Your bench is absolutely beautiful. Just curious how you attached the legs to bottom.
Thank You
02wrx I didn't include much information on the Barn Bench Build on this thread because it's cover very extensively on the Restored 1930's Auto Shop thread as I mentioned. The link I included earlier is where coverage of the bench build begins. As I look back now, I don't think that question about leg attachment ever came up and it's a good one.
The legs are all laminated hard Maple and are a full 4" X 4". All the legs are secured in their relative positions in multiple ways with stringers across the front, plywood dividers in the center and ...
...1/2" maple plywood backing all around the back side seen here. Since the leg material was all solid wood they were screwed to the base platform from the underside of the base into the bottom end of the legs using 2 1/2 " drywall screws, predrilled beforehand and using bees wax on the screw threads. The pattern was 1 in roughly each corner of the leg, slightly toenailed toward the center and 1 in the middle. That was one of the more challenging portions of the build since I was working from the underside of the base platform and the whole bench had to be elevated to do that attachment.
By doing it that way if you note this inside view and no leg attachment screws or hardware can be seen leaving a clean look. I hope that answers your question.
Thank you for the kind words and interest in my work.
Thomas from the Restored 1930's Auto Shop
http://www.garagejournal.com/forum/showthread.php?t=51567
