Thank you Frank. I'll give it a try and respond back.
I agree. Happy to help!Frank, I did as you suggested. The ring assembly lifts clear of the copper arm and the arm lifts clear of the contact. I have to assume the wear on arm is from the 30+ years of use in my shop. It never saw a tremendous amount of use, but the oily environment, on top of use, must have been part of it. The switch plate, and for that matter, the entire drill press was covered in caked on grease.
Thank you for the help! I'm sure once repaired and cleaned the old drill press will again function properly. And now that its in my garage, it will see very limited use.
I've been happy with Mobil Polyrex electric motor grease for bearings.Also, what is a good lube to use to repack the ball bearings if they are still good?
Do the **** connectors need to be high temp too? Do any of your videos show you doing this?Do a search on youtube for replacing lead wires in vintage motor or something similar. I use stranded copper 16 gauge silicone high temp wire. I use **** connectors and cut the existing wires about 1" from the windings. I only replace wires if they are brittle or the shielding is in a bad state. If they are just old but are in good condition, I do not replace them.
Thanks, I'm just wondering. I have a can of Super Lube Multi-Purpose Synthetic Grease. Would this work for repacking wheel bearings?I've been happy with Mobil Polyrex electric motor grease for bearings.
I would not use that grease for automotive wheel bearings or for electric motor bearings. I'm no grease expert though.I have a can of Super Lube Multi-Purpose Synthetic Grease. Would this work for repacking wheel bearings?
I found this, but there's no explanation as to what is earlier and what is later.
but I have a K4 52 motor that I can check tomorrow.
https://www.amazon.com/photos/share...g.1theTbKSCQ5NdhLnbsjv0f?tag=atomicindus08-20
If you're looking to replace with a cylindrical cap, I've had very good luck with Airstar Supply... made in USA and free shipping on most things.
Yes, but new flat capacitors are no longer available. You'll need to make a spacer to raise the base, or relocate the new capacitor.Hi Frank, I have a 1/2 hp motor that is missing the sardine capacitor. Are you still recommending Airstar supply for a replacement?
No.Do you know which model of capacitor to order?
Thanks
It is a 1/2 HP 1750 rpm 115 volt 50 cycle 6.7 amp type CNB-K8 115-6982 and I think A4-48Yes, but new flat capacitors are no longer available. You'll need to make a spacer to raise the base, or relocate the new capacitor.
No.
What is your model number, rpm, and date code on the badge?
It sure would be nice if there were a database with this info.
I believe your model number is 115.6962.It is a 1/2 HP 1750 rpm 115 volt 50 cycle 6.7 amp type CNB-K8 115-6982 and I think A4-48
I plugged this sardine capacitor from another motor and it ran (I only ran it for 5 seconds though) so I know the motor works. But, I'm not sure if it is the right size even though that is a 1/2 hp 1750, too.
Thanks Frank, I asked Airstar and ordered what they recommended.I believe your model number is 115.6962.
I looked through several years of my photos and found four 6962 motors with a snapshot of the capacitor specs. However, all four motors were later than yours, 1952 to 1954. All four had the same 124-155 mfd specs as your test.
I'm no expert and won't make any recommendation. If you call Airstar, they should be able to help.
I know there are a couple posts here. You'll have to search.BTW, do you know of any post or video where someone made a spacer for the newer capacitor?
Hi, back to the motor question, the motor works but is got a intermittent issue. Sometimes it just hangs there won't go full power or it cycles slowly, drawing too much power if i leave it on. Now I took it apart before, nothing weird found measure the can is well with in spec. Now the only, way to get the motor to work properly after the hang up, is to tap very gently on the pulley side(arbor) I mean super gently, sometimes if I spin the blade by hand it also works.Any ideas ??Tubes, what are you using this motor on? The RPMs are 3450, for a table saw that is good but for a band saw or drill press that is too fast. I did not find a diagram for this motor but if your capacitor is round and sits inside the stator this this should help. http://vintagemachinery.org/pubs/222/6042.pdf
Thanks for the very informative reply, how do I fix it. I did play with before, but I don't know anything about the centrifugal switch.The centrifugal start switch is hanging up. If it doesn't disengage the start winding, the start and run windings will fight with each other and the result will be very high current and very little power.
Tapping on the shaft will loosen up the switch so it works.
Thanks@miter19 , I would say at least 1980s or newer. The M12007 on the tag may represent Jan '07, not sure.
The MFG NO, 11853, is the date code; November’85.I was wondering if someone could perhaps offer some help as to how old it may be using the info in the pic.
I don’t think so. Plug it in and listen for anything unusual.Are there any inherent issues that may arise from something sitting unused for so long.
I’m not sure if NOS makes it worth much more.And if anyone would like to give an opinion on it's value, that would be great.
Thank you so much...Latham, NYThe MFG NO, 11853, is the date code; November’85.
I’d probably list it for $100. Opinions may vary on that.
Where are you located?
Well, if I had a sticker printer, that would be the way to go. Wasn't there someone here making repros a while back? Anyone have a contact?Beerhippie, I may have a replacement. I had one that just died on me and I saved the middle band in case I got another similar one. Let me check. If not, it is probably just the generic CM crown top logo. Find it logo @ VM or others, resize to match, print sticker, replace.
Thank YouThat motor has sleeve bearings, they need to be oiled once in a while. After sitting for that long, the bearings are dry and will seize up if not oiled.
The first thing I'd do is oil the bearings. There could be small rubber plugs in the oil holes, one on each end. Remove the plugs, put about 20 drops of oil into the holes (electric motor oil is best, 10W or 20W will work well too) and leave it sit for a couple of days before starting it.
I reconditioned the same Craftsman motor awhile back and also need a replacement sticker...Well, if I had a sticker printer, that would be the way to go. Wasn't there someone here making repros a while back? Anyone have a contact?
This would have had the Craftsman crown with General Purpose Motor below.
Thanks! That was the fellow I was looking for, but didn't want to search through five pages of posts to find.I reconditioned the same Craftsman motor awhile back and also need a replacement sticker...
You might want to contact GJ member Matt Blast for a reproduction...
He made mine and did an excellent job...
