Above 1200 Sq/FT LilScorpion’s Fab Space
cccoltsicehockey
Charlotte, NC
@lilscorpion Did you see the new Bambu H2D? I know you were considering one more before, so does this cause you to lean into another once since it is a bit different and can print larger? Can't wait till it hits real world users since it seems Bambu keeps reviewers from supposedly saying anything negative about their products.
kaymccampbell
Upstate New York
Clough42 has a decent review. He's got the good and the bad in his review. He claims to have run his for a few hundred hours.
cccoltsicehockey
Charlotte, NC
Link to the video...
Edit: TL:DR, It just works, like he has come to expect from Bambu. Jump to min 25:00 to hear the "Yes, but" comments.
Good video. Thank you. It will likely be between the X1C and this come this fall when I look to buy. I was wanting larger for less pieces for tool drawer holders and this might solve it.
L
lilscorpion
Colorado
Yeah, watched the videos early this morning. Im curious but not totally interested. May be because im not advanced enough in my printing skills. Maybe the most compelling in the video was how Clough printed a tube with integrated TPU gasket. That’s freakin cool as hell.
L
lilscorpion
Colorado
I’ve been working on some new drawer organizers now exclusively in Fusion 360. Im starting to tackle some of the more frustrating things to grab. An example is the collets for the rib-nut gun. I was keeping them in a cup like thing which caused all the parts to more or less stay mixed up. That then encouraged me to keep the most common ones in the drawer outside the cup which allowed parts to get scattered in the drawer. No more.
Next is the hole saw drawer. Most of my hole saws are Morse with the integrated shank. They’re awesome for fabrication but totally **** to store. I’ve resorted to storing them face down which does work well but also scratches the snot out of the drawer itself which drives me nuts. These organizers allow me to store them face up. I’m still working on the Tetris of them and will like change the size of a few to better interlock but I’m close. After going thru the collection I realized I’m about 5 short of a full set 5/8” - 4 3/8” so I went ahead and ordered the remaining few. You might be wondering what the heck I need with so many hole saws…well before CNC router I fabricated templates for repeat operations and used a hand router.
Next up are the tap drawers. I have a **** ton of taps but it turns out I have way less of specific ones that I thought (like taper taps). Instead of having to refer to a drill tap chart I decided to add those details to the trays themselves.
Add that detail, and keeping the drills and taps right next to each other (instead of above/below like in the old shop), it should be way faster to get the setup I need for any given thread.
This drawer will give you an idea of what I’m shooting for but will need to be tweaked more than a little before it’s done because some of the organizers I printed I don’t need. E.g. I’ll always have spiral point and spiral flute taps in every size because I use them primarily in the knee mill and tapping arm. Tapers I like for starting threads when power tapping on the lathe (tho only really good in larger sized taps). That said, I never buy taper taps so I have way less than I used to which eliminates the need for having a dedicated place for them.
Last for how, Celco organizer. Cleco’s are a rarely used tools for me because I rarely do sheet metal work. I’ve been content keeping them in a little cardboard tray in the corner of a drawer but always disliked the digitization of doing so. This will be way better and make reaching for them enjoyable.
XJSuperman
Central Iowa
...Last for how, Celco organizer. Cleco’s are a rarely used tools for me because I rarely do sheet metal work. I’ve been content keeping them in a little cardboard tray in the corner of a drawer but always disliked the digitization of doing so. This will be way better and make reaching for them enjoyable.
Now theres a model I can use. I need to check on my tiny cleco collection that I never use becuase I don't much like sheetmetal work either.
Those drawers are really shaping up. Must feel amazing to be getting all that stuff off of counters or floors or wherever you keep unpacking it from!
SilverJimmy
Prescott/Flagstaff, AZ
I have a quick question…
Is there a program that you could input the drawer size and then the sizes and quantity of the items you want bins for that would then do the Tetris for you? AI? Very cool organizer setup you are putting together.
cccoltsicehockey
Charlotte, NC
Not exactly what it is designed for but I wonder if you could get a rough starting point using a sheet goods cut calculator. That said I am surprised someone has not made a gridfinity calculator for bins and not just the grid panels.
L
lilscorpion
Colorado
A very good question. It’s occurred to me a time or two but haven’t spent time thinking about how it would work. It would be a nice tool to have. The way I do it now I end up re-printing pieces to finalize the layout after a bunch of guessing.
Maybe. The hard part is there’s a lot of variables. Bin size, what you want to organize together, base size, and even clearance (drawer depth) maybe. Like the idea tho
Edit: maybe I’m over complicating it. Need to think about it more.
cccoltsicehockey
Charlotte, NC
My biggest fear of starting down this rabbit hole for organization is that I know there are still a ton of tools I want/need to eventually buy. If I make my drawers perfect for now I could be tossing an entire drawer full of prints in a couple of months when I finally need one of those tools for a project and at it to the collection. I likely will still do it anyways.
Jgaz
I love that cleco holder!
L
lilscorpion
Colorado
It’s always been that way for me. The tool box is always evolving and changing and I’ve already accepted that maybe I will pitch a bunch just in normal tool replacement situations. I decided that is one of the risks of having this level of organization. May not be for everyone tho. It’s also not cheap and the expense is also an important thing to consider.
L
lilscorpion
Colorado
Alright…damn this moving and re-organization thing. It’s causing me to go thru $hit that I tucked away like suppressed memories of another time where stuff was…different.
I unpacked one box and had a memory in a past life where I recalled using the chalk markers for metal work that utilize round chalk. It’s cumfy.
So I thought to myself - “self, order some more of that round chalk because I ain’t gots much”. Like a hundred or something. I’ve been slipping on “consumable inventory”. So I did.
Now I’m unpacking a different box from a different time and I’m like “WTF, how did I live without the flat marking chalk”?!?
Maybe every prototype part I made on the press-brake I had my trusty square chalk marker. I only have 3 more…
My brain says order more! Order more! Am I losing it? Flat or round? Seriously, I don’t need this on a Friday. 😂
L
lilscorpion
Colorado
Didn’t get a lot of time last night but did get the sleeves installed in the oven base. The hole is drilled thru the square tubing at 1/2” and then top only is expended to 3/4”. Then a piece of 3/4x.250 DOM tubing is cut amd pressed (hammered) into the top hole and I press a boot thru to ensure it’s located correctly. Little tacks with the TIG keep it in place.
Remove the bolt and weld it all the way around.
Installing feet into the tubing this way helps the tubing better bear the load that will be on top of it.
The excess stud will be concealed inside the oven wall if fully lowered.
Plenty of adjustability for what I need. I’m only needing to handle a few degree drop over 3’.
Horror Business
I deeply appreciate that you not only show us the what, and the how, but also take time to explain the why. Understanding the why is crucial to learning (at least for me it is) and it helps the learner make future judgement calls, and life is all about judgement calls. Thank you.
L
lilscorpion
Colorado
How heavy is this oven?
Conservative calculations - 4x8 of 16ga steel weighs ~88lbs. 7 sheets inside, 7 sheets out - 1200 lbs. I’m gonna an assume that the rounding up if the sheet metal (I won’t use 16ga on the outside) covers the steel studs and insulation. Let’s add another 200lbs for the ducting, fan, and controller. Maybe add another 100 for some reinforcement of the door, hinges, etc
So less 1500lbs. 😜
If you’re gonna say the inserts in the rectangle tubing wasn’t necessary, maybe but it took maybe half an hour and I’d rather super overkill it now instead of find out they’re twisting because I never took engineering classes. 😆
L
lilscorpion
Colorado
I like that DOM insert technique for thru bolting! Clever.
It works very well keeping one side captive and it helps prevent bolt creep or hollow tube expansion. More or less it’s where you tighten the bolt to correct torque but the tubing shape can’t hold the tension over time causing the bolt to become loose. I used it in the suspension systems (jeep stuff) where a bolt needed to go thru a vehicles frame.
csp
Franktown, CO
I'd call the DOM inserts overkill for sure. I have a deep appreciation for such overkill. :D
With all of the trays/dividers/etc that you're printing I'm curious what happened to all of the organizing pieces that you had machined for use at the old house?
L
lilscorpion
Colorado
Some have been pitched but I have most of them still. You want em?
L
lilscorpion
Colorado
I clearly have ADD. I’m in the middle of organizing many of my tools/tooling drawers right now and realized I need to move my hardware out of my main base cabinets and into the ones at the head of the shop. Sooooo, off I go - smaller fasteners will be in the smaller bins. Grade 5 will be space grey and black lettering.
I checked size, these smaller bins will work for the various standard fasteners. IMG_5721.jpeg
I’ve stocked for a while many different kinds of fasteners (crazy I know): nylock, low profile nylocks, top locks, flanged mid-locks…haha. Not for all sizes
And thread pitches, but for a lot of them. Clearly this one bin won’t suffice. Need to figure it out. Conceptually you get it.
Grade 8 will be in yellow with black lettering. Figuring out sizing as the bolts get larger will take some practice.
Heres a setup with normally delivered quantities from McMaster (except the 1-1/4 which I raided recently when building the material carts). Bins this size will work for 3/8” and 5/16”.
L
lilscorpion
Colorado
Playing around with Fusion in prep for making sheet metal parts (once I have the plasma and press brake up). Fusion is fairly intuitive but I'll need to play with real parts before I can better understand how it works for real. Also, I kinda expected there to be more configuration adjustments but we'll see if it matters once I get to bending.
Here's an example: in the picture above, using "Start" for the bend line position I had to add little extensions to get to a weldable joint (where the wings fold into the main body) which makes very little sense to me...deviates from the value of CAD/Software.
To me it seems like I should be using "Center" but if I do the wings collide with the part and I get an error.
I don't see an override that will enable me to adjust this collision either. Any ideas?
slodat
Central-ish, WA
This is how I would make this part. Maybe it will help.
Start with the base flange sketch:
When the sketch is all black lines, it is fully defined/constrained. Next use the flange tool to turn that sketch into a solid. The reason to use the flange tool is the thickness is based on the sheetmetal rule. 14ga CRS using the 1/2" die in my case.
From there I pull three flanges from the bottom edge of the base flange. Note I've selected "Two Offsets" for each flange.
On the long edge I use a negative offset of the material thickness. Also note that "miter corners" is deselected, and the relief shape is changed to tear.
Then on the two sides I use an offset of 0.001":
This closes the corner, leaving a 0.001" gap. Then make a flat pattern:
The resulting flat pattern:
The aqua colored lines are the edges of the bend radius, and the center is the bend centerline. To give the sides the angle, make a sketch on one side:
Extrude through the part:
Updated flat pattern:
L
lilscorpion
Colorado
The resulting corner detail:
This kind of part doesn't require welding, generally speaking. We do weld parts like this when the project warrants. It's a quick fusion weld with little if not any filler.
Thanks Stephen. So in this case you're using a flange instead of a bend. That would be why I don't have an options other than "Start", "Center", and "End. Flange can work but based on how it's utilized, it seems like it's not technically part of the part. Meaning, what happens when your model has multiple connected bends that fold up into the entity? I do agree however that this is a much easier way to do what I was trying to do. Makes sense. I'll see if I can add a flange to a flange...
L
lilscorpion
Colorado
well today wasn’t anticipate. Made the sheet goods cart big enough to hold ~30 sheets of 3/4” ply. While at the ply-gettin’ store I was offered a deal I couldn’t refuse - 20% off so I bought almost all of it. Now I got a storage problem again even with the new cart.
Even so, I’m happy. Happy is good. 42 sheets of 3/4, 12 sheets of 1/2, and 8 of 1/4”. Let’s build!! 😆
L
lilscorpion
Colorado
had the 3D printers working on some shop parts today as well. Made some test caps out of PLA for the plywood cart.
Made a few adjustments and then printed enough for all the tubing ends. Best part is they were being made while I was out getting plywood.
Pulled them off the sheet when I got home. PETG prints nice when it lays down right.
And smacked them in place with a 0 dead blow.
Maybe the best part of having the 3D printers now is the ability to make whatever I want with nothing more than a spool of plastic and things like this really are the finishing touch. Can’t wait to be able to powder coat the cart as well.
