Puget Dude’s creations and fabrications (Random project thread.)
P
PugetDude
Superstition Mountains, AZ
Making progress...got the carb adapter machined, surface finish wasn't that great so I lapped the mounting surface on my surface plate with a piece of 180 grit wet and dry sandpaper and WD40. IMG_20240925_145356741.jpg
It fits the Goldwing engine and the new carburetor perfectly.
Happy with the test fit, will start putting everything back together today. IMG_20240925_145455776.jpg
This carburetor is a knockoff of a Weber 38/38 Two barrel. I chose it because the 38mm barrels are the exact same diameter as what's on the original Goldwing carb.IMG_20240925_145439740_HDR.jpg
This one comes from the highly esteemed Chinese carburetor manufacturer "Thundermingo"🤔
and comes with both manual and electric choke options, @$70 delivered via brown truck from Amazon.
I have 30 days to see if it's going to work, if not I can always send it back. This is more of a proof of concept exercise, I may end up with a genuine Weber($400+, made in Spain) or something different altogether.
Bob Heine
Boca Raton, Florida
Scott, I fell in love with Weber carburetors when I had a pair of Weber 40 Dual DCNF carburetors on my Fiat X1/9. The previous owner of the setup put the wrong jets and venturis in them and the engine bogged, coughed and sputtered (and belched black smoke like it was a diesel). Using the Haynes Weber manual I figured out the right setup and it was night and day. The Webers are the most customizable carburetors I've ever owned.
P
PugetDude
When I had my Jeep shop many years ago I installed a lot of Weber conversions on AMC straight six’s. They work in a broad range without having to change jets. Around here it is easy to gain six thousand feet in altitude and the Webers didn’t seem to care.
I hope that's the case here. Probably get it to the point that I can find out sometime tomorrow.
Got the carb adapter mounted, since it's on rubber isolators I elected to add a simple brace to help stabilize the new carburetor. The Goldwing carb and air box is tightly surrounded on the bike, in this case it's open on top of the motor. Used a piece of light gauge 1/4 ID" tubing, slid a piece of 1/4 all thread inside it so I had something more substantial to weld the mounting tab to. Welded a 1/4"-28 UNF stud on the other end for a Heim joint to give me some adjustability. Going to need a longer stud on the adapter and a spacer for the Heim, but it looks like it's going to work.IMG_20240926_193848455.jpg
Next order of business was to get the exhaust back on, and then get the motor back in. It's really easy to pull and install the motor with the gantry crane and an engine leveler. Only takes a few minutes. IMG_20240926_160612648.jpg
IMG_20240926_164402031.jpgStill have to put the mufflers back on, temp up the wiring (again) and get the radiators on so I can try to fire it back up with the new carburetor.
Fingers crossed for tomorrow....🤞
Old Man Roger
Palm Coast Florida
You probably already know this, but the gas tank has to be vented. I have a vented cap on my generator that has an on off switch, the generator won’t run long if you forget to turn the cap on.
P
PugetDude
Thanks for the heads up, Roger. The cap is vented, the tank was constructed by an old-time hot rod builder just for engine start-up testing. The threads on the cap have a vertical slot cut across them, just enough to vent the tank when the cap is loosened. Pretty ingenious.
@readhead gave me the tank when I visited him in Durango recently.
Old Man Roger
Palm Coast Florida
The cap is vented.
I figured you knew, just wanted to mention it just in case. (y)
What are you going to run for a permanent tank? A small fuel cell would probably be all you need for that motor.
P
PugetDude
Finished welding up another rack for the ubiquitous yellow and black HF storage cases. Had a well- meaning friend give me a few lengths of "salvaged household ferrous boudoir nocturnal furnishing support frames" (aka bed angle) a while back and I decided this was a good way to get them out of my way and put them to work.
As everyone probably knows bed frame angle is harder than a honeymoon pr*ck,
almost impossible to drill, and somewhat wonky to weld.
I used my old tired DeWalt chop saw to cut everything to length, and knocked off the rivets with an angle grinder. Ended up with just enough of the angle to build the stand. I did do something different on this one, made the top two rows to fit the half-width cases. Top and bottom front stringers are 1/8 x 1-1/2" flat bar; couldn't use angle without changing the case spacing. Since the bed frames were different thicknesses I had to use opposing pairs to maintain spacing- used 5" for the thicker cases and 2-1/2" for the thinner ones. And, yes @readhead I did use a piece of diamond plate to double up underneath the bottom front stringer- just for you.😉
Had a set of 3" locking swivel casters from Amazon Warehouse Deals, so I plug welded them on.
Back is a piece of expanded metal, I had lying around, I got tired of moving it every time I was pawing through my steel inventory- and it should prevent the rack from racking when I load it up with hardware...hmmm, that sounds like an oxymoron.🤔
Finished weldment got two coats of gloss black spray paint because I already had it.
Still need to glue up a 2x wooden top for it (which will bring it up to my bench height) but it's workable for now. IMG_20240925_164048454.jpg
Bob Heine
Boca Raton, Florida
Scott, that's brilliant. I don't have any of those cases but your storage rack flipped a sleeping brain cell (or three). I need to cut up a length of rain gutter downspout I saved back in February. I couldn't remember why I shouldn't throw it away until I saw your post. @shopnut used pieces of PVC downspout to organize his metal collection. My downspout is aluminum but it should serve the same purpose.
P
PugetDude
Update:
It runs!
Got everything temped up, crossed my fingers, turned the key... It turned over twice and fired right up!
Idles great, accelerates smoothly, no stumbling or hesitation,
BUT... Has a nasty exhaust backfire if I let off the accelerator abruptly. I can bring it down slowly and reduce the frequency and severity of the backfire but not eliminate it completely. Adjusted the idle jets on the carb, checked for exhaust leaks, plugs, wires, etc. I do have the stock vacuum line going to the ECU. Even tried temping up the Honda airbox to see if that makes a difference. Not really.
Does not backfire through the carb, just the exhaust.
Have a Weber jet kit on order, will try that next. Currently jetted at 45, might just be too lean. let's hope it's that simple.
Ideas, thoughts suggestions, criticisms, complaints, snarky comments welcome.😉
(Weber 38 carb on a Honda 1500 Goldwing Engine in a 32 Ford Roadster isn't something that yields much help on a Google search.)
Bob Heine
Boca Raton, Florida
Scott, popping from the exhaust usually happens when atomized fuel reaches a place in the hot exhaust system where it can mix with air and explode. When the throttle plate closes, vacuum goes way up and a bit more fuel gets sucked out of the carburetor. I believe a long exhaust pipe and muffler can cool things down enough to minimize that popping.
Finallygotit
Tucson, AZ
I had that issue with the Cobra when I would back off the throttle. It wound up being a blown exhaust gasket. Replaced them with an all metal compressible gasket and the issue went away.
BTW, great job getting it running!
:beer:
TimeWarpF100
not here
Temporary exhaust ready to go back on. Offset is for the driver's side to clear the shift linkage.
After seeing how easy this is going to be I may end up fabbing the finished exhaust myself- was initially planning on taking it to a muffler shop. (But I will use mandrel bends instead of miter cuts.)😉
I know someone who owes ya a favor that could do exhaust..
TimeWarpF100
not here
Did you find someone to repair the cylinders?
Yeah. Kinda pricey but seal on other cyl visibly coming apart too.
Don’t realize how valuable a tool is like hoist until it no longer works.
AC, Air Compressor, garage door opener, hoist and transmission jack all went south in couple weeks time. Robert always says he would rather be lucky 🍀 than good.
Good thing for bad luck or wouldn’t have any luck at all!
