old_smokey
Make sure your uncle is invited over to consult ( hangout) after everything is up and working. I bet he’d enjoy getting out and about .
Excellent suggestion!
Picked up some cleaning supplies and grease to restore the tool box. I hauled it home in pieces last night, along with most of my tools, two XT500s in boxes, and it’s all spread out across the floor.
In the mean time I gave myself a crash course on SketchUp. After a couple YouTube videos and some fumbling around I was able to mock-up the floor plan:
Gonna be squishy in there!
Today I placed an order for 1/8 thick cold rolled steel for the workbench top. I have about 1.5 weeks to get the base built up first.
I did what you're proposing, I ripped a 4x8 ft 3/4" ply. sheet, & glued/screwed it together. I capped it w/a single piece of 3/16" steel, which must be cheaper here. I ended-up w/a 2 ft x 8 ft workbench surface, & got some 1/8" by 1-1/2" wide strap to screw to the front of the wood, butted to the steel top. My bench frame had a steel backsplash that the steel benchtop butts-up to. I countersunk the flathead machine screws holding the steel tabletop in place. I need to clean it off, I have maybe 5 projects spread-across it now. I mounted my cordless chargers on the wall on Geartrack-style wall brackets, which I use for frequently used screwdrivers and wrenches too. Saves diving into drawers, & it's easy to see what's off the wall being used.
You have a stove, or it looks like to me, in your Sketchup. Storage or powder Coating?
I discovered that because the wood floor is so thick, the top of my backsplash will actually cover up the lower half of one 4-outlet plug, as well as the lower edge of the window. I might cut out the backsplash to provide access. I would still have about 3/4" of backsplash which would prevent spills from pouring into the plugs. Cutting out around the window bars would let me push the bench up against the wall. Not sure, I'll have to make that decision once the bench is built and in place.
So glad to see this moving along, your floor looks great, actually everything looks great!
I'm about 15 miles south of the Manitoba border, I think we're considered "Southern Canadians".
Everything will be glued together with contact cement. Picking it up tonight and building the base tomorrow![]()
You have made great progress. That floor is a very good idea. It will be warmer than a concrete floor and in your weather that is good. The bench turned out very well.
Your save of this building is really good.
Dwight
Been following your build from the beginning, fellow prairie Canuck. Awesome job! You've turned a sow's ear into a silk purse, well, maybe a leather motorcycle saddlebag.......
How do you keep your steel workbench top from rusting? You said you coated it in WD40 when you first installed it. Do you just sand off any rust and give it a blast of WD40 from time to time?
I saw a great comparison of rust inhibitors on YouTube somewhere. A guy tested around 50+ different brands. WD40 makes a "Specialist" line which includes a corrosion inhibitor product, it outperformed every other brand by a landslide. If I can ever find that locally I'll use it on all my tools.
