Zip tie storage-organization ideas
Sumboodie
AK
Hi, I’d like to see some ideas/pics of zip tie organization. Any bit hen ideas out there? Thanks in advance.
What's wrong with the bag they come in? I just buy 11" ones. Not worth keeping the short ones on hand when they aren't much cheaper.
king nero
Belgium
I got a lot of 'em, thrown all in a plastic box (in the long plastic bags they came in). Not sorted, but when I need one, it's easy enough to pick one sort/length out.
4xdog
Santa Fe, NM
My zip ties are mostly in the bags they came in, or in appropriate zip-locs, all standing on end in a medium plastic bucket.
MushCreek
Upstate South Carolina
Hmmm- I wonder if you could make long dividers to put them in one of those Harbor Freight organizers? I hate keeping them in bags. I invariably pick up the wrong end and they pour out. Of course, I have them from tiny 3" ones up to some 36" whoppers.
tomtomgt356
*******, GA
I have a tackle organizer I use for the smaller ones. The larger ones I keep in their bag.
A trick I found a while back (might have been here) is to cut a slit in the middle of the bag instead of opening the end. You can still get them out, but the rest are better contained and won't spill if you tip the bag wrong.
rieferman
Collegeville PA (30 min west of Philly)
I sparingly keep various sizes on hand in original bags, but mostly use two sizes... Those, I use one cable tie around each size to keep them nicely bunched (easy to tighten as stock is depleted) and those bunches sit in a tall plastic cylinder (I think bungees came in that originally). Works nicely
Radio Flyer
Suburban Chicago
This is what I use....
I can't leave them out at work, or they will disappear. It makes it easy to store in a drawer, and pull out when needed.
Also easy to "grab and go" for field service work.
Solpainter
I use the Plano box.
geneg
Midwest
small ones in peanut butter jars. larger/longer ones in suitable lengths of pvc pipe. All inserted in the same direction- head up. Pipes & jars vertical in a square (kitty litter) bucket. Makes them easy to select & stores better than a round bucket.
Bogie1632
Southeastern Wisconsin
I use some scrap PVC, cut to length. I glued and mounted them on the wall for easy access. I also have a Plano box with some in a tray so if I need to take all my electrical stuff somewhere I've got some ties with me.
V/R
Bogie
MushCreek
There’s a perfect example there’s an easy way and hard way to do a simple task/device.
And yet- neither one is portable. What some of us need is a way to haul the assortment with us. My shop and my house are 150' apart. My son's house is 600 miles away. I throw the bags of them in my electric kit bag, and of course, they eventually dump out and mix themselves with the other stuff in there. I used a HF organizer for my RBY connectors, and plan to modify one for zip ties. Organized, separated, and portable.
joey1320
NE Ohio
Would a utensil tray work?
Only $1 at Dollar Tree.
images
https://www.dollartree.com/plastic-flatware-storage-trays/858571
Renegade1LI
long island ny
Picked this up a few years ago, nice assortment and easy access, I it was 20$
Copymutt
Colorado
Anyone who drinks Folgers coffee has no shortage of storage containers. Tough enough for nuts and bolts. Will hold a huge number of zip ties. Work great for brining/marinading a duck or game hens. Good to clean paint brushes. Covers are cheap frisbees.. Mix a set of different sizes for a cheap set of kids bongos.
CN Spots
NW Mississippi
I like the Plano box idea. My 12" minus are in a clear plastic box. I zip tie my zip tie bundles together. The big ones I just hang the bag on the side of a shelf.
Alchase
Harrah, Oklahoma
All of mine are still in the original bags they come in. I store them just like you see in the stores.
They are on my pegboard with the longer Zip Ties in the back, shorter in front.
They all fit on two of the longer pegboard hangers.
Easy to grab and go.
crewchief888
NW indiana
Same size as the flambeau, I use both since the size is standard, same in my own shop have a mix of metal & plastic.
all mine were "salvaged" from a service van we stripped. company was going to scrap all of them. i have 20-25 of them in the garage.
my service truck has 4 sets, 4 drawers each
:beer:
niget2002
Josephine, TX
zip loc baggies.
Large ones in 1-gallon bag
smaller ones in increasingly smaller baggies
All thrown into one large 2-gallon zip-loc.
That way I can grab the big bag with all of them, or if I know I just need one size, I can grab just the one smaller bag.
As bags get empty, I refill them.
bas157
Near Philly
If leaving in the bag they came in, open the bag in the middle with a slit going perpendicular to the ties (or cut out a little square). Doing that, they can not fall out if you pick it up by the wrong end! Flexible enough to grab one or multiple by grabbing them by the middle and pulling through the slit.
I've got some huge bags of them (like 1000 pieces) from a yard sale, not lugging that around! I take out a handful and tighten one around the handful. As I use them, I just pull that one tighter to keep them all together.
Dan in Pasadena
Pasadena, CA
^^^ Smart and easy. What's better than that?
