Show Your Structural (SPUD) Wrench
Lassen Forge
Aw ****, I wish I had some of my old spud wrenches around... IIRC the largest was 5" (migh have been 5 1/2 or 6" - it was a big honking mofo)... the smallest was 1 3/4... used them extensively for bridge bolts... we had specially made 6-12' (yes 12 FOOT) extension handles (cheaters) that weighed about like a small sherman tank to handle the torque involved in some of them... I hung off one (open air at 175') to get a 4" tower bolt loose on the bay bridge, I was double harnessed in in case the thing slipped or broke. But yeah, Those were some awesome tools.
Beerhippie
Far NE Oregon
Here's my "newish" Armstrong adjustable:
OAL is 16". I inherited it with the shop, but I know we used it 25 years ago when we were building out our brewery.
The number of uses I've found for the spud over the years is impressive.
Wondering why open end appeared to be the standard over box end?
I agree with Jock. I would add ease of access. The opening will find and slip onto a nut more readily without lifting and placing. I have a few though. I posted a huge Plomb in post #16 on page 1. I got curious and checked a bunch of catalogs. Williams did not introduce a box end wrench with a structural or construction pattern (i.e., colloquially, "spud") handle until Catalog A-409 in 1943. For Armstrong it wasn't until 1957. Plomb in 1939. There are three Woodings Verona catalogs on IA/ITCL. The oldest, probably 1920's or 30's, is not dated. A catalog dated 1949. And a much more modern catalog, guessing 1960's or 70's. None of those offer a box end spud wrench.
PSCo1867
PA
Here's a trove of Bethlehem Steel Corp spuds: 5/8" REG-2pcs; 5/8" HVY-2pcs; 7/8" HVY-1pc, 1" HVY-6pcs; 1 1/8" HVY-1pc; 1 1/4" HVY1-pc. I've always been curious as to who actually made the BSCo wrenches, as Bethlehem was not known for making commercial-variety tools. Possible clues may be the forging marks "O" or "B" which are present on all these spuds. Another observation is that some have raised lettering, while some have stamped lettering. I've always thought that Bonney would be a good possibility, as they were located nearby to Bethlehem. I'd love to know your thoughts/opinions on this: Who did BSCo contract with to make their spud wrenches?
Wow. What a lineup!
Bonney is a good proximity guess. You might be able to do some visual comparisons. Are there any Bonneys on the thread? I don't have any. I was looking at my Williams, and I have to say, the shoulders, where the rounded handle necks down to the shank, looks different.
Book: https://books.google.com/books?id=f...=2ahUKEwjq5JWR6NmHAxXcF1kFHRPAETQQ6AF6BAgKEAE
PSCo1867
PA
Wow. What a lineup!
That's a good idea: do side-by side comparisons (BSCO spuds to other brands). This will give me a good reason to round-up and organize my spud pile.
And, I had no idea that BSCo had a formal Small Tools Department, complete with catalogs. As soon as I figure out Google books, I'll be reading them for sure.
Me neither. I was pleasantly surprised.
That book is not available digitally, in PDF or eBook. If it had been, you can be sure I would've posted some excerpts.
Google Books, in the spirit of open source and open source foundations that I admire, very helpfully, magnanimously includes printed books that have not been approved for their project in their system, though, and even points you to the nearest sellers and libraries where a print edition can be found. I have ordered a lot of references from Interlibrary Loan that way.
Clicking on that link in this case indicates that Hagley Museum and Library, 298 Buck Road, Wilmington, DE, 19807, has a copy. You might want to call them tomorrow. If it's in their collection and available to view on a visit, I could plan to stop in next time I go down that way, which is fairly often. I would takes notes, and photos, if possible.
PSCo1867
PA
I'll Give Hagley a call to see if they have the Bethlehem Steel "Small Tools Department" books available for viewing. Thanks for your offer to stop by for a little research if you're in the Wilmington area. So much information hiding out there in seemingly unusual places.
leg17
Kentucky
A trio of earlier Williams Spud wrenches. All marked Brooklyn.
(Williams called these offset style STRUCTURAL wrenches while the straight ones were called CONSTRUCTION wrenches.)
My daddy was an ironworker out of local 1 in Chicago. He worked on the Sears tower. He called them all SPUD wrenches.
Armstrong model 906B Spud Wrench
marked "1"
milled opening size is actually 1-3/16"
oddly, the 1935 catalog shows it as having a milled opening of 1" (I was not able to find it in any other catalogs.)
marked "HARDENED" on opposite side just below gullet
Armstrong model 906B spud wrench
marked "1"
That's a couple hairs larger than the differences all my spud wrenches measure between nominal milled opening and spec, but I am going to assume it's the rough nut clearance thing. If you look at the annotations at the very bottom of that table excerpt you attached, you'll see a caveat to that effect. All vintage catalogs have a similar caveat on their structural and construction wrench pages. Some catalogs are much more explicit. Williams, for example, says something about the actual openings being larger by some fraction. I can't remember how many 32/nds off the top of my head, but the difference you are measuring between the opening and the marking and the catalog is probably planned. If not, maybe spread from use, or a little of both.
john.k
A lot of big structural bolts and nuts were roughly made and the heads had a lot of taper -- forging draft it was called .........one bolt maker here called Trojan used to make the roughest bolts and nuts Ive ever seen,and Ive still got bags of them ......I had planned to use them as stay bolts in the 'mythical' boiler I have been threatening to make for 50 years now.
B Halverson
I rode my bicycle past a dumpster on 15th street a few weeks ago and this wrench was laying right on top. I grabbed it and put it through the belt holding my pants up and rode home.
FourthQuarter
Cape Ann
New additions to my collection. New old stock at auction for $18.56. Nice day here so gave them a quick wire brushing.
