Had a little yardwork to get done last night as we were supposed to get rain, which we did overnight.
The nice thing about my trees is usually once the first leaf falls, they are all on the ground within about two weeks. With the trees pretty bare and clouds thickening I decided to clean up the leaves from my trees last night. I will still have to do this all over again once my neighbor's trees shed their leaves, but at least mine would be done before the rain hit. Last night lying in bed listening to it rain, I just thought how nice it was not to worry about the leaves getting packed into the grass.
Losing DST *****. I HATE how early it gets dark now. Just as I was finishing up the leaves, I walked back to get the rake and noticed how pretty the mountains looked as the sun was setting.
Then within minutes it was dark.
One small tool that I have thought about making for a while now was a gauge tool to reach into fill holes in rear ends and transmissions to check fluid levels. Many times when a vehicle comes in the fluid isn't coming out of the threaded fill hole, so I will grab a zip-tie, bend it to 90-degrees and insert it to measure how far below the threads the fluid level is, then toss the zip-tie. For the past little while I thought it would be nice to have a dedicated measuring tool that would be easier to read than a plastic zip-tie.
Last night I grabbed a small piece of 3/16" cold rolled and knurled the end by about a half inch.
Then stuck it in between some soft jaws to avoid flattening the knurls and bent it to 90-degrees and put a little heat shrink on the end.
There, that should work as a nice fluid level gauge that should be easier to read, then clean and stick back in the toolbox for the next time.
Thanks for looking.
