 10 feet between the two front legs and still be sturdy. I wanted a ton of open storage under all of my workbench area.
Here is what I started with, a roughly 500 pound oak table from a library was low cost locally on line.
JDishong
Prosper, Texas
Not complete yet, but here is my progress on my made from scratch cabinets. I wanted the look of aluminum modulars .... Stainless steel counter top in progress.
Wall mounted base cabinets required additional wall supporting to be installed behind drywall as shown:
dittle fart around
Vancouver, Washington, USA
View media item 10146
Here's mine. Built from recycled soccer goal posts. That's the wife playing the part of Vana White. Check out this post for more workbenches
We moved to Napa and left the house with our sons. This is my oldest son's new workbench. The saw table fits flush with the wall mounted bench.
View media item 42506
The bench is sloped to follow the floor so the saw table can be moved down towards the garage door and still act as an extension of the saw table.
View media item 42507
The finished project. Doesn't look much like my old garage anymore.
Regnar
Here you go. Good video on flattening a bench.
sean Buick 76
Edmonton Alberta
Today I added a 20" deep 8' long fold up work bench. That brings me to 38 feet of workbench in this 26X26 garage. I used two 2x10 that I salvaged from a construction dumpster, 6 hinges, and some 2x4 that I had around. It is really sturdy and only took me an hour to build. The 1x2 that ties the legs together also hold the bench up against the wall!
pennsylvaniaboy
love this thread....so many great ideas...those of you using MDF of plywood for tops....how do they hold up long term?
Grinder Bill
I purchased 4 Craftman 42" rollaway tool boxs on sale and used them as built-ins. Made the base out of 2x6 covered with 1/2" plywood and built the walls to support the 3/4" plywood top. Bent up 2 8' sheets of 304 stainless to complete.
Built another 8' bench from 2x2 steel, covered in 3/4 plywood & capped with stainless.
taumac
Brooksville, Fl
That looks great. Nice job
5 Stitches Garage
http://www.garagejournal.com/forum/showthread.php?t=211899
Florida GJ Group
http://www.garagejournal.com/forum/group.php?groupid=117
DP121
SW Ohio
Grinder Bill, how do you bend the stainless steel and how do you attach it to the plywood to make a workbench top?
Grinder Bill
ty, taumac.
I know a few guys who do HVAC; cost me a box of donuts to have the tops sheared and bent. The sheared off pieces were used for kick plates and trim.
The s/s is glued to the plywood with PL Premium, and attached to the wall with s/s screws, which are hidden by the aluminum diamondplate backsplash.
DP121
SW Ohio
ty, taumac.
Thanks for the answer. :thumbup:
sean Buick 76
Edmonton Alberta
I found this table stand by a dumpster and I salvaged it to build a medium duty 4x8 table. I can stand on the table and it is plenty stiff. I put this top together with a 3/8" plywood top laminated to scrap 1/2" OSB with 2x4 and 2x3 re-enforcement:
The feet are adjustable which is great and the top is removable with just 6 screws to the base.
rick carpenter
Huntsville, East Texas
I like your narrow benches Sean, they look really good and are similar in spirit to mine: two 6' x 18" sections of an industrial particle wood door cut in half. I have two-high milk crate stacks (plus, uhh, other ****) under my benches for storage
peelman
Seymour, Indiana
Its really very subjective. If you beat the tar out of them and gouge them to hell, they might not last a month. if you have a proper steel top for that kinda thing, and reserve the MDF surfaces for moderate banging, you might get a year or two. If your like me and hardly ever find time to get in the damned garage any more, they might outlast you. :sad:
Kimarieck
Las Vegas
Agreed. Depends on how you use it. For a woodworker, sealing or applying Formica might make them a long term solution. If you're gonna beat on them, you need to cover them up. Metal is ideal, but a sacrificial tempered hardboard top might be the deal short-term.
