Which Pass Thru/Go Through Sockets/Ratchets Swap/Interchange?
DPDISXR4Ti
New York
Your welcome Brad. How about letting us know what you get and how it works for you?
Will do. Might be a little while if I decide to make it an item to search for at Carlisle later this year.
That's where I got this (GS80060) set last year for $40...
Which is a great set except for lacking a ratchet handle!
R
retDAC
near Huntsville, Ala.
That does look like a great deal. Incidentally you might find one on eBay. I don't know for certain but I think the ratchets actually branded Gearwrench may have better workmanship than perhaps Craftsman.
DPDISXR4Ti
New York
After finding that none of the local Sears/Ace stores stocked the 1/4" pass-thru ratchets, I decided to pull the trigger on this Gearwrench set (8923)
Currently available on eBay for $22.22 shipped, I figure that's about as good as it's going to get. Here's the ebay link, realizing it will be short-lived link, but might be useful for someone in the short-term.
https://www.ebay.com/itm/New-Gearwrench-23-Pc-8923-Metric-Pass-thru-Socket-Slotted-Phillips-Torx-Hex-bits/122356271954?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
LXCam
I totally forgot I had those sets in both sae and metric. The ratchets are complete junk. Both states skipping almost immediately. Hopefully you'll have better luck then I did.
DPDISXR4Ti
New York
Well damn, that's not what I wanted to hear!
DPDISXR4Ti
New York
I've used this ratchet a couple times now and it's worked as designed. Since it's effectively equivalent to a 1/4" socket I haven't used it for big-torque requirements, but I've certainly used it where the GearDriver Handle wouldn't deliver enough torque.
Now that I've got three different sets of pass-through socket sets (all Vortex GearWrench), I decided to just get a dedicated toolbag for all three. I would have just preferred that they included the ratcheting handle in the GS80060 set. I even tried to figure out a way to make a space in the molded case, but no luck.
R
retDAC
Thanks again Brad. Didn't know that existed. There have been adapters for Lowe's pass thru ratchets to use GearWrench/Craftsman pass thru sockets. Some show up on eBay.
DPDISXR4Ti
New York
As the "New home of Craftsman tools", it'll be interesting to see if Lowe's starts selling/stocking the less common Craftsman tools such as this. I won't be holding my breath. So far my local Ace Hardware has been a disappointment in their stocking of individual Craftsman sockets. That was always the nice thing about Sears - how they fully stocked individual tools for warranty replacement.
JBH
Does anyone know of another set (or square/bit adapter) that’s compatible with the Facom/USAG/Wera through ratchets? Ratchets are are 11mm 12pt with retaining ring, and sockets are 6pt with notch.
I list them together because I assume they have the same OEM. Wera Zyklop FA sockets work on the USAG locking flex through ratchet.
JBH
Pix or links w/same would be helpful.
Fair enough. The attached pictures show the USAG ratchet and 7mm through-sockets by USAG (my USAG kit came with sockets stamped with the Facom logo, as you will see below) and Wera, as well as Wera socket on USAG ratchet.
Links:
USAG/Facom compact set:
https://www.ultimategarage.com/shop/part.php?products_id=8928
I do not know if sockets are available as open stock.
USAG/Facom locking flex-head ratchet:
https://www.ultimategarage.com/shop/part.php?products_id=8929
Wera set:
https://www.kctoolco.com/wera-135918-kraftform-kompakt-zyklop-mini-2-set/
Wera ratchet:
https://www.kctoolco.com/wera-003660-zyklop-mini-2-ratchet/
Wera sockets open stock:
top of https://www.kctoolco.com/search.php...th 1/4" and Hexagon 11 Drive &section=product
R
retDAC
JBH
Thanks!
That’s a source I didn’t even think to look at. I assumed the Taiwanese OEM for Facom/USAG and Wera made this tool for others as well.
I do want to avoid two ratchets taking up space in a super small portable tool kit (i-Boxx Mini) so I’ll pick one up to test and report back
I’m more likely to try removing the retaining ring on the bitholder than modify the ratchet though.
R
retDAC
That's what I meant: you might have to mod the socket.
I think the OEM is Hi Five. Or the designer anyway. Whoever could certainly make what you want, but I guess there is not enough demand for it.
R
retDAC
gearhead1
NC
Thank you for posting retDAC, this was very useful.
I use a lot of threaded rod on my demolition derby cars. I picked up a set of the pass thru sockets at Harbor Freight on clearance, they’re all there but no ratchet.
jessknowsnuthin
Some more brands for the “a”group. Halfords advanced, Wurth zebra, makita, westward, omega pro, mob, tack life. IMG_1606.jpegIMG_1597.jpeg
I have reason to believe that the Stanley/ bostitch pass thru (craftsman also made an alternate pass thru version under b&d to be compatible with these) could be compatible with bahco.
I’m not totally obsessed but it does get out of hand at times. Here’s my 1/4” and 1/2” drawers. I won’t show my stacks of pass-thru cases
Klein has a couple newish pass-thru sets. 1/4 and 3/8” drives with a weird spline drive.
R
retDAC
Welcome to the board and thank you very much. For whatever reason when this board was changed over to different software, I am not allowed to make corrections. The goofy characters also appeared then.
R
retDAC
Finally was able to eliminate the weird characters and get the system to stop believing I had 30k+ characters. Have added the others but could not find a link for a TackLife set.
KnurledNut
n/a
Thanks. Have added Klein to Group J since it appears to use the Kabo style drive as far as I can tell from pix.
I was playing with a set recently. They were standard 12-point. They may be doing spline too. I haven't been following all the releases and design changes with this system. Their retaining ring works great with the 12 point sockets and accessories.
DPDISXR4Ti
New York
I don't have any Lowe's near me, but last time I was in one I was impressed with how many individual Craftsman hand-tools they were stocking. Alas, I forgot to check if they had any individual pass-through ratchets or sockets. Has anyone else looked?
JBH
I'm confused - which group is the 11mm outer hex with retaining notches, e.g. Facom/USAG, Wera, Würth, Matco, and now I think VIM too?
JBH
That looks bigger than 11mm outer hex. Also 3/8” drive rather than 1/4”!
R
retDAC
From the OP: "Most brands of Pass Thru sets label them as 3/8", 1/4", or 1/2" Drive. This refers to the range of socket sizes for each of those and IMHO, it should be 'Drive Equivalent'."
Some brands only have one DE; others, two or even three.
The groups are designated by retention style, not DE size. In many cases I could only go by pix on the 'Net.
JasOmatic
Birmingham United Kingdom
Interchange List
Group / Brand Name / Line Name (Group notes in Post #1 above)
A Boxer Go-Through
A Clarke Tooling PRO222 Go Through (PRO221 different = B3)
A Craftsman Max Axess: Sears
A Crescent X6 Pass-Thru
A Draper Vortex
A Duralast Pass-Through: Autozone
A GearWrench XL Pass-Thru
A Halfords Advanced Vortex
A current Husky Pass-Thru; Home Depot
A former Husky Thru-Ratchet; Home Depot
A JobSmart Pass Through: Tractor Supply
A KD GearRatchet
A Kincrome P2025, K2046, & K2047 Go Through (K2045 & EVA65T in B3)
A OLD Kobalt Flex Thru Lowe's
A Makita Pass thru
A current Mastercraft Maximum Pass-Through (not the same as Mastercraft Pass-Thru in B5.)
A MOB Tools Socket Through?
A Neiko Tools? Hole Thru
A Neilsen Go-Thru
A Omega Pro Go-Through
A PowerLift Go-Through
A SAM Tools Pass Through?
A SATA Pass-Thru OEM?
A Sealey AK6919 Go-Through (AK6927 in Group H)
A SIGNET VORTEX
A TOPTUL Go-Thru
A US PRO Go Thru
A Westward GearRatchet
A Wurth Zebra Pass-Through
B1 AmPro Go-Thru Hex Geared
B1 BGS technic Go-Through
B1 Channellock Ultra Access
B1 Clarke Power Products Open Center
B1 GM Goodwrench Go Through
B1 Jackway Go Thru
B1 Listol Go-Thru OEM?
B1 Performax Pass Through; Menards
B1 Pittsburgh Go-Thru; Harbor Freight
B1 Pro.Point Go-Through Princess Auto
B1 Power Torque go-through? O'Reilly
B1 Repco Go-Thru
B1 Ultra Steel Go Through
B2 Hexa Go-Through OEM?
B2 current Kobalt Xtreme Access; Lowe's
B2 Urrea GO-THROUGH
B3 Bahco Pass-Through
B3 BILITOOLS Pass Through
B3 Bostitch Pass Thru
B3 Hart Pass-Thru: Walmart
B3 HI-FIVE Thru Drive OEM?
B3 Kincrome K2045 & EVA65T Go Through (P2025, K2046, & K2047 in A)
B3 KS Tools Go Through
B3 Laser Tools Go Thru
B3 Mac Go-Thru
B3 Stanley Passthru (These are made in China; the others, at least Bahco/Bostitch/HI-FIVE, are made in Taiwan.)
B3 Teng Tools Push Through
B4 Connex Push-Through
B4 OLD Mastercraft Maximum Pass-Through (not the same as Mastercraft Pass-Thru in B5.)
B4 Proxxon ???
B5 Am-Tech Go-Thru
B5 OLD Husky Open End Home Depot
B5 Mastercraft Pass-Thru (not the same as Mastercraft Maximum Pass-Through in B4 and A.)
C Blue-Point Pass Thru
C Williams Bolt Thru
D Gedore 19 SK
E Hazet 436 (536 in Group K)
F1 Snap-on 1/4" Drive Low Profile
F2 Astro Pneumatic Close Quarter
F2 Mountain Close Quarter
G Spec Tools SqueezeWrench
H Clarke Tooling PRO221 Go Through
H Sealey AK6927 Go-Through (AK6919 in Group A)
I Mac Front End Alignment Flex Ratchet and Socket Set
I Matco Shock/Strut/Front End Ratchet and Socket Set
I Snap-on WA309FLA Alignment Set
J Cornwell Go Thru
J Fobi Through Socket
J Kabo Cross-Ratchet OEM?
J Klein KNECT Pass Through
J Powerbuilt Bolt-Thru
J Titan EXO-Drive
K Hazet 536 (436 in Group E)
L Armstrong Eliminator
L Matco Pass-Through?
L Matco Special Forces
M Facom Hollow Ratchet
M SAM Tools PTT?
N Reed Thru-Bolt OEM?
O O-Ratchet no separate line name
Amazing write up. Had to Register to say thankyou.
R
retDAC
Thank you very much and welcome to GJ. There are many on this board who know far more than I about most tools.
I tried to do something that might help with these particular niche tools since, unlike regular square drives, there are so many variations, finding replacements might be difficult for other than, say, GearWrench.
Have been told I "need to get a life."
YoshiMoshi3
Adding some knowledge to this database thread. I realize it's an old thread, but it is very detailed. I went ahead and purchased a GW 893823
The length of the ratchet at 12" is accurate. The ratchet is ~ 11.7 mm in overall thickness at head, not including the directional switch.
10 mm, 11 mm, 12 mm, 13 mm, 14 mm, 15 mm, 16 mm, 17 mm, 3/8 ", 7/16 ", 1/2 ", 9/16 ", 5/8 ", 11/16 " are ~ 32.0 mm in overall height.
18 mm is ~ 32.4 mm in overall height.
19 mm, 3/4 " is ~ 33.0 mm in overall height.
13/16 " is ~ 34.7 mm in overall height
7/8" is ~ 35.1 mm in overall height.
