Is this BP a 4hp?, what vfd did you order?
the operator has to "hold" each axis while using the other axis. If you let go of the "Y" axis and take a heavy-ish cut on the "X", the "Y" can back drive and move off position (my experience)Usually they don't hold the table still without a drive motor to hold the screw still,
Be aware, the vfd should only be used to power the motor. It does not put out a "sine" wave that is needed for the controller or any other 60hz power line dependent equipment. A rotary phase converter would be the choice for thatThe mill will be the only three phase motor that I currently have so the VFD looks to be the best and quickest option to get started.
Both my Bridgports (I have a step pulley and a variable speed) the only 3 phase needs are the main motor and the coolant pump, the rest of the machine and all the controls run of the transformers various outputs, which is single phase input and configurable to different voltages. They are quite easy to convert to single phase power.the operator has to "hold" each axis while using the other axis. If you let go of the "Y" axis and take a heavy-ish cut on the "X", the "Y" can back drive and move off position (my experience)
Another caveat: if using the vfd on the motor, the vfd output must go directly to the motor with no interruption. DO NOT hook the vfd to the forward / reverse drum switch and switch the motor direction while the vfd is active outputting power - it will ruin the vfd!
You must use the vfd control panel or hook up the appropriate switches (forward /reverse etc) on the vfd terminal strip. You may also need to adjust parameters on the vfd to get the needed acceleration / deceleration for the motor.
It should be 2hp for a series 1 with a 2j head. Earlier machines had options for smaller motors than 2 hp.Is this BP a 4hp?, what vfd did you order?
My intent is to make the power supply swap as simple as possible. The power cord from the Bridgeport motor will be wired to the output of the VFD. All control functions will be done using the control switches on the Bridgeport. I will probably play with the motor acceleration times and the braking resister to not having to use the spindle brake on the machine. Other than that, I see no other changes required.
again, a vfd should not be used as a global power supply / power converter. They are meant to control a three phase motor and that's it.The power cord from the Bridgeport motor will be wired to the output of the VFD.
As others have stated DO NOT connect it that way!. The power cord from the Bridgeport motor will be wired to the output of the VFD. All control functions will be done using the control switches on the Bridgeport. I will probably play with the motor acceleration times and the braking resister to not having to use the spindle brake on the machine. Other than that, I see no other changes required.
You must connect motor leads directly to the VFD.
So pretty. Lotta love put into that machine.As others have stated DO NOT connect it that way!
You can then. Run wires from the factory drum switch to the VFD or just use new forward / reverse controls for the VFD.
No real need to use a breaking resistor on a Bridgeport VFD (other than wiring an eclectic emergency stop). The factory breaking system works well, lasts forever and is important for changing collets (unless you put it in back gear to do that).![]()
Thanks! I fully tore it down to the last screw when I got it a few years ago.So pretty. Lotta love put into that machine.
Thanks. Had a few massive life changes in the last 6 months. Finally in a position to get back to the lathe project soon as I finish my Wilton 3C rebuild in my Garage Thread.LOL, I recognized Grants garage before I saw that it was him, his lathe post was/is addictive…
That’sThere's a flood of information coming, I'm just trying to process it all. For starters my Bridgeport is a Series 1 with a 2HP motor wired for three phase 208VAC. From the manufacturers plate on the motor, for low voltage (200V) motor is rated for 6.5 amps at 60 hz. I'm going to use a DuraPulse GS11N-23PO, rated for 3 HP at 11Amps.
Power to the mill motor goes through the Forward/Reverse/Off rotary switch then to the motor (see pictures). If I'm understanding the comments correctly, I need to bypass the rotary switch controlling the motor and wire the motor directly to the VFD? This will obviously require a remote function switch to the VFD
Grant Gunderson did just that ^^^^^The switch (if the VFD can do this) would go to the VFD as the direction input control.
You absolutely could wire it this way if you wanted to, as long as the drum switch gets wired out of the cable and instead gets wired to the VFD for direction control and you go into the control cabinet, find the motor contactor, pull the power feeds out of it, (from memory just phase 2 and 3 and they are short links from the coolant pump condactor) so it still operates but has no power, then use any of its available contact sets as the control switch for motor run on the VFD.My intent is to make the power supply swap as simple as possible. The power cord from the Bridgeport motor will be wired to the output of the VFD. All control functions will be done using the control switches on the Bridgeport. I will probably play with the motor acceleration times and the braking resister to not having to use the spindle brake on the machine. Other than that, I see no other changes required.
Yes, it is a variable speed head, you can crank the hand wheel on the upper right side of the head and it will alter the belt sheave to vary the spindle speed. Only adjust while the motor is running.can the mill handwheel still control spindle speed with a VFD?
Yes. However I and others have found using a new set of controls for spindle directions etc mounted bellow a DRO on the right side of the machine is a much more convenient and ergonomic location than the factory drum switch location on the top left of the head. Controls are pretty cheap so you can always try it one way and change it latter.So it can be done. My original plan was to use the mill controls as much as possible.
Another question is speed control. My mill has a variable speed handwheel. I don't remember how speed is adjusted on induction motors but can the mill handwheel still control spindle speed with a VFD?
^^^ very wise. Start simple. Bells and whistles laterDon’t get too caught up in the VFD tech. Keep it simple and just use it as a power converter.
Making sure to lock the table in the axis you are not moving is a first step. Just keep in mind that the table locks are not great. They are good but not great.Someone already answered for me but yes, I don't have three phase power in my garage thus the need for the VFD. The mill will be the only three phase motor that I currently have so the VFD looks to be the best and quickest option to get started.
Looking under the table this morning, it appears that I have a ball screw setup. It looks exactly like the ball screw from the drawing sent by RoninB4. If I'm understanding the comments correctly, the ball screw should not be an issue with manual operation as long as I lock the table in the axis I don't want moving during milling operations. Since I don't have the dial indication on the X&Y axis I will need some sort of DRO. The mill already has the linear scales (correct term?) installed for the Anilam controller. Can those be used for another brand of DRO?
The other option is to try to get the Anilam controller functional as a DRO only, probably a long shot.
Like some, perhaps most of you on GJ, I'm a hobbyist and enthusiast for metal working. I don't plan putting the Bridgeport through a work out. My ultimate goal is to be good enough to make car parts for my vintage British sports car when I need to. I was planning on using the Jet vertical mill at my local Makers Space when I ran across the Bridgeport. The convenience factor can't be overstated.
Nearly all CNC controls can be "power feed" with the controller. This particular control you would hit the hand button, Select X, Y or Z axis, an then push the + or - button next to the hand button to jog it. To adjust the speed of the feed you can either push the Feed button and enter an amount or use the feed percentage buttons to raise or lower.Making sure to lock the table in the axis you are not moving is a first step. Just keep in mind that the table locks are not great. They are good but not great.
Keep in mind that if you are taking to big of a bite with the cutter, you may get some creep in the table. This may just be a learning. Excersize for you till you get the hang of how big a bite you can take.
On the CNC machine, the machine(computer/controller) will “lock” the table using the motor by exciting the poles of the motor to not turn. I’m actually kind of wondering if you could leave the motors in place and use them as power feeds and as table locks.
I know one place I worked had a CNC lathe that allowed the operator to move the carrrage and cross feed using dials on the control,panel
I would have kicked the contractor out the workshop and told the guy to never come back, any one too thick to kill a drill running backwards without realising, let alone a second bit doesn't deserve to use others machinery.One day we let a contractor use one to drill some holes prior to being converted and he burned up two drill bits before someone came over to investigate the smell and realized he was in reverse practically hanging off of the quill lever.
While I don't disagree with you, Those kind of actions become political quagmires in large bureaucrat ran companies. He was asked never to touch any of our machinery again, and any machining that was required we would gladly assist him in to the fullest of our capabilities.I would have kicked the contractor out the workshop and told the guy to never come back, any one too thick to kill a drill running backwards without realising, let alone a second bit doesn't deserve to use others machinery.
A large bureaucratic company here would be very unlikely to let an outsider use machinery in the first place, the health and safety implications, not being trained on the machinery, not being covered by insurance to even be in the workshop, it wouldn't be worth the risk.While I don't disagree with you, Those kind of actions become political quagmires in large bureaucrat ran companies. He was asked never to touch any of our machinery again, and any machining that was required we would gladly assist him in to the fullest of our capabilities.
The powers that be did at this company?A large bureaucratic company here would be very unlikely to let an outsider use machinery in the first place, the health and safety implications, not being trained on the machinery, not being covered by insurance to even be in the workshop, it wouldn't be worth the risk.
Only after tooling was ruined, here in the UK in most corporate type places wouldn't have allowed a "contractor" to touch anything other than what they were there to do, would probably be escorted whilst on the property, they wouldn't be allowed to use machinery to begin with.The powers that be did at this company?
Your mill looks like it has the same electrical box as mine, labeled "high" and "low" speed, this is actually a switch to reverse the motor wiring when the mill is physically in low gear and running the quill backwards.An update on my progress. I had a couple of false starts with the wiring but the Bridgeport is finally wired up enough to check for noise and rotation. No external STOP/START yet, currently all done on the VFD PBs. With some trepidation, hit START and with great relief it powered up and ran CCW which I believe is reverse. I wasn't too concerned at the time, simply swap two motor power leads at the VFD. I later realized that the mill was in Low gear so all is normal. I again appreciate all the assistance here. The next step is to start buying the equipment to using the mill. I will also need to start looking to see if the CNC controller still works. With the ten million circuit board in the control box, I wouldn't know where to start, time to call in an expert.
No real need to use a breaking resistor on a Bridgeport VFD (other than wiring an electrical emergency stop). The factory breaking system works well, lasts forever and is important for changing collets (unless you put it in back gear to do that).![]()
