Wrench Organization
Mikem10974
What's everyone doing for wrench organization? I keep them in their original holders, but it's not a space saving method.....
2ndGearRubber
Pittsburgh
Ernst. They have grippy little nubs to hold the wrenches in. You can also get reversed models so you can stagger wrenches for maximum space utilization. Once you're above 22mm or so, the black HF wrench holder works well. It may scuff the chrome a little, but it holds my 32mm wrench just fine.
Yarpo
Minnesota
I've got two Ernst wracks and like them a lot. The Hi-Viz one here has no grips to hold them, the black one holds the wrenches better, but my box is pretty stationary so both work well.
griffiths51
I have a mixture of them and they are all about the same quality. The bigger one hold from 1/4 to 1 1/4c48d65a5239854dab7c28ee819b5d9c0.jpg
Mslund1
I second the Ernst.
I have the gripper style and like them a lot. They hold everything in place with out being difficult to remove the wrench 6a2c3ca4489c6cba7b0abd1082e10b69.jpg694d4ed64be5217c59f7078ee19bbad9.jpg
1/4”-1 1/8” and 7MM-21mm fit nicely, don’t mind the gaps in the Gearwrench sets.
Legion Prime
Leelenau County MI
Whenever possible I try to keep them in the original packaging. However I know I have tons that the packages got pitched likely before I was born. In that case the Ernest aren't bad. This is the one I have.
https://www.amazon.com/gp/product/B003XSTV5G/?tag=atomicindus08-20
I prefer something with a bit of retention but if you have bulky wrenches like Craftsman they're great. Otherwise I like the Hansen Global ones, I've grabbed a couple off Amazon and wow, they're even cheaper now. Maybe I should order a couple more just in case. LOL
https://www.amazon.com/gp/product/B005MVB2WM/?tag=atomicindus08-20
Mr Ratchet
I settled on the Kobalt wrench racks. They are pretty low profile and allow me to use a shallower drawer. I do wish they had a reverse pattern set though. I tried the Ernst which does have a reverse pattern set. They were to tall and I did not like they way they held my wrenches compared to the Kobalts. The Snap on versions look pretty good but, I've not tried them in my own box.
marineman
Wild Rose, WI
At work my combos and stubbies are on generic wrench holders, the rest are more occasional use so they're stored in rolls to save space. At home tekton wrenches come in an ernst style holder so my main wrenches are in those and the rest that I've collected over the years get tossed in a portable toolbox or a 5 gallon bucket
Wyoming09
Wyoming, MI
Regular Ernst rails here. Not perfect but the best I've found for my situation.
ssdave
Eastern Oregon
I use the Snap-on KRA rails. I tried others, but none hold as well, get the angle and spacing right, and pack as many wrenches into the space as the KRA's do. Here's a thread I started on them when I got them:
https://www.garagejournal.com/forum/showthread.php?t=341180
Here's what they look like in use; keep in mind these are in a KRL1001 drawer, so the drawer is about 38 inches wide if I remember correctly:
KBigg
NE Indiana
I got a spring from ace, stretched it out, and cut to size. Works great for less than $2. I haven't done one for my ratchet wrenches yet though so ignore those.
lilredex
Toronto
Everyday wrenches hang on the end of the bench, like this. Others are in small toolbox drawers and you go fishing.
1320
Arizona
I really like the Snap-on KRA15s and KRA22s and the OEM Tools copies as well.
4 FN 27
Minnesnowta
Those are nice and look very high quality, great job. I bet you could sell these here if you wanted to.
Wow, Great job
Thank you guys...a labor of love...and a touch of OCD.
I would market them but they are Wrench Set specific. Takes 10 times as long to design them as it takes to make them. Have to measure every Wrench...
I have posted all these before on here in different threads...but I did my Sockets too...some day I'll get around to doing my Screw Drivers.
View media item 87379
View media item 86214
Handyandy23
Ontario, Canada
Looks like I'm in the minority, but I just use the cheap-o Princess Auto (think HF) thin metal organizers. My box doesn't move so I don't have to worry about movement. They do the job just fine. For my uses I can't see getting too spendy because I'm not sure how much of an advantage nicer ones would even be.
They are a definite upgrade from the holders the wrenches come in, as they seem to take up a lot less space. The big chunky plastic ones they come in have the wrenches spread more and laying more flat for "display purposes" it seems, but for packing them into the box the little thin metal organizers are pretty dense.
sberry
Brethren, Michigan
I like that term,,,, every day wrenches. Same here, specialty stuff is tossed in a drawer.
jimmyin3D
southbay, CA
Save yourself the headache the Snap On KRA15 is the way to go, holds all types of wrenches and is fully customizable by cutting down. They also look the cleanest and it only took 3 of them (I believe $9 each from Snap On website free shipping for under $500) to do all my wrenches metric and SAE for a HF 56inch box.
Jtels85
I second the Ernst.
Thank you for sharing this! I’ve been looking for wrench racks that would hold my raised panel Craftsman’s besides the black ones they sell at Sears. Those only goes up to 18mm or 7/8. I’m OCD and a wrench rack should hold 1/4” to 1” and 7-19mm. The Hansen racks worked great for my Carlyle’s, but didn’t work for the raised panels because of the width of the raised panel haha
ihateminimumwage
Might have to give that a try. Moved into a 44" Homak box from a service truck, so getting used to not having wrenches in rolls.:beer:
Unruh
Silverdale, Washington
So for the wrenches I used two of the Harbor Freight Wrench Organizers and cut them into pieces for use. I got the organizers at a garage sale for $1 a piece so I wasn't too worried about cutting them up. The ratcheting SK's were birthday present. They are amazing and I'm asking the metric set to replace my Gear Wrench set this birthday.
BroncoAZ
Mine are a mix of Ernst and some generic racks from Amazon. This is the metric drawer. I will be removing or cutting down the middle rack with the ratcheting wrenches. The Wrightgrip sets are new and changed the layout of the drawers.
CGarage
United States/Switzerland
I like the Ernst wrench organizers.
The gripper organizers are great. But if you work on the clock, it is slower extracting the wrench compared to the standard Ernst wrench holder which just holds them (without grip) but presents them at a nice angle so you can view the size, etc
