I recently picked up a free Craftsman 4HP compressor which I was told was working fine and it runs for about a minute before bogging down to a standstill and then trips the thermal switch on the motor. The guy I got it from said he never actually used it but the neighbor who gave it to him used it all the time with no issues.
I've been doing tons of searching around and ruled out the switch. I thought maybe it was the run cap so for a $9 gamble I replaced that and it still did the same thing. Bought a new multimeter (been needing one anyway) that has capacitance testing capability and tested both run caps and the start cap and all were within spec.
The motor hums along fine without the belt attached or if I keep the pressure valve open. With the belt attached it will build pressure to about 40 PSI and then bog down and trip the thermal if I let it bog for too long. This is running on a 115v 20A circuit.
What has always bothered me is the motor plate only says 230v on it not 115/230. Had a thought tonight and popped the motor access plate off and I think what I'm seeing is indeed a motor that is only supposed to do 230v correct? There are not 4 spades to move the wires around on, just the two for black and white and the green. One thing I did notice is that one of the previous owners put a new power cord on it as it is a Husky one and there is electrical tape around the spades in the switch.
Am I missing something or did one of the previous owners just replace the plug with the wrong type (115v) and this should be a 230?
