Show us your handplanes
ararat
Ararat NC
Took a risk on the ugliest Record 073 on eBay and it's cleaning up nice. I've wanted one forever, but now that I've used it, it feels comically oversized and at least 2 pounds heavier than it needs to be. It is pretty and it takes micron thick shavings with the grain but cross grain, I'm not sure it's much better than a wooden skew rabbet plane you can find for $10. I'll keep messing with it but I'm considering this part of my weight lifting protocol for 2025.
Looks great. Record and Preston made some great looking tools.
milkovich
Akron Ohio
milkovich: It looks like you're not the only user that had trouble with cross grain work using the 073. Eventually, Record made it with an adjustable mouth.
This one does have an adjustable mouth. The prestons that @ararat mentioned don't and consequently, though older and prettier, they're a little cheaper. I have the mouth choked up, but I'm going to put a factory bevel on it and see if I can get it to work better that way. My other adjustable mouth planes can go across grain without "rolling" the fibers out, but they are at a higher angle (9 1/2 for example). This plane does work very well on end grain and with grain. Maybe I just need to try it on some hardwood (I'm just in the middle of building a mortise/tenon desk for junior out of white pine). After I finish this desk the next project will be in cherry so hopefully this plane pulls its (substantial) weight there.
ararat
Ararat NC
Successful transplant. I got these two in a box of planes and parts. The #15 had a cap that was broken and the #9 1/2 had a good cap but the lever was broken
I used a hacksaw and a chisel to break the good lever out. Lightly peened the pin back to round. Cut the bad lever off the 9 1/2. I installed the good lever and carefully peened it again with the 2 oz hammer. I just knew I was going to break the good cap, but I only missed the target a few times and nothing broke.
So now the 9 1/2 is cleaned up and the 15 still needs a cap. Cheapest one on ebay is $25 dollars + SH, which is probably more than the plane is worth. I will just wait for a donor plane. I already have a 15 like this anyway. I did find a parts plane for cheap for a lateral adjuster for the 9 1/2 that's on the way. Possible bad news on the 91/2 cutter if you can see from the picture. 20250207_083723.jpg20250207_083758.jpg20250207_083812.jpg
The excelsior body collection keeps growing. 15, 18, and 9 1/2.
milkovich
Akron Ohio
I would check with https://just-plane-fun.myshopify.com/ I've bought several things from him and he is usually about 1/2 the price of ebay and charges you the actual shipping. Just a heads up though, I haggle (always) and I don't think I've gotten him to move a dollar lol.
ararat
Ararat NC
Thanks for the link. They didn't have the part I needed, but they did have the tap and die for the handle hardware, so I got that to fix a couple of planes with handle issues.
milkovich
Akron Ohio
He can only show a small sample of what he has in inventory (since these are 100 year old tools, there's no automatic inventory system) but his hoard is massive and he specializes in stanley. I typically go through Facebook but he probably answers through his website as well.
ararat
Ararat NC
Ok. I will try send a message through the site then. Don't want to reawaken the Facebook account if I can help it.
Jim C.
What‘s your favorite plane size/type? My personal favorite is the # 4 1/2 or 604 1/2.
ararat
Ararat NC
Nice lineup. You have a great collection.
Here are some of my favorites for using. Record No 076 bullnose, Stanley 140, Union No 3, Stanley 40, Union 4 1/2
I got the No 40 without an iron, but I had a Hernshaw brothers iron that fits perfectly.
ararat
Ararat NC
Well the donor plane with the lateral adjuster came in and I couldn't get it to work right with the number 9 1/2.
Apparently they didn't start with the lateral adjuster until 1895. So, it and the incomplete 15 are from before then.
The ones with the adjuster have an area around the screw machined down to make room for the adjuster. $15 bucks down the drain lol. At least the 9 1/2 is complete.
During my researching, I think there is one year where my complete No 15 would have been made with this configuration 1897. I like when I can get the model year down to a small window.20250210_104027.jpg
milkovich
Akron Ohio
The 78 is kind of plebeian but from a woodworking perspective, it's a super star. It has a nicker and with the later thumb depth adjuster, it's very nearly the perfect wood machine. It will clean up tenons, it can act as a bull nose, it can cut rabbets in end grain. From a function standpoint, not many planes are actually as good at as many things in my opinion. I wish stanley had made a version with an adjustable mouth and had nickel plated it. Like a "78 1/2." Maybe even a rosewood handle (and a knob like the 46?).
milkovich
Akron Ohio
On page 45 of the thread we have to have at least one Stanley 45. IMG_7537.jpgI scored this at a big tool auction in Amish country last week, I already have a 45, but this one was "complete." The box looks like it's been through the war (both actually), and it's missing instructions and the little envelope with extra spurs, but otherwise it's mostly complete. The cam stop looks like an early design, I'm not sure if it's correct for a 7B. I'm also not sure if the box/logo is era correct. I found a price tag from an antique store in the box, so at some point it was in a reseller/dealer's possession, so it's hard to say if he pieced it together or if these parts have been together for over 100 years.
here you go -
Stanley Model 45 woodworking plane
milkovich
Akron Ohio
here you go -
Looks like I'm missing the front small depth stop. Those are actually not too hard to find. The irons, box, and cam stop seem like they're correct for a type 7-8. It's also cool that the 1/8 groove cutter isn't broken at the adjuster hole. Those usually snap since there's so little metal there.
lrhredjb
Central IN
Jim C. Here are some pic's. The black paint is in good shape so I plan to keep it. Will you be able to answer my question about the missing knob. The threads do not appear to be SAE. Metric comes close. Are the screws proprietary (one of a kind), and are knob screws for vintage planes the same?
Yes, Stanley used proprietary threads on its plane parts.
Ebay, flea markets , garage sales could be good sources as well as web sites. Lots of collectors out there.
Beerhippie
Far NE Oregon
Stanley also made planes for other brands. I managed to find a (cheap) no-brand plane that supplied the adjusting wheel for my #5 Bedrock.
I have a small collection Stanley of knob screws. If you can give me an idea of the length you need, I'll take a look.
The post he replied to (koken's) was from Page 1, 2015, not sure he's still looking.
Farmer J.
UK, Cornwall/Hertfordshire.
That's a nice one(y)
I bought a NOS no. 45 still in original cardboard box a while ago, but it's only about half the age of that one. At least it's old enough to have wooden handles.. I will now be motivated to take some pics of it, I keep walking past it thinking 'must post that up on the GJ':rolleyes:
ararat
Ararat NC
Nice find. These planes were meant to replace the "hollows and rounds" wooden planes I guess. Definitely wouldn't take up as much space.
I have the craftsman version of this plane. The notch on the cutters are a different shape than Stanley. It's made by Sargent. My dad gave it to me several years ago, he found it in an antique store. I got all the cutters from ebay. 20250220_145314.jpg
Sargent 1080 or 1085, depending on how many blades you got with it. I have a 1080, and three sets of blades, none of which were complete, and all have varying degrees of rust. Need to finish that project, and move the extra blades on. The two extras were both bought at GS or ES, guessing someone bought the plane w one blade, and missed the roll of blades.
I was gonna say, I have to wait many pages to post mine, but I can do something on the next page.
milkovich
Akron Ohio
I think they were really to replace the wooden plow planes, I don't think anything can replace a real wooden molding plane except a router/shaper and even then, you'll get machine marks.
ararat
Ararat NC
Mine has hollow and round cutters along with the plough cutters. Obviously not the largest sizes you would have with wooden hollows and rounds set.20250220_161147.jpg
milkovich
Akron Ohio
Ah ok, I was talking about the 45 type planes. The Stanley 55 and Sargent 1085 definitely had the wooden molding planes in their sights. I can get the 55 to make molding, but the wood has to be A+ clear and straight and I have to cut with the grain or it's a disaster. I think the wooden molding planes are a little more forgiving.
ararat
Ararat NC
Ah, now it makes sense. I was confused on the model numbers.
lrhredjb
Central IN
I usually use a #4, sometimes a #5. Last year I found a #3C body and I plan to get enough parts to make it into a user. All Stanley planes of course. Recently found a nice Keen Kutter block plane I will start using.
ararat
Ararat NC
Stanley made some Keen Kutter bench planes so the block plane could be Stanley, too.
ararat
Ararat NC
Got this little fella with a group of rusty planes and parts. Union 101 plane. It's got most of the japanning but it needs sharpening. Last picture is with my other mini planes. Two Stanley planes and a Craftsman right to left. 20250220_144055.jpgScreenshot_20250220_203641_Chrome.jpg20250220_144622.jpg
haven't done anything with it yet but my joiner friend says it will be a nice toy to keep me amused..
I like my #50 much more than the 1080. Never pursued a 45 until recently, when I found one cheap, have yet to use it. Not sure the difference between a 50 and 50s, but at a glance does not seem like much
ararat
Ararat NC
I think the 50s has less cutters included than the regular 50.
ararat
Ararat NC
Here's another of my favorites ( I have a lot of favorites haha). Very early Stanley no 36. I think it is a type 2 if I remember. It's been awhile since I researched it.
The customization of this plane is cool. The thin Stanley blade was replaced with a big beefy Butcher blade. A steel sole was added. It looks like the old owner added it early on, because it shows some wear, but the wood body is still thick. A lot of times the transitional planes have been worn down so much that the wood body becomes too thin and often get re-soled.20250227_080423.jpg20250227_080441.jpg
ararat
Ararat NC
Ebay find. $55 dollars free shipping. I couldn't resist. Record 311 shoulder plane. 20250228_111410.jpg
It is missing the small nose attachment but I probably wouldn't use it like a small bullnose anyway since I have several of those.
kwigly
Ontario
For Ararat: a custom transitional plane, similar to the style of a Stanley 35, with brass/bronze castings including an innovative cap on the handle top. When I got this at a local auction the brass was oxidized black and it was missing the blade adjuster wheel and post. But it cleaned up nicely, I scavenged the blade adjusting bits off another plane, sharpened the blade, and made a few shavings.
ararat
Ararat NC
I don't recognize the adjuster wheel. What type of plane did it come off?
That's really cool. It would be easy to miss the upgrades from the first picture. I would like to see a few more pictures if you get a chance.
Are the rest of the parts Stanley #35 parts? It looks like it could be a new wood body too, but I can't tell from the pictures.
