Another month has passed and we have made a lot more progress. I originally wanted to get the car done for Sick Week 2023 and now I am shooting for Sick Week 2024 lol! Some might say I grossly over estimated how much time this project takes but I don't think I have I just under estimated how much time family, work and trying to hang on to the last shreds of fitness from my Triathlon days takes lol!!!
We are signed up to do the SE Street-N-Yeet DnD event in SC in Nov again AND it is looking pretty good that this car may actually make it to the event. Whether it makes it down the track is another story BUT I think it will at least be running by then and if it is I am planning to take it.
As of today I have ALL the plumbing done, brakes, fire suppression, oil lines, evac line, fuel lines, trans lines coolant line so many AN lines it is almost dizzying. I did plumb the entire car using Racetronix stuff which is pretty nice. They are in Canada shipping is really reasonable you don't pay tax and their website is pretty easy to use and has an extensive list of fittings adapters etc. I used their PTFE line and fittings for the fuel, std nylon braided rubber for coolant, oil and evac, and hard AN lines for brake and fire suppression. The parts are all high quality and I even used the Clam Shell/Wiggins style clamps for the IC. I am 99% certain they are the same parts as Vibrant produces just re-labeled for Racetronix. Both companies are in Canada and the parts interchange for the clamps
As you can see in the pics the header coating is done and they are finally on the car for good 3 versions later! I used a product from Zycoat that is supposed to be good to 2000* my coater has it on a TT Mustang he said still looks like new. We will see I have not seen a good coating that holds up to the heat a turbo motor makes but this one looks promising. It is a bronze and at least looks good now! I also fabbed a new turbo mount version 6.4 lol. I also mounted the boost solenoids on it which turned out nice and is in close proximity to the WG.
I am pretty happy with how the engine compartment is turning out. I am not sure I am keeping the pressure sensor bar on the pass wheel well yet. I know it doesn't look like a stock GN motor BUT it does keep the same basic layout and stock configuration which is what I am shooting for, a cool hot rod that is stupid fast and not just a race car. Then again you never know what the future brings, a twin turbo Stage 2 head Buick V6 on methanol.........
I bought a pair of Goodmark rear floor pans and Ray did a great job sectioning them in and around the bars. It cleaned up the floor pan and we also raised that area of the floor 2" which will help with the exhaust system whenever we get around to fabbing that mess.
I ended up struggling with the Vacuum pump and evac system and still not sure what I have will work. Crankcase venting in a high pressure high HP turbo motor is never easy. I ended up going with a really nice air/oil separator tank made to mount on the firewall for a G-body. It holds 2 qts and has two -12an fittings with a drain on the bottom and a port for the transmission vent. The jury is out on the whole vacuum pump deal and whether it will work and be able to keep up on my motor. I already had on the car from before so it really didnt take any extra work to hook it up other than a couple of extra AN lines. I am going to give it a go, we struggled to get it to working right back in 2009 but I did have it working. Back then and did not have any crankcase data but I will now as I have 1 Bar MAP sensor wired into the Holley. If I can't get it to work I will just pull it off and run two -12s from the VCs to the tank and be done with it. Might use the mount for the AC compressor lol!
We got a lot more the fab work done this last weekend and started on the inside of the car with the shifter parachute handle etc. I have some work on the dash frame and and have to finish all the electronic mounting then it will finally be time to start wiring which is the final step! Fingers crossed the car may be running by the time I make the next post!!
