Hubmonkey
OK
Oil Change and transmission drain and fill on the wife's 2018 Accord... CCV Filter change for the 2015 RAM to get the annoying "Perform Service" ding reset. Up next will be Fuel Filter changes on the RAM and a brake job on the Accord with a brake flush as well.....
Hub
kaymccampbell
Upstate New York
Grabbed a piece of scrap timber for a shop project, it had a decent warp in it so I actually used my jointer and thicknesses to straighten it out with some degree of success. Approx 27" long and close enough to 20 thou difference between edges.
I'm pretty happy with that as I haven't really used the jointer for any projects only a few test goes and I never really felt confident, the new push paddles I made are a big improvement over just using hands. The finish from the jointer is a bit 'choppy' but I'll work on that
Slow down your feed speed. Check the sharpness of your blades.
oldman_pottering
Tinonee, NSW Australia
Will do, thanks
The blades seem 'ok'.............a couple of nicks outta them and not super sharp. I bought this machine second hand and went through the process of setting the blade heights ( that was a pita) but didn't want to get new blades until I get familiar with the machine, but as I type this that seems a bit counter productive, trying to learn with a machine that is not as it good be................seems a bit stupid now, I'm going to search for some new blades
Ultradog MN
Twin Cities
16' 14K trailer won't fit IN my garage.
Too much junk in there.
Yesterday - on the concrete apron in FRONT of the garage I put new brakes on it - new drums and backing plates. Today I put a new radiator in my tractor - also on the apron.
Will get the sheet metal and grill back on tomorrow
DGersic
DeKalb, IL
More sanding.
Then took an unplanned break from sanding when the sander decided that it didn’t want to sand anymore.
Some Bauer surgery:
Turns out that I didn’t need to remove the gearbox from the motor. Could have saved a few minutes there.
The points in the power switch were arced and not conducting. Confirmed with meter, no power through the switch. Disassembled and filed the points:
Need a new switch, I broke the little hold-it-together snap tabs in taking it apart. So it’s currently wrapped with electrical tape. That’ll hold for now.
Reassembled:
And back to sanding. Got done with the garage. Next up, sanding the shed. Yay.
southalabama
Brewton AL
Worked on a wall. 3/4” t/g plywood
End is 8’. Leaving it at that height.
On long wall it will go up to roof. But need to pull wire first. Then cut plywood for slope roof. But I’ll may paint or prime the cut pieces first so don’t have to paint 12’ in the air
2x6 studs.
I’m beat.
kaymccampbell
Upstate New York
More sanding.
Some Bauer surgery:
Reassembled:
The switch on my oldest DeWalt angle grinder has been held together with 33+ for 10 years or so.
Jgaz
I volunteer at a county conservation area in the north valley doing trail work, repairs, etc.
We have a job coming up to change a number of the trail marking signs.
The provided sign holders don’t fit the sign posts we use and the compatable posts that came with the signs are way too wimpy to pound into our rock hard ground.
I came up with this prototype adaptor today.
A 1” cross drilled ******, 6” long, and a 2” to 1” bushing.
The plastic spacer moves the bushing down so the set screws bite into the threaded OD.
Way easier than pulling or cutting off the old posts and driving new posts that are strong and also compatible with the new sign holders.
oldman_pottering
Are you cleaning the steel? Is your gas flow high enough, but not too high?
yes to cleaning, I don't really know the correct procedure for setting the gas flow although that being said sometimes during the weld it goes real quiet, no crackling and it makes a light woosh type sound, no idea what happens at this time, maybe I move too far from the workpiece although I generally weld close for not much stick out
micromind
Fernley, Nevada, about 30 miles east of Reno.
Will do, thanks
If the nicks are small ,simply sliding one blade to the right a bit and another to the left will solve the problem.
kaymccampbell
Upstate New York
MiG gas flow for mild steel should be between 15-25 CFH. So if you set it for about 20, it should give you a good baseline.
I typically do about a 10-13mm stickout for steel.
larry4406
Northern Virginia
More sanding.
Some Bauer surgery:
Reassembled:
What are your thoughts on that Bauer sander machine? They had it on sale recently and I thought about it ever so briefly.
Old Man Roger
Palm Coast Florida
Is your tip clean? Almost sounds like your wire feed might be slowing down periodically.
kaymccampbell
Upstate New York
He could also have bad roller tension, worn/wrong rollers, a dirty/damaged liner, wrong tip , a bad ground, a loose wire, something broken, you-name-it. Or just bad luck. I've never heard a whooshing sound from my MIG machines. Course I'm most of deaf, so it could be below my threshold of hearing.
DGersic
DeKalb, IL
If you have a use for it, it’s a good sander. I bought it last year to prep (scuff) my house for painting. The included flap wheels worked well for that. I got the resin brush wheel from Amazon, which worked well on my gutters. It‘s kinda heavy, but that’s not a knock on the Bauer version, my friend has the Eastwood version, and it’s the same.
kaymccampbell
Upstate New York
I've had one for a couple-ish years. It does great on ripping off rust. It makes a nice brushed finish on bare metal. I mostly use it to give a rustic finish to stumpkins nowadays.
kaymccampbell
Upstate New York
Ya, I've heard it before. The wire will stick for a second and burn back to the tip, once it burns back to the tip it starts feeding again. Welding things like old dumpsters and dirty trash trucks, you know Kay, you been there.lol
Never heard it, but I've seen it. That sounds like crud, rollers, tip, liner. I'd change the tip, then check the rollers.
KwikFab
Central Valley, CA
Haven't done much of anything lately until today.
To start, I got a few parts together for putting together a drain and refill system for my CNC table.
And here's a mock-up. I need to buy a transfer pump and wait for my stainless hardware to arrive so I can mount the flanges and glue everything together.
Water from the table will drain through 3/4" PVC into the reservoir below, but only after it runs through an in-line filter I've got in place.
The threaded plug at the bottom of the reservoir will receive a 1/2" barb where I'll run a soft line to a transfer pump, and the outlet of that pump will go up the second ball valve to act as a means of refilling my table.
Another item that showed up was a torch mount from Beck's Armory. When I got the mount, I quickly saw what an improvement the clamp-style is on this versus my factory one.
Rather than creating pressure points with it's V-style clamp, the new mount is sized for specific torches.
Last but not least, I cleaned up the garage as best as I could.
Before today, you could barely walk through as I had boxes and hardware everywhere since I had disassembled my plasma table and squared everything up all over again.
One of the fabbed up bumpers gets picked up in a few weeks, the air compressor will go back to its respective spot, and hopefully my Z-axis assembly should arrive. I was running into a small binding issue and when I asked about what parts to order for rebuilding it, Langmuir opted to extend my warranty and send me a complete new one.
The old one.
Picking up where I last left off.
This Friday I got motivated and started plumbing my table.
From enlarging the holes in my table, to sandwiching stainless steel mesh to act as a strainer in my drain, to testing for water leaks, I was motivated to get my table cutting this weekend.
Why? My Z axis assembly was to arrive that Friday.
Everything was cool and dandy, and I was stoked to see my replacement included a free mount to the gantry.
The old next to the new.
My heart sank when I found this though; the tab arrived broken off of the new assembly.
The tab holds the spring for the IHS part of the assembly.
Without it, IHS and THC is rendered inoperable. So I have to wait until Monday to reach out and ask if I should send it back and wait for a replacement, cannibalize it and swap parts to my old one, or?
Here's the old mount, new (broken) Z axis assembly, and old Z axis assembly.
So with my CNC table being down for over a month now I'm not really sure where I found the motivation to trim the bushes, edge the sidewalk, mow the grass, and even pressure wash my entire driveway today 🤣
I even pressure washed the truck.
Electric tools definitely make things quick and easy. So glad I made the switch some 2+ years ago.
KwikFab
Central Valley, CA
Nice rides!
Yea, my last few orders have been hit or miss on the magnets. I think I had 3 of those, gave 2 away to buddies that didn't have those yet
They're long gone but thanks!
Aside from my old man vehicles I own now, all that's left is my C4 and C5Z that both live in a garage I pay a space for (old pics).
