Alamedasam
Hi, I’d like to see some ideas/pics of zip tie organization. Any bit hen ideas out there? Thanks in advance.
Nick has a nice easy one on his YouTube channel....
Ray
There’s a perfect example there’s an easy way and hard way to do a simple task/device.
This one is nice but not cheap.
https://frontiershopsupplies.com/sh...rtment-800-pc-black-uv-rated?yoReviewsPage=3t .
this is the type box i use, both in the garage and in my service truck
Same size as the flambeau, I use both since the size is standard, same in my own shop have a mix of metal & plastic.
I use the Plano box.
If leaving in the bag they came in, open the bag in the middle with a slit going perpendicular to the ties (or cut out a little square). Doing that, they can not fall out if you pick it up by the wrong end! Flexible enough to grab one or multiple by grabbing them by the middle and pulling through the slit.
