Vintage RIDGID Pipe Wrenches
jeffmoss26
Cleveland, Ohio
today's 5 dollar restore find - part of me wants to remove the dirt to expose the markings on the jaw, but the other part wants to leave the patina on the wrench!
AreBeeBee
Wisconsin
And to judge by the knurled adjustment ring it's likely a WW2-made wrench. Cleaning the adjustable jaw may reveal a date...
PSCo1867
PA
This 6", B-5-4, squared-off dynamic appears to be practically unused. However, it's been "modified" with an extra hanging hole, and an enlarged original hanging-hole. The red seems absolutely original. May 1944?
Your wrench may fall into this questionable transitional category that was recently discussed. My very similar example is shown below.
Ahhh! Good. We are in agreement then.
I don't think there's ever been any question about that. Scroll through the thread. I don't recall any pipe wrench with all the unmistakably prewar or wartime features having a bulge.
If they are wartime dates and not a decade later, yeah, it was either Ridge using up old stock, or people using parts interchangeably years and decades later, which is still very routine.
I don't look at the case of these wrenches - red frame (static jaw, housing and handle), slight bulge, patent number on handle, found with dynamic jaws and adjusting nuts that could also be wartime - as counting or discounting them so much as being more precise about what is being counted or discounted. What is the wrench when it has two parts? The dynamic jaw or the frame itself? Treating them as separate assemblies creates the least amount of conflict.
The red frames are postwar.
The dynamic jaws may be original to the frames and therefore with date codes that are postwar years.
The dynamic jaws may be wartime with wartime date codes.
That's safe and reasonable until we have more evidence, I think.
Brian R.
I've really been enjoying this thread. There's something about an old pipe wrench that's satisfying in a way that's similar to a great old bench vise. Just a simple indestructible old thing. I picked up a pretty clean 1944 14" off Craigslist. I overpaid at $40 but I don't really care. I needed a pipe wrench for another project and didn't want to buy a new one. All it needed was a soak in Evaporust, paint and grease. Anyway, here are the pics. It matches up nicely with my old No . 2 heavy duty cutter which has it's original box! How often does that happen?
Brian R.
Brian R.
Thanks guys! I actually forgot to include the jaw pic that shows what we've concluded is likely the date of manufacture. B-9-4. September 1944. I think of all that's happened in the world in the time this thing has been around. I feel like this wrench is too clean to have been used much in the field.20230727_091832.jpg
Leviton
Oregon
I love this thread. I found one, and bought it because it looks factory black. My assumption is that it was made in Octembruary of 1944 and wanted to see if you guys agree? (The adjusting screw ring would have to NOT be original.)
StampDate CodeOAL"Post #Type
3 RxA E-15-410430Straight
P
...wanted to see if you guys agree?
Yes.
Octembruary
Haha. Yeah, there are some numbers that bust the month theory. I have a couple, too.
Correct. Postwar interchangeable.
You passed the test. Place your right hand on a Ridge Tool Co catalog and repeat after me...
I [state your name], of my own free will and accord, in the presence of these GJ members as witnesses, do hereby solemnly declare that the principles of this dating theory as it has been explained to me accord entirely with my own views; and I solemnly promise that as a member of this thread I will faithfully adhere to those principles endeavoring in every way to perfect this theory for other newcomers, intellectually, and socially, and endeavoring also to hold other Ridgid pipe collectors to that high standard of conduct required. :)
waks
Northeast CT
After looking thru most of the posts in this thread I haven't seen another one with "Pat'D" stamped on the handle ......I'm assuming it is probably dating between "Pat Pending" and the 1727..........Pat of 1929....any insight as to the date would be appreciated......
P
There are a few others on the thread. They've been discussed a few times. Jury is still out. See post #88 on page 3 and then posts #283 thu 291 on page 8. Or hang around. Yours might reinvigorate the discussion on them.
waks
Northeast CT
Thanks for heads up response to my post.......I've checked out the posts that you listed and agree that it is still a "gray" area. I will share that I have a collection of pre-48 wrenches from 6 thru 60......yes I know they should be black but hanging from my 12 foot garage/shop ceiling they are much more visible in red. I do have a few set aside that are still original black with decals intact.
Mike'smeatshop
I've had this 24 for years. Good you seldom need a cheater. Bad hard to find somewhere out of the way to store.
