Lift modifications Thread- Lets see them!
Relax
GTA, Ontario
That is 9ft4 inch to the ceiling... even less with the garage door in the way. I was in the garage attic the other day though after posting this and I think there just may be a way to get 3 extra ft. I would have to have the door closed when working though. At least there is some hope though.
A high lift garage door conversion will also buy you additional height, and depending on how close your lift is to the garage opening, the portion of the door that's horizontal when open might fit between your hood, windshield, and ceiling. It's mostly the traditional garage door opener hanging in the middle of the ceiling that's in the way.
Relax
GTA, Ontario
That's assuming a single garage door. On the other hand, this picture posted by @HIRISC was always an inspiration for installing a 4-post in a standard-height garage:
N
ndm
So let me try to explain. It is more complicated than that in this particular case.
1. My garage has a bobtail truss. In the area of the bobtail that is clipped out of the typical truss, there is a bedroom so it cannot go up.
2. The door is a double door and 2.5 ft of the door is beneath the bedroom so it cannot go higher than the ceiling is now(9'4")
3. The man door into the house is in front of the area where the lift would be forced to go due to the bobtail location. So essentially, even if I can make this work, the door will be blocked mostly.
It is complicated, but after tonight, I think I might have really figured out a good way to get it in there.
TurnipTruck
Southcentral Alaska
Not a mod really, but I've used this method to get my engine in and out of my bed a couple of times.
DE773FED-BA04-4901-897F-6458C2899A12.jpegI also had to use the hoist to unload an engine. My tractor can pick a big block Chevy with a ******, but it couldn’t budge this Unimog engine. I’m guessing 1200 lbs?68CEBF0F-90E2-4B4C-8D51-E60069F8EF2C.jpegNot much clearance for the trailer. After the pallet was on the floor I used a freshly-salvaged pallet jack to stash the engine out of the way.
N
ndm
Wow.. This one is too good to leave unposted.
Found it here
N
ndm
Well, after 6 years of dreaming and drooling over these lifts and lift mods, I have given my wife notice that I intend to finance a doublewide advantage lift.
To keep this thread clean I will start another thread though. Mine will be heavily modified though in a unique way.
like2wheel
On an as needed basis
Here’s a simple one:
Not willing to pay almost $90 for the miniature dock bumpers that is the door protector kit for my Forward lift, I came up with a better & much less expensive solution.
Ran across a couple nice soft foam garden kneeler pads on clearance for the season, and came up with this idea: Cut out a block of wood to match the handhold in the kneel pad and tape to small fender washer to the backside. Attached one of those thin rare-earth magnet to the lift carriage. Screw holes in the wood blocks match the threaded holes designed to hold extremely overpriced dock bumpers
Now I have a kneeling pad always waiting in the right spot, then it’s easy to just pop it back where it belongs. The magnet quickly locates the spot & just a quick tap puts it back on the wood block. I would make that out of rubber if I had something 3/4 of an inch thick, but it is still recessed & nowhere near the door in use anyway.
Actually, I think three magnets with corresponding washers taped to the back of the pad would do just as well.
Now the doors are always nicely protected from opening too far, and I no longer have to ******** kneepads to set the lift.
number9
I’ve got an Advantage Lifts 9000XLT on the way and researching mods I may want to add.
Thinking about where to mount the power unit, I can see where either side of the post it’s mounted on may be in the way under some condition.
Has anyone ever done or think it would work well, to drill the post top plate and power unit arm to accept a 1/2”, 5/8”, 3/4” bolt and mount a thrust bearing between them to allow the arm and power unit to rotate to a different side of the post if needed?
Couldn’t find a pic so snagged a screenshot from an install video.
575cat
I widened one my lift,s 1 foot to lift my tandem boat trailer and store it .
rsparks64
Hill Country Texas
Found it here
I wonder if it could also be modded to give massages?
grabeb
I have the same lift and after nearly a year, that hasn't been an issue for me. Reading through some of these, I am now worried, just a little, about the exposed bottle. I wondered if I could remotely mount it to the wall with the controls, but I don't think easily doable.
number9
I’ve decided to use a sheet of UHMW instead of a thrust bearing. Lift is supposed to arrive 1/4 so I’ll see how it’ll work out then.
grabeb
I've seen talk about how to store 4 post lift casters so here's my solution. 12' sidewalks so they're up and out of the way.
I also added a switched outlet that I can lockout if need be and it's up out of reach of little ones.
Lastly, I've added lift lights to light up underside of vehicle, still want to light up the underside of the lift.... working on that.
I guess I've now is, I added a power strip under the lift to power anything needed while under there.
grabeb
Here's the power strip and switch lockout.
jbrentd
Northeast Oklahoma
Recently added a bridge jack...
I store mine much like yours.
grabeb
The bridge jack is/was a great addition. I want to fabricate a rolling hoist, maybe even look at a rolling jack tray and add a winch mount, so I can lift heavy objects up with the lift when it's up. Think car engine, etc....
On non-lift subject how you like the tin on your walls? I'm planning that exact tin on mine once I get the uppers complete.
jbrentd
Northeast Oklahoma
I like it quite a bit. Glad I did it.
grabeb
If you work on any solid axle cars (and even if you don't), a pair of axle stands/adapters are a nice-to-have over the regular flat bridge jack pads. They provide insurance that whatever you're lifting doesn't slip off. I whipped these up some time back.
As I think I might have told you before, I'd probably buy those if someone sold them. I think I asked you if you would! ;) That said, when working on my 2012 Yukon XL, I'm not sure they would have helped much if any. Seems like I recall spacing was off, so I just used the high density foam 6" thick foam pads they included and they did the job. Excellent job though!
jbrentd
Northeast Oklahoma
Not really a modification, but I’ll post anyway. I’m sure I’m not the only one doing this, but I figured out a decent place to store my ramps. I was trying to think of a good way to get them off the floor. Turns out the simple solutions work the best sometimes. Not sure why it took me so long. They fit nicely between the rails, stacked on each other.
grabeb
Mine fit there as well. Sometimes if I have a leaky car I'll throw cardboard over to catch the drips.
number9
Not really “mods” as I am still in “setup / adjustment” phase of my lift install, but some things I’ve done.
Made a bracket for an emergency stop switch (idea from this thread) and mounted it to the power unit plate.
Found a 2’ 12/3 whip with triple outlets on the end at Rual King. Got two of them and cut the opposite end off each one. Used them to wire into the emergency stop switch.
The line side runs up to a 40’ 12/3 extension cord that runs up across the joists and down the wall to an outlet. The load side has the triple outlet end and dumps just under the stop button.
The lift is plugged into the triple outlet and the remaining two will be used for led tape lights when I get to that point.
I stuffed the excess lift power cord up into the arm that holds the power unit.
Nearly anything that comes with push clips gets them replaced with the quick ring type, did just that to the pin on each lift caster.
RamVet
DFW, Texas
jbrentd - Looks like we have the same lift and I've been moving my ramps all around the garage until seeing your post. What a space saver and nice not having to step around the ramps. As usual, Garage Journal fixing problems in a simple and elegant manner. Thank You Sir.
grabeb
Number 9, I've seen other posts regarding an emergency stop but I guess I just figured maybe something different on those lifts, but you've got the same brand as I. I guess I'm not sure I totally understand the point.
Now I do have a lockout switch so lift can't be turned on, but it's there a problem with the motors on these sticking and running? If that happened it would be on way up and they aren't exactly fast. Going down there's the release valve and the safety lock that both need to be held. Power isn't used to go down so only useful going up.
Can you clarify why you think important? Looks like a clean install regardless!!
number9
I’d seen other posts of adding one, read accounts of button sticking or failing internally (not on an Advantage lift) and thought it would be cheap insurance. My teen boys will use the lift too, so should something like that happen and I’m not right there at the time, it’s a panic button for them.
Fix Until Broke
SE Wisconsin
Some hoists use the pushbutton to start the motor to handle the full motor current. This is a huge inductive load to make and break with a small microswitch. The scenario where an e-stop is handy is when you're setting the hoist arms. You swing them under the vehicle on one side (typically the motor side :)) and bump the hoist up an inch or two for accurate placement and the motor doesn't turn off. You can stand there and hold the lowering lever to keep the hoist from raising one side of the car up - remember the other side hasn't been set yet - but you might be there a long time waiting for someone else to turn the breaker off.
In a perfect world this would never happen because you'd always set the opposite side first, the vehicle would always be perfectly centered in both directions on the hoist, there is never anything on the floor that interferes with the hoist arms, there's always a 2nd person in the shop, etc. Now, back to the real world...you install a secondary means of stopping the hoist.
jbrentd
Northeast Oklahoma
Glad to help! I was also tired of walking around them or seeing them take up space. I like that they are so close, for when they are needed.
grabeb
I understand for some lifts it might be good. For the 4 post advantage, I didn't see a need, but I get it with the teens using it..... maybe i overestimate the pushbutton that's on these as well.
Dig Doug
Here's what my rolling jacks look like. Might be able to attach some angle to the runway and put the lights ontop, they'd end up just above the top of the runway.
If I do this should I use 2 sided tape to attach the angle, not sure drilling and tapping the runway would be a good thing?
Like this
Fix Until Broke
SE Wisconsin
Here's some pictures of the pushbutton - Doesn't last long making/breaking current on a highly inductive load...The switch now just operates the coil on the motor starter above it. Still inductive, but a couple orders of magnitude smaller.
One switch in parallel with the push button so you can lift the hoist and walk away, 2nd switch is the "oh poop" switch that cuts power to the motor directly.
We added a couple outlets as well for power tools, welders, etc
Homewrecker
Toronto, Ontario, Canada
I was looking at getting that Paddle Switch. What device box did you install it into? I've been reading about people having issues finding one that can fit the depth of the switch.
BruceMc
Fairbanks, AK
Not a modification so much as an accessory. I have a Direct Lift 4-post with a couple of rolling bridge jacks. The bridge jacks came came with a pair of 1 1/4" and 5" spacers for the pads, but there have been times I needed more extension height than that, which usually wound up being a chunk of 4x4 or 4x6. I contacted the local Rotary dealer (aka Direct Lift) about getting another pair of extensions and they quoted me $42 each for the 1 1/4" and $67 each for the 5". So I made my own instead. Ordered four 6" chunks of 2" DOM and four 1 1/2" rods off of Amazon for a total of $95 in materials & shipping.
